Question about Minolta Di3010 Copier
We have a CALL SERVICE C0B60 error code on a Minolta 3000 copier. Any ideas on what to do other than call service?
  • Minolta Expert
  • 158 Answers
That is a stapler drive failure code you may have a bent staple or stapler motor is bad
Posted on Oct 01, 2009
Access code needed
Access to what service mode or admin mode, pin#
Mar 29, 2015 | Konica Minolta 1149-0291-01 Minolta Cs Pro...
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
ERROR CODE LIST FOR C450
Go to service mode and click on counters, then select Service call counter, there you will find the complete error code list for bizhub c450.
Dec 06, 2012 | Konica Minolta bizhub C450P Laser Printer
Minolta CSPro 3000 Copier/how to enter service mode
Press Stop - 0 - 0 - 1 or it maybe User Funciation then meter count - Stop - 0 - 0 -1 , it's been years since I worked on them
Feb 06, 2009 | Minolta Di3010 Copier
IMAGISTICS 2620 Error code C0500
How to reset malfunction code C0500 of a imagistic
Feb 03, 2009 | Konica Minolta DiALTA Di200 Copier
KONICA MINOLTA: CALL SERVICE 0017 P MOTOR 2
Our Magicolor 5550. It keeps coming up with the error message: CALL SERVICE 0017 P MOTOR 2 . Any idea as to waht it is
Dec 17, 2008 | Konica Minolta magicolor 5550 Laser...
Fatal Error 21H
FATAL ERROR CODE 21H / SERVICE CALL 21 TRANS DET SENS: Malfunction of the OHP detecting sensor
check the OHP detecting sensor (PC3A) (it's at the front above the waste toner sensor pc6)
May 22, 2008 | Konica Minolta magicolor 2300DL Laser...
Minolta Di151 Error Code C-13
The trouble is that Minolta did not provide a chart of error codes in the user manual; mostly error code issues would require a technician to repair anyway -- or at least somebody trained to do preventive maintenance. If you have a routine repairman, or if you have My Konica-Minolta access, you should be able to get more information that way. Other things to check:
  • Is a preventive maintenance due?
  • What was the unit doing before it threw the code? Was it making copies? Of what quality? Did it stop in the middle or finish a run?
  • Are you using good quality, dry paper? This was posted in December -- might you be having static problems due to dry air?
If you're in the United States, you can check Konica-Minolta's Sales/Service Locator for a local repair outlet. Otherwise, you may need to contact Konica-Minolta directly.
Dec 26, 2007 | Minolta Di151 All-In-One Laser Printer
Minolta Di3010 Copier Logo
165 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
