Question about Sony Cyber-shot DSC-W100 Digital Camera
The lens doesn't open or close properly. I can hear the motor trying to open it. The screen says turn off and on again but I get the same result.
3 Suggested Answers
  • 188 Answers
SOURCE: when turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Posted on Mar 21, 2009
SOURCE: MY CAMERA LENS OPEN CLOSE E READY ACSESS NO
so i charged my battery, and same thing happends. Bought a new battery, didnt chatge it fully, but had one charge bar on it and the same thing is going on??????? ANy suggestions
Posted on Jan 16, 2010
How do I fix lens error problem on the described camera?
hi,
lens error occur normally when it fell or the lens shaken, if so open the camera, take the lens unit out, disassemble the lens unit, then fix it again properly. example below:
(this is not the told model)
Dec 10, 2015 | Nikon Coolpix S3000 Digital Camera
Shutter wont open or close
Hi seems to be a mechanical problem.
Feb 20, 2008 | Panasonic Lumix DMC-FX3 Digital Camera
When turn camera on lens opens and close
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Zoom Error, Lens won't close
There are several causes for this to happen.
1. The lens assy is out of alignment and stuck; stalling the motor.
2. The motor itself is defect
3. If you can hear the motor working , then it will be a stripped plastic gear between motor drive and lens assy.
DIY repair not recommended (possible)
Mar 07, 2009 | Fujitsu Cameras
Lens error, restart camera
i had the the same lens error restart camera problem for almost a month.  If you haven't already, try restarting the camera with the sd1000 in the view pictures setting.  This may allow the lens to retract into position. Next, with the lens extracted, try looking down on the camera from the top to see if the lens is angled downward in any way.  If it is, this means it is jammed into place on one side.  Simply use your fingers to slightly push the lens into proper position.  If you hear a pop, you should be in business! hope this helps!
Jan 22, 2009 | Canon PowerShot SD1000 Digital Camera
Will not show screen
pls try some solutions below
check batteries are they fully charged and supply good power, try replacing them .
check the memory card is it formatted properly try to re format on Laptop card reader, and also check mem card compartment is it closed properly
do u see anything on LCD if not then problem can be big as CCD Failure
does the lens moves and comes out do u hear something
pls check and tell me if u find me helpful
Dec 29, 2008 | Kodak EasyShare CX4230 Digital Camera
Lens does not close anymore -
When you opened it the cog connected to the motor which opens and closes the lens probably shifted and no longer has traction against the ring around the inside of the lens which turns it to open and close it. If you open the camera up again be extremely careful - the lens has loads of springs inside it - lose one of these and it won't work properly. I opened up the whole thing to try and fix my lens which had been jammed in after a friend dropped it. I fixed the lens but couldn't put the damn thing back together again to many tiny parts and no guide to the jigsaw!!
Nov 16, 2008 | Casio EX-Z1050 Digital Camera
"Cover Is Not Open" And The "Lens Cover" Is Open...
the lens cover switch of your camera have a poor contact that why that message is appearing...you have no choice but to disassemble the camera for repairing or cleaning that switch....i suggest you have to go the service center now and don't try open your camera if you are not a technician cause you may damage the flexwire of the lcd monitor if you not properly remove the cover...
Aug 30, 2007 | Sony Handycam DCR-HC21 Mini DV Digital...
Zoom error
I had the same problem with mine and I tried several suggestions, BUT the only one that has worked is to gently grab the lens, pull it out as far as it will go until fully extended. While keeping it extended turn the lens to the right until you hear a click. Once you hear the click, release the lens and turn the power button on and then back off again. This should take care of the problem. A word of warning. ALWAYS make sure your fingers do not touch the front of the lens when you power on the camera. Even the slightest bit of obstruction seems to make the problem reoccur. Another note. I had tried this several times until I finally heard the click, so please don't give up on it, just keep trying. This will work and it will save you a lot of time and money having it fixed.
Dec 09, 2005 | Fuji FinePix E550 Digital Camera
Sony Cyber-shot DSC-W100 Digital Camera Logo
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
