Mitsubishi WD-57734 57 in. HDTV Television
Problem for Mitsubishi WD-57734 57 in. HDTV Television
Mitsubishi WD-57734 TV Powers on, Have sound, No Pic, Shuts down!
By just-hunt on Sep 30, 2009
My HD1080 Rear Proj. TV seemed to take longer for the picture to come on. I could hear sound then the pic would follow. Now the sound is clear but the pic never does come up, it's just black. The green power button will flash while, I would assume, the pic is trying to boot up but then after about 70 seconds the TV shuts itself off.
Any idea on what's wrong? Can I fix it myself? If not, any idea what I'm looking at dollar-wise?
Thanks in advance for any help anyone can give me.
Best regards,
Kevin
Comments:
Sep 30, 2009
- God bless ya brother! I'll try it tonight. Always good to see another ambassador for God on the net! I'll update you with what I find out. I was told about the reset button and I'm going to try that after work, then I'll see about that lamp. In His grip, Kevin
Oct 01, 2009
- I'll be ordering the lamp. The reset button did not do anything. Bummer. I'll keep you updated.
Solution #1
posted on Sep 30, 2009
Not Rated)
King R2
Rank: Guru
Rating: 94%, 41 votes
Hi,if you hear constant clicking or trying to turn on it could be your ballast.But if tv is between 1 yr -2 yrs maybe its time to replace the lamp.This will be the part number you need 915P061010 you can find it in discount-merchant to get the Philips lamps that normally last 2-4 yrs.God bless. The price will be around $129.99 you can replace it your self just put the part number 915P061010 on youtube and you'll see instructions to replace lamp.
Was this helpful?
Yes
No
Popular Solutions for Mitsubishi WD-57734 57 in.
Questions and Unsolved Problems for Mitsubishi WD-57734 57 in.
Do you recommend Mitsubishi WD-57734 57 in. HDTV Television?
Answer
Answer
I heard a pop in my televison and now I have no pictiure or sound but the power is still on Can it... (More)
Answer
when i turn on the air condition the engine doesnt accelerate but instead it cuts off. my mechanic... (More)
Answer
when the tv is turned on a message at the bottom says the tv will turn off in a few seconds and to... (More)
Answer
tv will turn on, but in 2 seconds it turns off. unable to get tv to play at all!
Answer
It keeps on cracking and poping as long as have it on.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Mitsubishi WD-57734 57 in....:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 745
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
