Question about Sony KP-51WS500 51" Rear Projection Television
Hi!! my sony projection tv kp-51ws500 shows double picture. there is reddish outline & its out of focus. i need help to reapir this. please advise. thanks
  • 647 Answers
This sounds like a convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually charge between $200-$400
Posted on Sep 30, 2009
I have double picture on my KP-51WS500 Sony TV
The converence board is bad and if you remove the back it ios located on the right side towards the front and there are a couple of fuses on it, Covergence ICs, need change.
Sep 04, 2011 | Sony KP-51WS500 51" Rear Projection...
Out of focus, double blurred image with pinks & greens
Out of focus, double blurred Problem with the Sony KP-51WS500 51 in. Rear Projection Television
Apr 21, 2011 | Sony KP-51WS500 51" Rear Projection...
I need part # for Sony KP-51ws500 D board, and
Required D board part number for KP-51WS500 is appended below:
A1300417A... D COMPLETE BOARD
Available in Part Store, click the link for price info.
Thanks.
Jun 04, 2010 | Sony KP-51WS500 51" Rear Projection...
Convergence problems w the color tubes
Press the Majic Focus button on the front. If that doesn't fix it then the convergence ICs may be bad.
Mar 31, 2010 | Sony KP-51WS500 51" Rear Projection...
Have Sony KP-57ws500 rear projection i had the bulbs replaced 3 years ago now itseams as if everyting is out of focus.images outlined in green and red.
It sounds TV got convergence out ICs failure problem and causing 3D image or outlined picture.
There are 2 convergence out ICs mounted on D board in TV that need to be replaced.
Let me know if you need part number of ICs if you want to replace by yourself or call local Tv tech to fix it.
Thanks.
Dec 04, 2009 | Sony KP-57WS500 57" Rear Projection...
Sony kp57hw40 tv blurry image,
Yes, you have a bad convergence Ic--set uses two of them---have someone change both and adjust the set in the Tech menu--if you need more information or help email me etower.766@netzero.net---
Aug 09, 2009 | Sony KP-51WS500 51" Rear Projection...
Double and triple picture
replace the two STK392-560 convergence ICs they are located on the two large aluminum haet sinks on the DBoard also check the yellow pico fuses near the ICs
Jun 24, 2009 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51ws500 Sagging Picture and blurred colors
Bad convergence Amp ics mounted to large metal heat sinks on deflection bd.Sony parts around $40.00 each-generic approx 12.00 ea.The board must be pulled out of chassis frame to unsolder the ICs.and some alignment will be needed after replacement.NOT a do it yourself job unless experienced at soldering and desoldering.
Jan 04, 2009 | Sony KP-51WS500 51" Rear Projection...
The picture is out of foucus
If your tv is Sony KP-51WS500, then its rear projection tv and problem seems in convergence stage.
Please confirm model number to guide you further.
Oct 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500
the tv needs to have a convergence done on it to realign the picture..the colors have to be set a certain way or it will show shadows and it will only get worse
Jul 11, 2008 | Sony KP-51WS500 51" Rear Projection...
Sony KP-51WS500 51" Rear Projection Television Logo
274 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
