Question about Canon F-603 Calculator
Canon F-603 Rounds Off At Decimal
Except upon data entry, nothing to the right of decimal shows. Thus:
Press 3.14 ---> 3.14 appears on scree>
Press X ----> 3. appears on screen
Press 2 ----> 2 appears on screen
Press = ----> 6 appears on screen
Efficient rounding, but not acceptable to me. How can I get the decimals I need?
Bob Wersan
  • nessa2102 Jun 09, 2008
    I have the same problem with the Canon F-602. Can anyone help?
Press mode then the dot (.)
Posted on Mar 11, 2008
  • jhay_ehm Mar 11, 2008
    i'm sorry i mean press shift + fix + dot (.)
Convert a decimal into a fraction
Conversion is not always possible. If a decimal result has just been found and displayed, pressing the [a b/c] fraction button may convert the result still in answer memory (ans) to a fraction. But if you alter the value of answer memory and type in the (approximate) decimal value that you copied from the screen, you may not get your correct fraction.
Sep 22, 2014 | Canon F-603 Calculator
I want 1000000 to appear as 1,000,000 in fx82es plus
I am afraid there is a misunderstanding. The sequence you describe changes the decimal marker from a dot to a comma. It does not insert a thousands separator.
May 13, 2014 | Casio FX-300MS Calculator
How can I change the setting to print total the decimals. It is rounded off to the nearest one hundred.
You need to set your decimal selection to full-floating if you expect any numbers to be more than 4 decimal places.
Each time you press the DEC key it changes the decimal selection. From F to 0, 2, 3, 4 and A in that order. F is "full floating" but appears as a blank on the screen. A is the "add-mode" for currency transactions. The "A" does show on the screen if this is your selection.
As soon as the letter for the number of decimal places you want ("F" is blank just before 0 decimals) appears on the screen you are "ready to go." Problem is, the decimal indicator numbers and letters are so tiny and screen is so difficult to read that under many lighting conditions your selections might be all but invisible. They are in the upper left side of the screen just to the right of the equally difficult to see multiplication and division rounding indicator "5/4." PS If the 5/4 does not appear on your screen then you have set the round-off function to not available.
Feb 26, 2011 | Canon P1-DHV Calculator
Where do I go to find an on-line manual for TI 5045 Sv Texas Instruments calculator?
TI-5045 SV
English.............................................................. 1
Fran?ais ............................................................ 6
Espa?ol ............................................................. 11
Portugu?s ........................................................... 16
Examples, exemples, ejemplos, exemplos .............................. 21
Removable tab
Leng?eta extracci?n
Alavanca usada para o rolo
Ink roller
Rouleau encreur
Tamp?n de tinta
Cartucho de tinta
Your Texas Instruments calculator has a built-in printer for producing a permanent record printout of
your calculations with negative numbers printed in red. A big, easy-to-read display also enables you to
check entries or perform quick calculations without printing.
1. Connect the calculator to a proper power outlet (110-120V or 220-240V
where available).
2. The calculator is turned on by setting the POWER switch to the PRT
Inserting the paper (see illustrations 1, 2, 3, and 4 on page ii).
1. Turn on the calculator.
2. Open the printer compartment cover by pressing down on its front edge and sliding it back in the
direction of the arrow.
3. Fit the roll of paper on the holder so that it unrolls from the bottom, with the loose end toward the
4. Cut the end of the paper squarely and insert it firmly into the printer slot on the back of the
5. Press & until the paper is in the printing position.
Replacing the ink roller (see illustrations 5 and 6 on page ii)
1. Turn the calculator off and tear off the excess paper.
2. Remove the printer cover by pressing down on both sides of the front edge and sliding back in the
3. Remove the old ink roller by lifting it with the removal tab.
4. Insert the new ink roller into the compartment and press down gently until it snaps into place. Close
the printer compartment.
Note: The old ink rollers should not be refilled. Replacement rollers can be obtained from your local
retailer. The warranty does not cover ink roller replacement.
: 5/4 9 + F 0 2 3
Set the POWER, ROUND, DECIMAL and TAX switches as required.
Note: The TAX switch is spring-loaded to return to CALC when it is moved to SET and released.
The switch settings are summarized in the following table:
No printout is provided; however, the display can be printed by pressing
The printer provides a printout of your calculations but does not count them.
The printer is on and an item count of additions and subtractions to or from
the register is printed when sub-totaled or totaled.
The GT position controls whether or not the totals from the independent add
register are accumulated in the grand total register.
ROUND Rounds the result of a calculation to the selected number of decimal places.
Truncates the result to the selected number of decimal places.
Rounds the result up or down according to its value. For example, when the
DECIMAL switch is set to 2, the result is rounded up if the third decimal
position is 5 or more and rounded down if it is 4 or less.
Rounds the result up to the selected number of decimal places.
Ex. 220 P 6
Ex. 220 P 6
Press Display Printout Press Display Printout
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.66 6¦ =
36¦66 ?
2 0. 0¦ C
220 ' 220. 220¦ P
6 3 36.67 6¦ =
36¦67 ?
DECIMAL + Add mode: All results are given with two decimal places. For addition and
subtraction only, a decimal point is automatically placed to the left of the last
two digits entered, unless the number already includes a decimal point.
F Floating mode: Any results are displayed and printed with the maximum
0 2 3 4 Fixed decimal mode: Sets the number of decimals to 0, 2, 3, or 4.
Lets you enter a tax rate to perform tax calculations.
Stores the tax rate. Pressing ! or " after a tax rate has been entered,
adds/subtracts the stored tax rate to/from the value in the display.
Ex. VAT = 17.5 %
100 + VAT
Ex. VAT = 17.5 %
235 - VAT
Move and hold the TAX switch to SET. Press 217 L 5 and release the TAX switch. It
automatically returns to CALC. 17.5% is printed.
2 0. 0¦ C
100! 117.5 100¦
17¦5 @
117¦5 ?
2 0. 0¦ C
235" 200. 235¦
N35¦ @
200¦ ?
Note: The most common setup is POWER: PRT, ROUND: 5/4, DECIMAL: 2, TAX: CALC. Use these
positions for the examples unless other settings are given.
Basic keys
I Clear Entry: Clears an entry, enabling you to enter another number in its place. Note
that this key does not clear the add register.
2 Clear Key: Clears the add register, any pending operations, and the display. 0.C is
printed. Does not clear the memory.
( Right Shift: Deletes the right-most digit entered from an entry before an operation key is
pressed. Shifts the remaining digits one place to the right.
L Decimal Point: Enters a decimal point.
4 Date/Non-Add: Prints a date (such as 12¦10¦96) or a number for reference purposes.
Does not affect calculations. This entry is printed on the left side of the printout, the date
or number preceded by the # sign.
& Paper Advance: Advances the printing paper.
Addition and subtraction keys
9 Add: Adds a number to the add register. Displays the cumulated result.
: Subtotal: Gives the intermediate total from the add register. Using this key does not
affect the contents of the add register.
. Subtract: Subtracts a number from the add register. Displays the cumulated result.
E Total: Gives the total from the add register, and then clears the register.
Multiplication, division, percent and margin keys
? Multiply: Multiplies the number in the display by the next value entered.
' Divide: Divides the number in the display by the next value entered.
3 Equals: Completes any pending multiplication or division operation.
> Percent: Calculates percentages, ratios, add-ons (e.g. of VAT), or discounts.
# Gross Profit Margin: Calculates the selling price of an item when its cost and gross
profit (or loss) margin are known; also used to obtain a price excluding VAT.
Cost: 594
Profit margin: 40%
Press:2 594 # 40 3
Selling price: 990
Gross profit: 396
Selling price including VAT: 252
VAT %: 20%
Press: 252 # 20 . 3
Selling price excluding VAT: 210
VAT: 42
/ Grand Total: Gives the grand total of the operations previously performed and stored in the
Grand Total register. Every time a total is obtained with E it is cumulated into this register
(printout shows G+) which is only cleared when / is pressed twice. During long
calculations, if / is not used, this re
Jan 16, 2011 | Office Equipment & Supplies
Whenever I try to add or subtract a number with a decimal in it, when I press the + or - key, it rounds the number I entered either up or down to the nearest whole number.
You have the calculator set to round everything in the display to zero digits after the decimal point. To change this, press SHIFT [DISP] and then a digit representing the number of digits you want to the right of the decimal point.
Nov 09, 2010 | HP 10bII Calculator
Follow these steps to check for problems on the machine you cannot access.
1) Open the registry editor on the machine you cannot connect to by clicking on Start, Run
2) Type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following entries
4) In the right-hand portion of the Registry Editor look for a key called IRPStackSize
5) If the key exists, double-click on it and increase the decimal value to 15 and click OK. Close the Registry Editor, reboot the computer and try to connect to the network share. If you are still unable to connect follow the above steps again and increase the decimal number for IRPStackSize by 5 and try again. Continue to do this until the stack size is large enough to permit access. Personally, I had to increase the number to 25 before I could connect. The decimal range for the parameter is between 11 and 50.
6) If the IRPStackSize key DOES NOT exist in the right-hand column of the registry editor, then click on right-click in the blank area in the right-hand column and choose New
7) Then Click on D-Word under the Key column
8) In the Name of the new key, type the name IRPStackSize and press Enter. Type the name with the correct capitalization as shown above.
9) Now double-click on the IRPStackSize key and type 15 in the value data box and place a dot next to Decimal then click Ok.
10) Close the registry editor and reboot the computer. Try to access the network share again. If the same error appears follow the steps above to increase the value and reboot again. Continue this procedure until the problem is resolved. The decimal range for the parameter is between 11 and 50.
Oct 18, 2008 | Computers & Internet
Canon F-502 statistycal scientific calculator
As I added on to the previous solution on the other problem.
"Okay, I did what the best solution did and worked with it.
"1. press 2nd F (left top corner)
2. ENG/FIX (the button next to 2nd F)
3. press 0 (if you don't want calculator to round off any decimals)"
In order to get your exact value of pi, in step #3, instead of 0, press the decimal [ . ]
This should give you no decimals when entering a number and give you 3.141592654... when you input pi.
Hope that works/helps."
Nov 05, 2007 | Canon F-502 Calculator
HeLp !
That's the Binary code. You have to change it back to the Decimal code. Try to change it back with the shift and Mode buttons
Oct 08, 2007 | Canon F-603 Calculator
Canon F-603 Calculator Logo
635 people viewed this question
old marine
old marine
