Samsung clp 315 colour lazer printer. Paper feed problem, rollers refuse to pick up paper and load it into the printer
  • 68 Answers
Pull out the paper tray and clean the feed rollers with alcohol or water
Posted on Oct 04, 2009
Paper not feeding
Try replacing the pickup rollers
Jun 17, 2010 | Samsung CLP 300 Laser Printer
My Samsung 310 printer is giving a paper jam message inside warning when I turn the printer on and yet there is no paper jammed inside. Cannot print. Been working fine before. Mayb 100-150 pages printed...
Chek paper size (A4, letter...etc)in driver options and compare it whit your file settings (fo example - you trying to print something whit paper size A4 but printer expect letter format...etc)
Clean paper feed roller
Apr 08, 2010 | Samsung CLP 315 Laser Printer
Samsung 315 Color laser printer acts like it's going to print, but doesn't feed paper. No paper jam...
Sounds like you have a roller turned glossy.
Open your paper feeder drawer and locate the pickup roller. It's rubber, or like rubber and will either be glossy or a little dirty. Now take a light bristle toothbrush and clean the roller with alcohol, remembering to roll it as you clean. Allow to set dry for 20 minutes and try again.
Mar 07, 2010 | Samsung CLP 315 Laser Printer
Samsung clp 300 paper jams after feeding about 5cm. Tried more paper, less paper, printing black only, printing colour, no change. Help
Clean up the Pick Up Rubber.
When you are able to get the Pick Up Rubber out of the maschine rotate it 180 degrees an reinstall it. then the problem would be fixed.
Oct 14, 2009 | Samsung CLP 300 Laser Printer
While this machine worked fine for about 9 months, it now grabs 8 or 10 sheets of paper at a time. I can't find any kind of paper thickness adjustment, either on the machine or in the documentation. Any...
You might see if you can locate the rollers which pick up the paper and clean them with a soft, lint-free cloth and plain water. They get worn smooth and after a while won't pick up the paper properly, just like ink-jet printer.s
Oct 14, 2009 | Samsung CLP 315 Laser Printer
Samsung CLP-300 picking up too many pages
Hi
Thanks for using FixYa. Paper jam is a very common problem with the printers.
First of all clean off the rubber piece that pulls the paper into the printer from the tray with rubbing alcohol, and also take a knife to the rubber piece to rough it up to create more traction.
To clear the paper jam problem you need to remove the back roller mechanism to get at paper. If still the problem persists, then check the following to resolve the issue--
1. Please check all interlocks, electrical and signal connections are seated properly.
2. Front cover, back cover and lid are closed properly.
3. Power plug and USB cable are connected.
4. Printer is turned on with switch on the back.
5. Toner signal lights sequenced, with yellow overall led on.
6. There is some noise of paper roller movement.
7. Toner signal lights all out, overall status light turned to red
8. No visible paper in paper tray or anywhere else.
9. No paper in tray---added paper
10. Waste toner container is full or not installed ---empty, installed properly.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 16, 2009 | Samsung CLP 300 Laser Printer
Not feeding paper properly
if in australia contact Laserfast.Your printer pickup arm assy requires changing.
Jun 21, 2009 | Samsung CLP 300 Laser Printer
Samsung CLP-300 paper feed
Clean the feed roller.
Remove the paper tray, from the bottom there is a grey rubber semi wheel in the middle front of where the paper tray would be. Use a cloth with WD-40, brake cleaner, or lighter fluid to lightly wipe the rubber clean. Put the paper tray back in and it should print.
Jan 24, 2009 | Samsung CLP 300 Laser Printer
225 people viewed this question
k24674
