Question about Maytag Neptune MDG5500AW Gas Dryer
Why does my dryer take so long to dry my clothes? It seems to get warm because when there finally done they come out warm. I have to run it through 2 cycles and towels sometimes 3 cycles
  • Maytag Master
  • 2,605 Answers
It sounds to me like a problem with either a) poor venting/obsruction of some kind...possibly kinked hose ? or b) the blower wheel in the unit responsible for moving the air is spinning freely on the motor shaft.
Check your venting first, insure you have a strong flow of air where the unit exhaust's outside. if yes, good. if no...pull the vent off from the back of the dryer itself and make sure you get good air flow (exhaust) there. If you don't get any or very little flow with the vent off, chances are likely you have a broken blower wheel.
These are the most common and likely sources of a dryer that actually heats, but takes a long time to dry garments.
(Another possible cause that goes unnoticed often, is no issue with the dryer at all, but the washer not spinning properly,(kinked drain) be it mechanical or overloading...check that too).
hope that helps
good luck
Posted on Sep 30, 2009
Wrinkles clothes terribly. Solutions.
Check your settings on your dryer. See if it's on a longer duration of time to dry. Dryers have different wording depending upon the make and model. If you're trying to dry smaller loads the heat settings s
does not have to be set for very long. Heavier, loads with thicker clothing will need to dry a little longer. When you take the clothes out of the washing machine, do you shake the clothes before putting them in the dryer? And do you use dryer sheets? Believe it or not, they're not only used to help make your clothe's smell fresh but they also help elevate static and a few wrinkles.
Mar 23, 2015 | Washing Machines
How can I diagnose, isolate and repair my Amana, NED7200TW dryer it runs but will not heat?
Since you say it happened gradually seems like it's not the heating element. If that's functioning properly you should see the orange glow inside the dryer when running. If your dryer does not have a glass door you can keep the dryer running by holding the button in. Look on the door, at some point you should see something that makes contact and pushes a switch on the frame. You can trick it by manually closing the switch. Be careful. I would suspect the trouble is a clogged lint exhaust. Over time this will fill with lint preventing the moist air to escape. This is how the dryer works. The hot wet air in the drum needs to vent outside to dry the clothes. When this becomes clogged you have nowhere for the moisture to go. So it stays in the drum and runs and runs without drying clothes. Also make sure you clean out the lint trap after each use. Clean the entire vent path. Also make sure you are venting outside. If not, you are just recirculating wet moist air back into the dryer. When working properly, you should feel a good flow of warm wet air at the outside vent. If not there is still a clog. Good luck.
Sep 05, 2014 | Amana Dryers
Samsung dv317 gas dryer takes forever to dry cloths. Cloths do not feel very warm when they are finally done. I changed the valves but still very little heat. It looks like the flame ignites but them it...
Easiest thing to check is the dryer vent. Maybe you've already done this, but make sure the 4" vent is not kinked or stopped up with lint. This causes the dryer to overheat. Hope this helps.
Jun 24, 2011 | Samsung DV306LGW Dryer
My dryer doesn't seem to be drying my clothes. I have to run the cycle 2x for clothes to dry and the lint is cleaned out
Lots of the time lint still gets by and starts to block further down into the ductwork and around the fan.
Unplug dryer from the wall
Pull dryer out and remove hose from the back
Inspect inside with light you can put your arm up to to feel around
Look for the odd sock, clumping of lint or bounce sheets
If dryer is not even warm when running the heat elemnt or thermostat may be faulty
Jan 20, 2011 | Kenmore Dryers
Have a whirlpool cabrio gas dryer. It takes several hours to dry one load of clothes. The clothes seem to stay damp towels may take all day... what could be the problem
Have you opened the door while its running to see if its warm inside (heater working) If its getting warm and still not drying the clothes properly you likley have a air circulation concern. With the unit running check the exhaust vent outside from dryer it should have a good flow of warm air, if not you have a restriction sowher between the unit and outside. Heat alone will take forever to dry clothing,you need good air circulation to remove the moisture from the clothes otherwise all you will end up with is warm moist clothing.This generaly happens over a long period of time and then all of a sudden you realize the dryer is not working like it use to..Hope this helps you with your concern.....
Aug 09, 2010 | Whirlpool Dryers
Dryer turns on and rotates. However, does not dry clothes completely. Cycle signals wet,then damp,cool down and finally dry,but clothes are still wet. Sometimes the dryer works fine and completely dries...
This problem may be the result of a dirty lent filter which if clogged will short cycle the dryer and the clothes will still be damp when done. Also a dirty exhaust pipe (usally 4") will prevent the clothes from drying correctly. Make sure that the air is leaving the machine. To do this you have to go outside when the machine is running.
Mar 21, 2010 | Kenmore Dryers
Dryer will not get warm will still run, product only 4 years old. clothes will not dry
dryer will not get warm will still run, product only 4 years old. clothes will not dry
Oct 16, 2009 | Whirlpool Dryers
Wont dry clothes
you need to clean out wall vent and dryer vent,thats your problem-mike
Nov 30, 2008 | Whirlpool Dryers
Dryer takes too long to dry my clothes
My dryer has been taking longer and longer to dry my clothes. Sometimes it takes multiple cycles before the clothes become dry. They seem to be getting warm, but are not drying as quickly as they use to.
Jul 08, 2008 | Whirlpool ET8CHEXSQ Dryer
Maytag Neptune MDG5500AW Gas Dryer Logo
1,066 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
