Question about Garden
I have a 14.5 hp briggs and srtatton that idles sweet, starts very easily but when you incraes the throttle over 1/3 it runs ok for about 3-4 seconds then starts to miss and puff black smoke. I tried it withe the air cleaner off to observe the carby at work and noticed that when it begins to miss the fuel straem changes from a mist to large droplets.I have cleaned the carby and the nozzle but the base of the nozzle was damaged slightly trying to get it out. The engine did do this before I damaged the nozzle that why I was trying to get it out for cleaning. Have oerdered a new one but am worried that it may not fix it .Any idea's?
  • 472 Answers
YOU NEED TO PUT A NEW NOZZEL IN IT IF THE OLD ONE IS STUCK THEN YOU HAVE TO DRILL IT OUT AND TAKE A TAP TO IT AND GET IT OUT MAKE SURE YOU CLEAN IT UP GODD AFFTER YOU DO THAT
Posted on Sep 30, 2009
I have a Briggs & Stratton Vanguard 16 HP motor. It idles fine and it runs OK at high RPMS. But it backfires thru the carburetor during accelerating. Any suggestions?
On some float-type carburetors, you can adjust the air-fuel mixture and engine speed at idle. Check for an idle speed screw designed to keep the throttle plate from closing completely, and an idle mixture screw that limits the flow of fuel at idle. If your carburetor contains these screws, proceed below.
  1. With the engine off, remove the air filter and air cartridge.
  2. Locate the idle mixture screw and turn it clockwise until the needle lightly touches the seat. Then, turn the screw counterclockwise 1-1/2 turns.
  3. If your carburetor has a main jet adjustment screw at the base of the float bowl, turn the screw clockwise until you feel it just touch the seat inside the emulsion tube. Then, turn the screw counterclockwise 1 to 1-1/2 turns. Replace the air cleaner assembly and start the engine for final carburetor adjustments.
  4. Run the engine for five minutes at half throttle to bring it to its operating temperature. Then, turn the idle mixture screw slowly clockwise until the engine begins to slow. Turn the screw in the opposite direction until the engine again begins to slow . Finally, turn the screw back to the midpoint.
  5. Using a tachometer to gauge engine speed , set the idle speed screw to bring the engine to 1750 RPM for aluminum-cylinder engine or 1200 RPM for engine with a cast-iron cylinder sleeve.
  6. With the engine running at idle , hold the throttle lever against the idle speed screw to bring the engine speed to "true idle." Then, repeat the idle mixture screw adjustments from Step 4 to fine-tune the mixture .
May 02, 2017 | Briggs & Stratton Briggs Stratton Intek V...
Vanguard V Twin 18 hp. monted in Cushman Motor scooter, runs great at W.O.T and at on quarter throttle, misses at range inbetween
Sounds like your carb needs the fuel/air mix adjusted..uses all the gas at high speed but has excess at low speeds...find your adjusting screw and at med throttle slowly screw it clockwise until the engine starts to sputter then back it out until it starts to sputter again then continue to do this until you reach ideal mix where it runs the best it can..then go slowly through the throttle up and down..when set..unjust your idle speed screw to your ideal idle speed..if this dies not fix ..carb will bed cleaned or rebuilt. Good luck.. Note always push or pull your throttle handle slowly to position avoids gas load up causing sputter and backfire.
Mar 15, 2012 | Briggs & Stratton Briggs Stratton Vanguard...
Ok i have a problem with my Briggs & Stratton 16HP v-twin vanguard engine.When i start the engine and rev it up when i idles back down it sits there and rev's up and down then it straightens out and...
It appears that you have a slight mis-adjustment in the idle speed and idle mixture. To adjust setup, start with at least a half tank of fuel, and have engine at operating temperature (That is warm but not overly Hot). The Briggs & Stratton Website manuals section should show the locations of the adjusting screws if you are not sure of them.
To adjust idle speed set Throttle control to minimum and adjust screw on throttle butterfly to maintain a good idle speed. To adjust idle mixture, screw in idle mixture screw (Lean) until motor falters and then screw out (Rich) until it falters again. Correct setting is the halfway point of these two positions. You may have to re-adjust idle speed again and also the mixture to get best running.
If you are not comfortable doing this, take it to a B & S dealer.
Sep 21, 2010 | Briggs & Stratton Briggs Stratton Vanguard...
Briggs & Straton 20 HP, two cilinder engine idle speed
Surging is usually caused by a lean condition You can try to turn the mixture screw ccw about 1/4 to 1/2 turn. If this does not solve the problem your carb will have to be removed, cleaned thoroughly, and reinstalled.
May 17, 2010 | Briggs & Stratton Briggs Stratton Intek V...
3.5 Briggs with not run at full throttle
same problem, was told it was the jets, are your symptoms as follows
runs at low throttle, will only run at full throttle if fully choked
dies if choke is relieved
Apr 15, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Xterra repair
Since this is an intermittent problem, first try to determine if the problem arises due to one of these many intermittent problems:
* Vehicle vibration
* Heat sensitive
* Freezing
* Water intrusion
* Electrical load
* Cold or hot start up
If you can't isolate the cause of the intermittent problem, you can try adjusting the Idle Speed/Ignition Timing/Idle Mixture Ratio:
Idle Speed/Ignition Timing/Idle Mixture Ratio Adjustment
PREPARATION
1) Make sure that the following parts are in good order.
* Battery
* Ignition system
* Engine oil and coolant levels
* Fuses
* ECM harness connector
* Vacuum hoses
* Air intake system
* (Oil filler cap, oil level gauge, etc.)
* Fuel pressure
* Engine compression
* EGR valve operation (If so equipped)
* Throttle valve
* Evaporative emission system
2) On air conditioner equipped models, checks should be carried out while the air conditioner is OFF.
3) On automatic transmission equipped models, when checking idle rpm, ignition timing and mixture ratio,
checks should be carried out while shift lever is in “N” position.
4) When measuring “CO” percentage, insert probe more than 40 cm (15.7 in) into tail pipe.
5) Turn off headlamps, heater blower, rear defogger.
6) Keep front wheels pointed straight ahead.
7) Make the check after the cooling fan has stopped.
INSPECTION PROCEDURE
1 INSPECTION START
1. Visually check the following:
I Air cleaner clogging
I Hoses and ducts for leaks
I EGR valve operation (If so equipped)
I Electrical connectors
I Gasket
I Throttle valve and throttle position sensor operation
2. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
Ensure engine stays below 1,000 rpm.
3. Open engine hood and run engine at about 2,000 rpm for about 2 minutes under no-load.
4. Perform diagnostic test mode II (Self-diagnostic results).
OK or NG
OK ' GO TO 2.
NG ' 1. Repair or replace components as necessary.
2. GO TO 2.
2 CHECK IGNITION TIMING
1. Run engine at about 2,000 rpm for about 2 minutes under no-load.
2. Rev engine (2,000 to 3,000 rpm) two or three times under no-load, then run engine at idle speed.
3. Turn off engine and disconnect throttle position sensor harness connector.
4. Start and rev engine (2,000 - 3,000 rpm) two or three times under no-load, then run at idle speed.
5. Check ignition timing with a timing light.
15°±2° BTDC (in “P” or “N” position)
OK or NG
OK ' GO TO 4.
NG ' GO TO 3.
3 ADJUST IGNITION TIMING
1. Adjust ignition timing by turning distributor after loosening securing bolts.
2. Turn off engine and connect throttle position sensor harness connector to throttle position sensor.
' GO TO 2.
4 CHECK BASE IDLE SPEED
1. Check idle speed.
700±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 6.
NG ' GO TO 5.
5 ADJUST BASE IDLE SPEED
1. Rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run engine at idle speed.
2. Adjust idle speed by turning idle speed adjusting screw.
' GO TO 6.
6 CHECK TARGET IDLE SPEED
1. Turn off engine and connect throttle position sensor harness connector.
2. Start and rev engine (2,000 to 3,000 rpm) 2 or 3 times under no-load then run at idle speed.
3. Check idle speed.
750±50 rpm (in “P” or “N” position)
OK or NG
OK ' GO TO 9.
NG ' GO TO 7.
7 DETECT MALFUNCTIONING PART
Check the following.
1. Check IACV-AAC valve and replace if necessary.
2. Check IACV-AAC valve harness and repair if necessary.
3. Check ECM function by substituting another known good ECM.
(ECM may be the cause of a problem, but this is rarely the case.)
' GO TO 9.
9 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
2. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
3. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 12.
NG (MIL does not blink.) ' GO TO 17.
NG (MIL blinks less than 5 times.)
' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
10 CHECK FRONT HEATED OXYGEN SENSOR LH SIGNAL
1. Warm engine to normal operating temperature.
2. Run engine at approx. 2000 rpm for approx. 2 minutes under no-load.
3. Set “Left bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
4. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' GO TO 13.
NG ' GO TO 11.
11 DETECT MALFUNCTIONING PART
1. Check fuel pressure regulator.
2. Check mass air flow sensor and its circuit.
3. Check injector and its circuit.
Clean or replace if necessary.
4. Check engine coolant temperature sensor and its circuit.
5. Check ECM function by substituting another known good ECM.
' GO TO 2.
13 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
1. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
2. Make sure that MIL goes on more than 5 times during 10 seconds at 2,000 rpm.
OK or NG
OK ' INSPECTION END
NG (MIL does not blink.) ' GO TO 16.
' 1. Replace front heated oxygen sensor RH.
2. GO TO 14.
14 CHECK FRONT HEATED OXYGEN SENSOR RH SIGNAL
3. Set “Right bank front heated oxygen sensor monitor” in the Diagnostic Test Mode II.
OK or NG
OK ' INSPECTION END
NG ' GO TO 15.
15 DETECT MALFUNCTIONING PART
3. Check injector and its circuit. Clean or replace if necessary.
' GO TO 2.
16 CHECK FRONT HEATED OXYGEN SENSOR RH HARNESS
1. Turn off engine and disconnect battery ground cable.
2. Disconnect ECM harness connector.
3. Disconnect front heated oxygen sensor RH harness connector.
4. Check harness continuity between ECM terminal 50 and front heated oxygen sensor RH harness connector.
Continuity should exist.
OK or NG
OK ' 1. Connect ECM harness connector.
2. GO TO 18.
NG ' 1. Repair or replace harness.
2. GO TO 9.
17 CHECK FRONT HEATED OXYGEN SENSOR LH HARNESS
3. Disconnect front heated oxygen sensor LH harness connector.
4. Check harness continuity between ECM terminal 51 and front heated oxygen sensor LH harness connector.
OK or NG
2. GO TO 18.
2. GO TO 9.
18 PREPARATION FOR “CO” % CHECK
1. Disconnect engine coolant temperature sensor harness connector.
2. Connect a resistor (4.4 kW) between terminals of engine coolant temperature sensor harness connector.
' GO TO 19.
19 CHECK “CO” %
1. Start engine and warm it up until engine coolant temperature indicator points to the middle of gauge.
3. Check “CO” %.
Idle CO: 1.5 - 9%
After checking CO%,
a. Disconnect the resistor from terminals of engine coolant temperature sensor.
b. Connect engine coolant temperature sensor harness connector to engine coolant temperature sensor.
OK or NG
OK ' 1. Replace front heated oxygen sensor LH.
2. GO TO 10.
NG ' GO TO 20.
20 DETECT MALFUNCTIONING PART
1. Connect front heated oxygen sensor harness connectors to front heated oxygen sensors.
2. Check fuel pressure regulator.
3. Check mass air flow sensor and its circuit.
4. Check injector and its circuit.
5. Check engine coolant temperature sensor and its circuit.
6. Check ECM function by substituting another known good ECM.
' GO TO 2.
Aug 17, 2008 | 2000 Nissan Xterra
Garden Logo
54 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
