Question about Karcher Garden
How do i connect the screw to secure the handle on a k7.85 washer
2 Suggested Answers
rick_stokes_
  • 61 Answers
SOURCE: the screw securing the tap handle has sheard off.
Take an electric hand held grinder with either a small carbide burr or grinding bit and grind away the rest of the head of the screw. This should release the handle so you can pull it off and then you should be able to remove the remainder of the screw. If it is a set screw holding the handle, grind the top of the screw flat and use a drill to drill it out.
Posted on Sep 19, 2009
Testimonial: "Thank you very much much for your help, im just going to give it a go now. Tony."
Hi. I inherited a 1998 Husqvarna 265 rx. Got new plug and new fuel and it fires ok. Wouldn't stop so I added a washer under the 'earth' screw and it now stops. Problem is poor acceleration
To set the throttle, start by slackening the cross head screw securing the cable in the handle and pull completly out, now slacked the three allen headed screws securing the handle, twist the handle to the best position for your use ( at full throttle your thumb should not be straining ) now slacken the lower cross head screw and turn the silver clamp to tention the spring underneath, when correctly adjusted the throttle trigger should spring back to the idle position readily, now re fit the cable up through the clamp, turn the cable so as it is just about to open the carb throttle spindle, lock the cross head screw and test to make sure you are getting full throttle, if not slacken the screw and turn cable a little more.
Sep 19, 2012 | Husqvarna 531004054 Throttle Wire
My complaint is about the go diego go toy trike, the screws that hold the handle bars to gather will not stay in ,, the holes are either to big or the screws are to small. do hope to hear answer on this...
1. You can buy a bigger bolt at a hardware store with a nut that fits the bolt and use a washer on both sides of the handle bar. Also, before screwing on the bolt, put teflon tape around the bolt screw where the nut is to go. This should secure the nut from unwinding through use. Make sure the nut is on more than hand tight.
2. If you cannot purchase another bolt, then start with washers and teflon tape. Be sure to tighten the nut more than hand tight using a wrench or pair of pliers.
Mar 07, 2011 | Cycling
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
Dec 31, 2010 | 2002 Jaguar X-Type
Installed new valve but when I screw the handle in I can't shut the water off completely. I can pull and turn the water on but when i push it in, it only turns off part of the way. To shut it off i have to...
On most moen single handle valves there is a washer that is supposed to fit over stem on cartridge.This washer has two flat sides to fit over flats on stem. The only other thing I can think of is that your valve face plate is mounted a little to far out and won't let back of handle go all the way closed. I would try tightening the two screws that secure face plate to valve a little and see if that helps. Good luck. Thanks
Nov 18, 2010 | Moen & One Handle Tub & Shower Faucet
Need to change washer faucet
Probably what you need to do is change the cartridge. You will need a Moen cartridge puller to help with removal and reinstallation. You can get these and the cartridges at most hardware stores. Shut Off Water first, remove set screw that secures handle and carefully remove handle. You may have to tap lightly on rim of handle to free it. There is a retaining clip that holds cartridge in place, it will have a small round hole on top. Carefully remove clip using neddle nose pliers or perhaps ice pick inserted in hole to remove clip.Install puller as per instructions and tighten nut to remove cartridge. Install new cartridge andclip. put handle back on and install screw. I need to back up here and say that screw is normally located under moen insignia in middle of handle. Pry cover off with screw driver or knife blade to access screw. After you have cartridge, retaing clip and handle reinstalled turn water back on and check for leaks. Hope this helps. Thanks.
Nov 11, 2010 | Moen Bathroom Sink Faucet - Single Handle...
Need to remove driver side door panel?
  1. Disconnect the negative battery cable.
  2. If equipped with an accessory switch panel, carefully pry the switch panel up and away from the door panel. Tag and disconnect the switches from the panel.
  3. On 1981-86 models, remove armrest attaching screws.
  4. On 1987-96 models, remove the retainer screws secure the pocket in the molded armrest on the door panel.
  5. If equipped with crank type windows, remove window crank handle with the appropriate clip removal tool.
  6. If equipped with manual remote mirrors, remove the control knob bezel.
  7. Remove inside door handle cover attaching screw and trim plate.
  8. If equipped with door mounted speakers, remove the speaker, and disconnect the speaker wires. For speaker removal and installation steps, refer to .
  9. Remove all external screws securing the door panel. Insert an appropriate prytool between the door panel and door frame to remove the hidden clips securing the panel.
  10. Holding door panel vertical lift straight up to release the upper clip.
  11. Inspect all retaining clips and replace any broken or missing pieces.
To install:
  1. Position the door to the door and carefully press on the retainer clips to engage. If a clip will not engage, inspect the mounting hole behind the panel to make sure the clip is properly aligned. Install any panel-to-door retainer screws.
  2. If equipped with crank windows, attach the washer and crank to the window regulator stud.
  3. On 1981-86 models, attach the armrest to the door using the retainer screws.
  4. On 1987-96 models, insert the armrest pocket and secure in place with retainer screws.
  5. If equipped with door panel mounted speakers, attach the speaker wires to the speaker and secure the assembly to the door panel.
  6. If equipped with remote cable mirrors, attach the control knob to the door panel with the retainer bezel.
  7. If equipped with an ashtray, insert the holder assembly, and secure in place with retainer screws. Install the ashtray to the holder assembly.
  8. Position the door handle trim panel around the door handle assembly, and secure in place with the retainer screw.
  9. If equipped with accessory switch panel, attach the harnesses to the switches, and press the accessory plate into the door panel.
  10. Connect the negative battery cable.
  11. Check and make sure all panel components function correctly.
Apr 03, 2010 | 2002 Ford Explorer Sport Trac
I have an 11 year old, single handle shower control that when turned off has dripping. I have taken off the handle, etc and am at the wall. What is the next step or steps?
After you remove the chrome collar and plastic collar washer (behind the faucet handle), pry the beauty plate off the wall. Turn off the house main water supply. Remove the four screws and washer holding the cartridge and valve stem in place. Save the metal washer under the four screws for use with the new cartridge. Replace the stem/cartridge assembly and secure with the saved metal washer and four screws. Reinstall beauty plate, collar & collar washer, then handle.
Dec 21, 2009 | Price Pfister R89-7PC0 Chrome Portland...
Trying to take off non electric door panel
PLEASE DON'T FORGET TO RATE!!!!
Remove the screw from the armrest cup. A magnetic screwdriver is helpful here
Slide a rag between the panel and handle ...
... to dislodge the retaining clip
The handle can now be pulled from the regulator
Remove the screw securing the door handle cover then pull it away ...
... enough to release the lock rod
Remove any screws securing the door panel ...
... then pull the panel away...
... and unplug any electrical connections
The panel can now be removed from the door
Oct 28, 2009 | 1995 Mazda Protege
The screw securing the tap handle has sheard off. how can i remove it to get to the washer?
Sep 18, 2009 | Home
Water leaks where the hose connects to the trigger handle.
Be sure to get a good washer on with the connection. They're easy to buy at any hardware store. You can also put white plumbing tape around the threads before screwing them in to make it really fit.
Sep 28, 2008 | Bissell 1631 PowerSteamer ProHeat Canister...
Garden Logo
22 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
