Question about Baumatic 24 in. B40 Gas Cooktop
Baumatic B40 Gas Hob : Gas not staying on.
When Lighting the hob the gas ignites but will not stay lit when releasing the ignitor, One ring has failed and another is getting intermittent, have used this hob for about 8 weeks.
  • topbud Sep 24, 2008
    Same probleme as above replaced the ring and still have it it is a manufacture issue. Will go to watch dog. I am sick of beeing con.
    New Friend:
Have the same problem with two hobs and one of them is baumatic and i solved the problem, it isnt a manufacture problem but indeed its dirt problem, next the ignition there is a heat sensor that works on magnetic source you should clean the very top of it with a knife by passing it you should remove the black dirt and then brush it with a t
Posted on Sep 14, 2013
We have the same problem... try removing the knob, ours works fine without the knobs ????
Posted on Nov 19, 2010
I have a hover gas hob one-off the back burners sparks and light the gas butter gas will not say on
Posted on Jul 29, 2018
    Habit-Forming:
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
Symptom is as above. I have a Siemens two burner top by Schott Ceran. Both are intermittent, and fails most of the time. They will usually keep lit if I try about ten times, and if I turn it off again once it has stared working, it will light normally if I try again. If I let it cool for a minute it will start troubling again. The thermocouple next to the igniter is clean (cleaned it with a knife), so I guess they are OK, although they can get faulty, but saw another post of someone replacing the thermocouple with no effect.
Then I tried the advice above on pulling off the knobs. And now it works... And I put the knobs back on, and it fails again! And it is reproducable every time!?! Very strange, yet delightful insight. Dismantling the thing tomorrow.
Posted on Jul 06, 2016
I have a Neff 5 burner hob. The middle burner will not stay lit. A small amount of gas runs around the grey gas dispenser while trying to light the hob with the igniter depressed. It then fizzles out...
Some gas appliances have a thermal couple. it could be dirty at its base connection. If possible clean that area with alcohol
always unplug electricity before attempting to repair on any electrical appliance .
Sep 08, 2017 | Neff Cooktops
The ignitor on my AEG gas hob keeps firing. I have not spilt anything on it.
Take the switch buttons off and use a hairdryer to blow dirt out and dry up any damp. Also make sure buttons go up and down cleanly.
Mar 03, 2011 | Baumatic 27 in. B67 Gas Cooktop
Neff gas hob on T2124 not lightin when turning on ignition.
make sure you have gas to the hob then make sure all the rings are clean and not blocked and that the ignition electrodes are clean
Dec 09, 2010 | Neff 22 in. T2124 Gas Cooktop
Electric ignition to hob seems to be jammed
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
http://www.fixya.com/support/r4033033-gas_range_repair_burners_keep_clicking
heatman101
May 31, 2010 | Cooktops
Gas hob ignition firing, won't stop
not a solution I'm afraid - I'm having the same problem. How did you manage to fix it?
May 11, 2010 | Baumatic 27 in. B67 Gas Cooktop
My baumatic hob keeps sparking for no reason! i was cleaning it and now they keep sparking and i dont know what to do! also, is it dangerous, will gas be leaking?
No. You have some moisture around your igniters. They will stop eventually or you can use a hair dryer to help them along.
Jan 31, 2010 | Baumatic 23 in. BT62 Gas Cooktop
Miele KM 320 G gas cooktop ignitor
I had a similar problem and discovered that the control knob had fried itself, most likely due to liquid penetration down the shaft of the control knob and into the control knob electronics. Inside is a printed circuit board with resistor, diode and a rheostat. The surface of the board was charred beyond repair.
To trouble shoot the problem, open the cook top and hook the burner in question to one of the known good control knobs. If it ignites, then it is the control knob electronics. If it doesn’t, then there is something wrong with the igniter.
Note: The 2-zone Wok Burner had a different control knob that the other burners.
To open the cook top, do NOT loosen any of the Phillips screws on the sides. Here are the instructions from the user manual:
Disassembly
Shut off gas supply, disconnect the manifold pipe, disconnect the electrical power. Remove pan supports, burner heads and burner rings. Remove control knobs.
In the event that the hob is built in, undo the bracket clamps underneath the work surface. Lift the hob on to the work surface. Unscrew the venturis on the high-speed and super high-speed burners using a 20 mm wrench. Lift and remove the burner rings and burner base plates. Disconnect the wires from the ignition plugs. Keep the wire from dropping into the undertray by inserting it in one of the slots in the burner supports.
Remove the three screws securing the dual ring wok burner. Remove the wok burner base plate. Lift the ceramic tray from the hob.
Note: Each regulator shaft is equipped with a black ring. This ring may cling to the rubber seal in the ceramic tray. Check and remove the rings from the rubber seals.
To order parts, call 1-800-245-8215, 8:30 AM to 5:00 PM EST
Mar 04, 2009 | Miele 35 in. KM326G Gas Cooktop
Gaggenau kg260 gas hob, ring not staying lit, possible thermo-couple gone, request replacement cost / parts please
Thats the Stainless Steel model KG260-234CA with SuperQuick electric and Safety Thermocouple ignition, I think they come in pairs RS and LS, for around $27.00 per Pair + tax and SH.
The best place to get them will be SEARS PARTS DIRECT on Line at: http://www.searspartsdirect.com/
Eddie Rentas
Tupper Lake NY.
Jun 25, 2008 | Gaggenau 23 in. KG 260 Gas Cooktop
SPV577x Hob
i think there is a problem with the mercury fillament. there is a mercury filled nipple next to the flame, if this cools down and the mercury contracts the gas shuts off. this is to prevent the gas from flowing if the flame isn't lit. i have the same problem myself as well as one of the ignitions doesn't work. i beleive the cooker hood will hinge up giving access to the parts beneath althoguh i'm not sure what to do when i get under there, i'm pretty sure this is how to go about it. hope this helps
Feb 19, 2008 | Smeg 27 in. SPV577X.1 Gas Cooktop
Baumatic 24 in. B40 Gas Cooktop Logo
2,387 people viewed this question
Top Baumatic Cooktops Experts
Marvin
Marvin
Paul Carew
Are you a Baumatic Cooktop Expert? Answer questions, earn points and help others
