Question about Sony KP-53V80 53" Rear Projection Television
No sound with with sat but have sound with dvd
I can ont get sound back when using salettelite but have sound with dvd. i think it has something with remote
  • 647 Answers
First unplug the DVD and plug the satellite in the place where the dvd was. if you get sound the problem is with that particular TV input or the wiring if you get no sound the problem is with satellite. Check the sub volume for the Satellite or call satellite provider for assistance
Posted on Sep 30, 2009
No audio after recording from sat. Reciever
Double-check your input cables from the receiver to the LG 389. Do you have the sat. receiver AV out connected to the front AV In on the LG DRT389? Make sure that you haven't mixed up the L and R audio connections on either side. (I've done something similar with RCA cables myself.) Next, try a different set of cables.
If that doesn't work, there may be a problem with the audio jacks on either your receiver or the 389. To check, plug the AV cables from the Sat. Receiver directly into the TV. If you have sound and video, then the input jacks on the recorder may be damaged.
Try using another input. (It looks like some models have the SCART input; you may need to set the input source in the menu under AV2 Decoder.)
The fact that you have audio output on USB and DVD's means that cables/connections between the LG289 and the TV are fine.
I hope this helps. Please add a comment with the details of which AV port you are using on the LG389 for additional assistance.
Aug 31, 2012 | LG DR389 MULTISYSTEM DVD RECORDER FOR...
Sharp Aquos LC 37D6U
If you use analog signal or play a dvd or vcr do you get sound?
Jan 31, 2008 | Sharp LC-32D4U 32 in. HD-Ready LCD...
Cant get coaxel wire to give me sound
You need the remote to turn the coax input on or off and assign it to SAT, DVD, CD, or MD/ TAPE 1.
Press the receiver button on the remote then use the < > buttons 'till coax appears in the display. The up-down or center cursour buttons should turn it on-off, and I think the < > buttons assign coax in to the source you want to use it with. You wound naturally want to assign it to the same source as the video signal if it coming from a dvd player or sat receiver.
Jan 09, 2010 | Pioneer VSX-D508
Can only get the dvd player to use the surrond system
This is going to be a bit tricky with this model, since either your Cable or Sat box will need a Digital Audio Out, and you will need to purchase a Digital Audio cable. If your sat box has a digital audio out, connect a digital audio cable from the sat box to the digital audio in on the back of the Samsung. Then connect a red and white AV composite cable from an available audio out on the back of the cable box to the "Aux In 2" on the back of the Samsung - this may only allow stereo sound, however.
Your absolute best bet (and the simplest connection) will depend on whether your TV has a SPDIF OUT or Digital Audio Out (they are roughly the same). If your TV has a Digital Audio out, connect a digital audio cable from the TV to the Digital Audio IN of the Samsung. Now you will get sound from any cable, sat, or any other type of box that is connected to your TV.
-Tha Mp3 Doctor
Dec 25, 2008 | Samsung 1200W 5.1-Ch. XM-Ready Home...
HAD TV SET UP ON SOUND SURROUND TOOK OFF NOW HAVE NO SOUND ON TV BUT HAVE SOUND FROM TV WHEN DVD PLAYS
I found out how to retrieve plug & play and put TV back to defaults.
Hope this helps others.
KC-Oshawa, Ont.
Aug 26, 2008 | Televison & Video
DVD player
well on mine, I have to turn off the sat. radio before the kids can watch dvd and I can only listen to radio or cd while they watching dvd. I don't even know if you are able to listen to dvd through them speakers, because it came with headsets. I know I am not big help, but I think you have to change something on the front radio. If nobody else can answer your question, than I will look tomorrow to see how I turn on my dvd player and tell you what I have to push.
Sorry
Tanya
Jul 06, 2008 | 2004 Ford Expedition
No sound
Go in to the menu for the sound setup. Make sure that the sound is not on MUTE, or SAP. Make sure that the speakers of the TV are in the ON mode, or any sound system that the set feeds is setup okay for the TV.
It is possible by coincidense that something in the audio section of the set has failed.
All of this has nothing to do with sitting on a remote control...!!!
Jerry G.
Apr 29, 2008 | Proscan PS32500 32" TV
Operating a SONY DVD player with RCA TV
The only thing I can think of is that you have the input option on the wrong input. Have you tried pushing the input button or TV/Video button? I hope it helps...
Feb 23, 2008 | RCA F27664 27" TV
Hooking up video
I am assuming that you are using a surround sound system?If so on the back of the satellite receiver you will have RCA cables labled yellow ,red,white uuse an rca cable to run from the output on the back of the sat box to an rca input on the surround sound unit.the inputs should be labled on the back of the surround sound unit.once you have the sat box plugged in look for the output on the surround sound (rca cables) run one set of rca cables to the rca cable input of the Tv.on the original tv remote select the tv input that is the cable from the surround sound is plugged in to . make sure the surround sound unit input is selected to the input that the sat box is plugged into.this will give you surround sound from your satellite receiver,repeat with your DVD player plugging the DVD rca cable output to another empty input on the surround sound.to switch between the sat box (satellite TV) to DvD select another input on the surround sound unit.Try to correspond the units you are plugging into the surround sound to the correct name of the component on the back of the surround sound unit to avoid confussion.any questions,Im here to help.If this works rate me FIXYA! if it helps.GOOD LUCK!
Nov 18, 2007 | Panasonic SC-HT40 System
My DVD player does not charge!
I think you mean the "charge/power" light doesn't come on? One thing I've noticed on the PD-758LP I have, is that the power connector on the back of the player is none too good, my DVD player quits if the cable isn't set just...right... Try moving the power cable around on the back and see if it lights-up briefly. I suspect problems with that connector first.
Jan 14, 2007 | Protron PD-758LP
Sony KP-53V80 53" Rear Projection Television Logo
60 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
