Question about Samsung J700 Cellular Phone
Bluetooth problem my bluetooth does not wanna turn on and does not find other users
How To Set Up Bluetooth
To make the Bluetooth connection, you turn on the Galaxy Tab's Bluetooth radio. Obey these directions:
  1. On the Apps screen, open the Settings icon.
  2. Choose Wireless & Networks.
  3. Place a green check mark by the Bluetooth option.
When Bluetooth is on, the Bluetooth status icon appears.
Here is a tutorial video on youtube:
http://www.youtube.com/watch?v=ol5Vg-fpKDI&noredirect=1
If you wanna know more about Galaxy Tablet you can go to here: http://www.aneesoft.com/tutorials/tablet/index.html
May 21, 2013 | Samsung Galaxy Tab Tablet PC
My Bluetooth don't wanna work after I disconnect my audio system 2010 ford fiesta
Thats because the bluetooth is run through your factory stereo.
Feb 11, 2013 | Car Audio & Video
How do i turn on my acer aspire 4738 laptop bluetooth device on?
Here are steps:
Download the bluetooth driver from acer website
Install it restart your pc
Then press the bluetooth button which is on the top(above function keys)
Then right click on the file you wanna send through bluetooth then send via bluetooth
bluetooth adapter driver ENGLISH version
http://support.acer-euro.com/documents/reports/blue_share_eng.pdf
you will need to connect your bluetooth device with a usb lead then make both your computer and the bluetooth drvice discoverable also you might downoald software
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you. The BluetoothView application was designed to be a small tools that runs in the background, and monitors the activity of Bluetooth devices around you.
hope this helps you
Aug 25, 2011 | Computers & Internet
Will not pair hautecubaninc3@aol.com
Make sure bluetooth is enabled and discovarable on your phone!
Turn off your bluetooth headset, when you wanna turn it on, hold the power button which is the round botton, press and hold for appox. 10 seconds until you get a solid light and the pairing address should be 0000! if that doesn't work! hollar back at me!
Sep 04, 2010 | Jabra BT2050 Bluetooth Headset
How to active E500's bluetooth?
Hi tran_dat_syc.
After researching all the information online, I found the steps to enable the Bluetooth Device in the Computer.
Please follow the below steps to enable the Bluetooth Device in the Computer:
1) From the Today screen, tap the iPAQ Wireless icon located
in the Navigation bar at the bottom of the screen.
2) On the iPAQ Wireless screen, tap the Bluetooth icon.
3) When Bluetooth is turned on, the Bluetooth LED on the front of your Pocket PC flashes blue.
4) To turn off Bluetooth, tap the Bluetooth icon again. When
Bluetooth is turned off, the Bluetooth LED turns off and no
incoming or outgoing Bluetooth connections are possible.
5) Battery Saving Tip: Turn Bluetooth off when you are not using it.
For more information regarding to the Bluetooth Device, please refer to the User Guide mentioned below:
http://h20000.www2.hp.com/bc/docs/support/SupportManual/c00267893/c00267893.pdf
Please open the link above to view the User Guide.
Please refer to page 114 to 136 to view the detailed information to use the Bluetooth Device in the Computer.
Hope this helps.
Please feel free to ask for further questions.
Aug 21, 2010 | Computers & Internet
I wanna know whether aspire 4310 have inbuilt blootooth hardware available . if so where i can find the driver dowloads for xp
To find out, access the manufacturer's web-site:
http://support.acer.com/drivers_download.aspx
Select NOTEBOOK
Select ASPIRE
Select ASPIRE 4315
Select Document
Download the User Guide (8Mbyte).
Select Drivers
Download the device-drivers for XP or VISTA (none are available/needed for Windows 7).
Your "4315" computer has an "ExpressCard" slot,
and you could buy a BlueTooth card that fits into this slot.
The ExpressCard is the newest version of the PC Card. It is a smaller and faster
interface that further enhances the usability and expandability of your computer.
ExpressCards support a vast number of expansion options, including flash
memory card adapters, TV-tuners, Bluetooth connectivity and IEEE 1394B
adapters.
Jun 10, 2010 | Acer Aspire 4315 Notebook
Wanna use bluetooth applications?
go to the settings icon.
then press the joystick to the right side till you get the bluetooth menu.
then select the turn on bluetooth option.
after that u can send/receive data,pair devices etc...
Apr 04, 2010 | Sony Ericsson W350i Cell Phone
Need passkey for the pairing for bluetooth with
The passkey in the Phone prompts up only when you are trying to pair your device to another device,
So, you can provide 1234 as the password and another user who is pairing with you should also provide the same,
Incase if it is not working under Generic key or if you are facing any other problem related to Bluetooth pairing, Please contact your Service Providor and check..
Oct 24, 2009 | RIM BlackBerry Storm 9530 Smartphone
How to connect blue tooth from pc to samsung cameramobile?
hi there!
While the specific user interfaces implemented by manufacturers may differ from device to device, there are still some very basic steps to go through in connecting two devices for the first time. Users should always conduct the pairing process in a secure environment.
Charge the Devices
If the devices are new Bluetooth devices, often they must be charged before they can connect or turn on. This is particularly true of new Bluetooth headsets, which must be charged before use.
Power Up the Devices
Power up the devices you are trying to pair. With some devices, like Bluetooth wireless headsets, powering up the device also initiates the pairing process.
Turn the Bluetooth Functionality On
The Bluetooth functionality in a device may or may not be turned on when you receive the device. For many computers, users will need to turn the Bluetooth radio on from the control panel or system preferences.
Make the Devices Visible
As a security measure, some devices allow the Bluetooth functionality to be off, hidden, or visible. When trying to connect devices, users should make the devices visible so the devices can discover one another. After the devices are paired, users can set the devices to hidden if they have concerns about their devices being discovered by others.
Place Both Devices in the Connection Mode
After both devices are charged, powered up, and the Bluetooth functionality is turned on, each device needs to initiate a communication session. Typically, in a connection between two devices, one device acts as the “host” and the other device acts as the ”guest.” The device in the host role is the one with the user interface from which most of the connection setup will take place. A device can be in the host role with one device and in the guest role with another device. For example, in a phone and wireless headset pairing, the phone is the host. However, in a phone and laptop pairing, the laptop is the host.
Enter the Passcode
After the two devices have discovered one another, the user will be asked to enter in a passcode in one if not both of the devices. In some cases, like with wireless headsets, the passcode is a fixed passcode assigned to the headset by the manufacturer. In those cases, the user enters the assigned passcode into the host device. The user will find this passcode in the user manual. In other cases, the user will be able to enter in his/her own passcode. In these cases, the user will enter the passcode once into each device. It is highly recommended that users employ an eight character alphanumeric passcode for the one-time pairing process. After the passcode is entered, the devices will validate one another and complete the establishment of a trusted connection.
Deleting or Disconnecting Trusted Devices
When should a user delete or disconnect a trusted device? If one of your Bluetooth enabled devices is lost or stolen, you should unpair that device with all the devices to which it was previously paired.
How do you unpair or delete a trusted device? For devices like a mobile phone or computer, the user should go into the device connectivity settings and find the list of trusted devices. The user should then have the option of adding a new device or deleting a trusted device. Highlight the device you want to delete and push the delete button. A device like a keyboard or mouse, which only has a button or switch as a user interface, can only connect to one device at a time. To delete its previous trusted device, the mouse or keyboard just needs to be connected to a new device
Or you can try this:
Bluetooth Mobile Phone to Bluetooth Personal Computer
  1. Power up both the mobile phone and the personal computer.
  2. On the PC, open up the control panel and find the Bluetooth Device Wizard. This will assist the user in setting up a Bluetooth connection between the PC and trusted devices.
  3. Ensure the Bluetooth connectivity is turned on in the PC.
  4. Find the connectivity settings of the phone. Make sure Bluetooth connectivity is on and visible.
  5. On the PC, choose to find and add a specific Bluetooth device.
  6. Of the devices found, pick the mobile phone with which to pair.
  7. PC will generate a PIN code.
  8. Mobile phone will ask if you wish to be connected to the PC.
  9. After the user answers in the affirmative, the user will be prompted for the PIN code on the mobile phone. Enter the PIN code into the mobile phone, which the PC generated.
  10. Allow devices to complete the establishment of a trusted link.
  11. If prompted on the PC to choose the Bluetooth services, the user may have several services available. The user may be able to sync the phone and PC. The user may be able to set up dial-up networking (DUN) preferences so that the user can use the mobile phone as a modem for the PC over the Bluetooth connection. The user may be able to transfer files, like pictures or business contacts, between the mobile phone and the laptop.
  12. After choosing which services the user wishes to enable, the user can then finish the connection and exit the setup on the PC.
better yet go to this website: http://www.bluetooth.com/Bluetooth/Products/Devices/Generic_Pairing_Instructions.htm
Feb 16, 2009 | Samsung SGH-E251 Mobile Phone - Black
Samsung J700 Cellular Phone Logo
21 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
