Question about Car Audio & Video
I am after the radio code for my hyundai terracan without having to take it to dealer . It is a05/2005 model 2.9 turbo diesel
  • BNJ06 Apr 26, 2011
    I am after the radio code for my hyundai terracan I think the serial number is H001048.
  • 4,848 Answers
First make sure that the code has not been noted somewhere within the car (underneath the ash tray, glove box , rear of sun visor etc)
To see if your code is available here for free then the radio will have to be removed from the dashboard (and if you are lucky, someone may have written the code on the casing ) .
Free removal instructions here www.fitaudio.com
If not then POST ANOTHER QUESTION
quoting the radio MAKE+MODEL plus ALL the LETTERS+NUMBERS on ANY LABELS ,BARCODES or STAMPED IN THE METAL CASING
note: Unfortunately not all radios can be decoded using the Serial Number
If not then try your Main Dealer ...........or take it into a Decode Service who will plug in a laptop to read/recode the memory chip (EEPROM). This takes a few minutes and shouldn`t be too expensive
Posted on Sep 30, 2009
My 2006 terracan diesel 2.5 won't start battery is good fuel filter is new
Check for 12V on the horn feed wire while someone tries to sound it, if it's there, replace the horn
Feb 05, 2016 | 2006 Hyundai Terracan 2.9
My Terracan normally starts on the 2 nd turn of the engine. All of a sudden the engine just turned without starting at all. I waited till the next morning and tried again. It start immediately. I let it...
That code would have been "camshaft position sensor". They may have replaced the old one with a faulty new one, which might account for the blown fuses. Have them try unplugging it to see if it stops blowing fuses. If it does... have them replace that sensor again with another new one.
The replacement they used MIGHT not have even been NEW - it might have been salvaged from another vehicle... or they might have used the wrong one for your Terracan. How much do you trust that shop? You might have the Terracan towed to a different shop if you're not pretty confident about their competence.
Aug 04, 2014 | 2005 Hyundai Terracan 2.9
How to find radio code to a hyundai terrcan 2004
normaly they put it in two places,first is on the back of the radio casing and the alternative is in the ownersmanual
Jul 23, 2014 | Hyundai Terracan Cars & Trucks
My Terracan 2007 loses power going uphill
would need to get the OBD codes read as could be a number of things , worst case scenario the head gasket has blown or may be as simple as needing fuel filter changed , the OBD code will pinpoint the sensor/switch at fault and will save you time and money diagnosing the exact, cause keep me posted
May 22, 2014 | 2007 Hyundai Terracan 3.5
How do you fix Hyundai Terracan 2002 model with error code P1728 - EMC open/short to battery?
There is a factory repair bulletin for this code, we do not have access to it, only the dealer does at this time.
Apr 06, 2012 | Cars & Trucks
2004 Hyundai Terracan, 2.5 turbo diesel, manual. Will not start cold. Once I get it started, it runs and starts perfectly, with some heat on the engine. Error Code P0110, I replaced the air intake...
right renew the glow plug timer/relay if you put a meter on the glow plugs when cold and turn ign on (with help) it should supply power for a about 20 secs ,time depends on outside air temperature ,if all else fails then do a colin --- use a push button switch,wired to a relay so glow plugs can be operated by pushing the switch which you will mount on the dash ,cant beat a manual overide system
Dec 14, 2009 | 2004 Hyundai XG350
Radio code for a 13 year old Ghia.
call the dealer and give them the serial number of the radio they will give it to you
May 08, 2009 | Car Audio & Video
Tectaloy extra cool 2000
http://www.tectaloy.com/images/documents/Tecinfo%20Book4.pdf
This is there own spec manual , However as a general rule most automotive grade antifreeze works fine in diesels. Your own owners manual will tell you if there is one kind you shouldnt use.
Dec 12, 2008 | 1999 Hyundai Accent
05 Hyundai Terracan transmission temp ecu code
I'm having a hard time to fine that code, but I'm still looking.
Cheer
Aug 30, 2008 | 2005 Hyundai Tiburon
Car Audio & Video Logo
531 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
