Code for thomson vs 360 transmitter
I have a thomson vs360 transmitter. I can turn the sound up using my sky remote on the receiving tv, but I cannot turn the sky channels over - is there a code I need. Sky don't seem to be able to help
Regards,
  • joan36 Nov 23, 2008
    I need a code
Kazong
  • 152 Answers
SOURCE: Remote control code to program for directv receiver
i have a ton of codes i need your model# of your Directtv Receiver.
Posted on Feb 05, 2008
SOURCE: Code for RUC/Sky
The following code: 253 will work on Sky remotes for the following tv:
Bush LT42M1CFA
Posted on Feb 17, 2009
SOURCE: trying to set up sky remote with TV (19LG3000)
The Sky Remote Code 1280 worked for my Sky+ box
Dannyboi1940
Posted on Feb 18, 2009
SkyGuy08
  • 27 Answers
SOURCE: Sky remote wont control on/off , volume, or terrestrial channels
Press tv on the Sky remote
press and hold select and red until the led blinks twice
type in 0 0 6 0
press the power button, if the tv turns off then the press select and the remote should work all the tv functions.
If the tv does not turn off then press tv then the power button and keep doing this until the tv turns off, once it turns off press select and it should work.
If you have any problems let me know
Dazz
Posted on Apr 04, 2009
SkyGuy08
  • 27 Answers
SOURCE: Remote code needed (sky+) to sync with Sony bravia kdl32v2000
1. Press tv on your Sky remote control.
2. Press and hold down select and the red button together until the red light at the top of your Sky remote control flashes twice.
3. Press tv again
Then enter the remote control code using the number keypad. The red light will flash twice if a valid code has been entered.
Sony Code: 0000
4. Point your Sky remote control at your TV and press the Power button. If this turns the off as you'd expect, then the tv should be set, press Select and the remote should work
5. If the TV does not turn off press tv, then press the Power button again, repeat this process until the TV turns off, when the TV turns off press Select.
Posted on Apr 08, 2009
Unabel to use sky control for sound
You have to programme the correct code for your TV into the Sky remote.
You can get these via "Sky Active" (if your box is connected to a phone line) or from the Sky website, or google search: "Sky remote codes".
However your sky remote wont necessarily control more recent televisions unless you have a REV8 remote control. You can check this by taking the battery cover off your remote and looking at the sticker inside. If it says RC1600/00 you're probably not going to be able to control your TV. REV4 and REV6 are more likely to work - but not guaranteed. If it says REV8, then you are probably not using the correct code or you're not programming the remote correctly.
If you have REV8, the correct code for your TV (according to Sky) is: 0678 or 1678 or 0254
Sky remote code finder page is here: http://sky.uebv.com/
Sky guide to finding your remote code and programming remotes is here:
http://www.sky.com/helpcentre/tv/sky-remote-control/program-your-sky-remote-control-to-work-with-your-tv/
Please rate my solution if you find this helpful. Thanks.
Oct 13, 2010 | Panasonic Viera TH-42PX80U Plasma TV
I need sky remote code for sharp tv model no lc-32sh7e
Hi there. I hope you will see this reply. I bought one of these TV's yesterday and I've got the code from my dad's website www.satcure.net
If your remote is Version 6 then you will be able to follow the help on the sky box under
Interactive
Customer service
Program Remote
Then follow the steps using code 1221
If you have a Revolution 8 remote then you will have an easier job but with a 3 digit code.
3 digit code is 253
TO PROGRAM THE remote USING THE 3 DIGIT CODE:
1. Turn on the TV receiver
2. Press TV on the Sky Remote Control
3. Hold down SELECT and the RED buttons together for approximately two seconds, until the RED LED on the Sky remote blinks twice.
4. Enter three digit code from list for the receiver (early versions now flash twice).
5. Press select to enter code structure (the LED will flash twice if a valid code has been entered).
6. Now press the STDBY button and test other functions.
Hope this helps/works!
Apr 21, 2010 | Sharp Televison & Video
Cannot programme the sky remote, have used 0771 and various others
some of the remote,not all of the codes are listed, try to run scan mode.Check if that remote control has a code scan function.
Aug 29, 2009 | Thomson 20LB125B4 20 in. LCD TV
I want to find the Sky remote code for this Tv.
Just got an LG 42LH2000 and code 0206 works
May 16, 2009 | LG Televison & Video
Code for sky plus remote please
Hi, the code is 1130, i have the same television and the code works perfectly with a rev 8 sky+ remote.
Apr 04, 2009 | Televison & Video
My sky remote has stopped working on my samsung tv
Easy peezy...just press TV on your sky remote,now hold select and the red button until it blinks twice,after it blinks twice enter this code ...1430....it sjould blink twice again,now press standby,it should turn your tv of,if it does press select to save these settings,it should now control your volume too,let me know if this helps
Feb 16, 2009 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
How do i key in code for digibox
Repeat if necessary until a code is found that works most common functions.
TO PROGRAM THE remote USING THE 4 DIGIT CODE:
1. Turn your TV on.
2. Press tv on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press tv on your Sky remote control again.
5. Key in the four digit code for your brand of TV. The light on the Sky remote control blinks twice. If the light blinks once only, recheck the code for your brand of TV and start again at Step 1.
6. Press the standby button on your Sky remote control. If your TV switches off, press select. The light on the Sky remote control blinks twice (code stored). If your TV does not switch off, press tv, then press the standby button. Repeat this (press tv, then standby) until your TV turns off, then press select (stores code).
If at this point the LED on the Sky remote control blinks three times then all possible codes for that make of receiver have been checked. Repeat from step one, ensuring that you enter the correct manufacturer code.
At the end of the sequence, if you see the TV Guide screen, the remote control setup process is complete. If you did not see the TV Guide screen, you must now complete the following steps.
8. Press tv on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice.
10. Key in the number of the channel on your TV that you use for watching satellite TV.
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
If after trying this, you still have problems, call your broadcaster's help desk. For your broadcaster's help desk number, select the Telephone Numbers option from the Services screen.
Dec 19, 2008 | Computers & Internet
TV REMOTE CONTROL NOT WORKING
1. Turn your TV on.
Oct 17, 2008 | Philips HDD065 MP3 Player
Tv codes
ok codes look up online what model tv u have so i can help u get yours
Feb 03, 2008 | Sagem PVR 6280 Freeview DTV Receiver /...
Archos dvr station remote control
I HAVE A SKY+ BOX ALSO , AMSTRAD MAKE ON BACK, TRY SETTING IT TO DIGITAL RECEIVER INSTEAD OF SAT RECEIVER, THEN SELECT THE MAKE PACE, THEN CODE NO 8 ( B676 ) THIS DID TURN OFF MY SAT RECEIVER BUT THEN ACCIDENTALLY SCREWED UP THE NEXT STAGE AND I CAN NOW NO LONGER TURN THE SAT BOX OFF,
BUT YOU MAY HAVE MORE LUCK, IF YOU DO NOT SCREW THE NEXT STAGE UP, BEST OF LUCK
Nov 30, 2007 | DISH Network ViP622 DVR DTV Receiver /...
Televison & Video Logo
373 people viewed this question
Top Televison & Video Experts
