Question about Dell D430 Notebook
How do i get my laptop out of hibernating mode Since morning when i am starting my laptop it is going to hibernating mode directly and i am not able to use it.
  • Amruth Louis May 11, 2010
    Does this happen when you shutdown or just happens when youlog into windows?
  • 329 Answers
To permanently diable hibernation go to control panel>>power options>>hibernate>>uncheck enable hibernation.
or to increase hibernation time click on power scheme and adjust the hibernate time manually with your ease.........
Posted on Sep 30, 2009
My laptop keeps saying hibernating and i cannot get to menu screen.
Definition: Hibernate is another option for powering down your laptop. When you use Hibernate all data will be saved to the hard drive in a compressed form. Once you start up from Hibernate mode you will be able to work with the applications and documents you left open before putting the laptop into Hibernate.
Hibernate is best used to conserve laptop battery power when you will be away from the laptop for more than a few minutes. You can put your laptop into Hibernate overnight or when you will be away from it for a few hours. Examples: Rather than shutting down my laptop each night, I use Hibernate to help conserve battery power and enable me to access my open files quicker in the morning.
If you are not going to use your computer for a few hours, it is a good idea to put it to sleep (also known as mode) to save power. If you are not going to use the computer for more than a day, it is usually best to turn it off.
hope it helps.... please rate if you like my post...thanks
Jun 06, 2011 | Computers & Internet
Dell 1737 laptop won't turn on (A/C or battery powered). Last night I tried for 15-20 minutes then it worked. This morning it didn't work again (from stand by mode). I held the power button to shut down...
you have a BIOS bug when hibernation , leave without battery for few days try to turn on with the charger, and if turns on go to the battery settings and disable the hibernation option, later go to dell website and update your system BIOS.
please rate me
Aug 13, 2010 | Dell Studio 1737 Laptop
I ussually put mi laptotp to a hibernating mode but now I cant get it started the message it shows says: "hibernating" and its been like this for more than 3 hours How can I solve this?
Power off the laptop, remove the ac adapter, and remove the main laptop battery. Push the power button in for approx 15 seconds. This will bleed all power from the capacitors. Now, replace the battery and attach the ac adapter. Power the computer up. When it boots, go to the control panel > Power Options > On the top of the window you will see the hibernate tab, click on it and un-check the hibernate box. Hibernation will and can destroy parts of the registry. Sleep mode is fine for most laptops....hibernation is not.
Jun 30, 2010 | Dell Inspiron 1545 Notebook
The hibernate option is not getting activated.what should i do?
In window xp follow this steps to activate hibernate mode
go to start then setting and select control panel, then go to and performance maintenance, select power options, then power options property appear you can see 3 tab is hibernate there from down check enable hibernate, press apply then go to advanced tab on the same window, when i press the power button on my computer select hibernate there then press ok,
now try to press the power button on your laptop to go to hibernate mode
Regards
manish
Mar 24, 2010 | Dell Inspiron 6400 Notebook
HAVE A COMPAQ MODEL SR2177CL IF THE SCREEN HIBERNATES IT WILL NOT RESPOND HAVE TO POWER THE SYSTEM ON/OFF WILL WORK FINE TILL IT HIB. AGAIN PLEASE HELP
Attempt to turn off hibernation mode in the Windows Power Options.
Start > Control Panel > Power Options
Find the Hibernation option and change it to Never.
This way, the laptop will go to sleep, but not hibernate and store data to the hard disk.
Nov 25, 2009 | Compaq Presario F572US Notebook PC
Question
Hibernation is a power management feature. When you hibernate a laptop, you're essentially turning it off. So, unlike Stand By (Sleep) mode, a hibernated laptop isn't using any battery power at all - that laptop is off!
The secret behind hibernation is that before you turn off the laptop, everything you're doing with the computer is saved. (The contents of memory are saved to the hard disk.) When the computer is turned on again, it recovers from hibernating by reloading all the saved information and restoring your laptop to exactly the same condition it was in before it was hibernated.
Briefly, hibernation works like this:
1. You activate the hibernation feature.
Hibernation is activated differently depending on how it's set up.
2. The laptop hums as everything in memory is saved to disk.
3. The laptop turns itself off.
It's really and truly off: The battery isn't being used, and it's safe to store the laptop or put it away until you need to use it again.
To recover from Hibernation mode, just turn the laptop on. In some cases, the laptop may recover from hibernation when you press a key or touch the mouse pad. hibernated state for as long as you want.
Hibernation mode requires hard drive space. So you should be aware that when hard drive space runs low, it's possible that Hibernation mode won't work.
In Windows XP, you have to activate Hibernation mode before you can use it. Follow these steps to activate Hibernation:
1. Click the Start button.
2. From the Start menu, choose Control Panel.
3. Open the Power Options icon in the Control Panel.
4. In the Power Options Properties dialog box, look for and click on the Hibernation tab.
If you don't see a Hibernation tab, there's your answer: The laptop isn't capable of hibernating. Oh, well.
You might want to check the laptop's Setup program to see whether you can activate Hibernation there.
5. Select the Enable Hibernation option by clicking the check box to place a check mark in the box.
6. Review other options, if they're available.
7. Click OK to confirm the changes and close the Power Options Properties dialog box.
Optionally, close the Control Panel window, as well.
Some laptops may require you to restart Windows for this change to take effect.
Sep 09, 2009 | Computers & Internet
Hiberation mode ,,what do i do/
Hibernate mode is a power saving feature for computers. In hibernate mode, the current state of a computer is saved to the hard disk, and the computer shuts down. A user will have to power on the computer to restore the previous settings. When a computer resumes from hibernate mode, it reads the saved settings from the disk and restores the system state as it was before it entered hibernate mode. By default, hibernate mode is disabled. If a computer is not ACPI-enabled or APM-enabled, users will have to enter hibernate mode manually. Users cannot set the computer to automatically hibernate after a certain time. With ACPI-enabled and APM-enabled computers, users are able to set hibernate mode automatically
How to enable Hibernate:
Please follow this steps below to enable your Hibernate features:
1. Go to Main screen in your windows then right click your mouse to an empty area in your main menu.
2. After clicking the right click please select the properties then go to Screen Saver Tab.
3. Please Click the Button name Power then click the Hibernate Tab.
4. Please check the CheckBox name Enable Hibernation to enabled the hibernation if it is not hibernated.
5. To try test the Hibernate process please follow the steps in How to start using Hibernate below.
How to start Using Hibernate:
Please follow this steps below to active your Hibernate Features:
Make sure all necessary programs are closed prior to shutting down. Hibernating will put all programs to "sleep," but some programs won't start up properly. Experiment after this to figure out which programs perform as intended.
  1. Click Start and Shut Down,
  2. Point the standby button and maintain the shift key pushed,
  3. A new hibernation button appears: click it while still holding the shift key: voila your PC will hibernate.
Thanks
Aug 07, 2009 | Averatec C3500 Tablet PC
Acer Aspire 3610 plugged in closes down
I would suggest you just plug it in and do not power on the laptop for a few hours. Then try. If it persists reboot into safe mode and disable hibernation then reboot
Dec 06, 2008 | Acer Aspire 3610 Notebook
My laptop won't start up
It maybe stuck in a hibernation mode.
Make sure to hold down the power button for 6 to 10 secs.
That should force the laptop to shutdown completely and then should be able to boot back up by pressing the power button like normal. You may get a choice about deleting hibernation info, do that and you should be back up and running. If not, press F8 while booting (before you see the XP logo) and choose safe mode, if you can get into safe mode, good, just reboot and it should go back into normal mode. There maybe more to it, please let me know.
G'luck
Oct 24, 2008 | Compaq Presario 700 470024-192 Notebook
Desk top won't display-hibernation mode
Based on your post of failure to boot due to hibernation, you can try removing the battery and AC adapter connection for an hour or so. Thereafter, insert battery back and charge but don't power up. Allow the laptop to charge for a couple of hours. Try powering up/booting. Press F8 to start in Safe Mode. Once in Safe Mode disable Hibernation.
If the laptop still fails to power up, then it may be entirely another problem.
Post back results. Good luck and kind regards.
Nov 04, 2007 | HP Pavilion dv4000 Notebook
Dell D430 Notebook Logo
423 people viewed this question
Alun Cox
