Question about Compaq Presario R3000 Notebook
Won't boot up
My laptop will not boot up. All I get is the Compaq page. None of the keys will work, so I can't do anything. Just returned from a trip with my laptop and it worked perfectly. Came home, plugged it in and nothing works. Hope someone can help.
  • horonym Dec 21, 2007
    I have the same problem. I've tried all options , , plus some. The system will not respond to any key strokes at boot so you can't change boot options or enter BIOS to reconfigure. Have reseated all cables to include keyboard and still no response. Have even removed BIOS battery to try and force the BIOS to reset. Still locks on Compaq screen.
  • Rico Fault
    Rico Fault Nov 02, 2008
    Same problem. Turn on the Compaq laptop and all i get is ESC for selecting BOOT SEQUENCE or F10 for SETUP (neither will do anything). Once in a while hitting F10 will change the screen to F! CONTINUE F10 SETUP but that as far it will ever go. If I take out the memory it will complain (as expected). An whenever I use either of the 2 SIMMs I get the exact same result. I taken the drive out and same results.
    Please no suggestions to go to safe mode (the laptop does not get that far). I can not even get to SETUP.
    Anything that could make this happened? If the drive is bad (or not there) will it prevent it from going to setup?
  • 41 Answers
Press F8 while your computer starts up then and then use the safe mode to start your computer in then once it starts you can do a ststem retore just follow the instructions on the screen once it starts it will give you the option to start your computer in safe mode just click yes, try that
Posted on Dec 19, 2007
Need boot up system disk for a laptop compaq presario 2227US
When you try to boot up, press Function key F12 a few times. Sometimes that boots you up into a recovery mode, where you can fix your computer to work normally again with an options menu. If that does not work, you may also find someone else with a recovery disk for the same model or even manufacturer. Sometimes any recovery disk works, but you will not be able to recover anything unless it is your manufacturers. Lastly, you may acquire software downloaded on another computer called " Spotmau Boot Suite 2012" . It is about 30 dollars. Be sure to make a boot disk when it has booted up so you are not in the same position the next time.
Jan 28, 2014 | Compaq Presario 2227US Laptop Universal AC...
Laptop won't boot - Compaq
Do you see anything on the screen? Does the HDD LED blink? You can start by removing the HDD and testing it or have it tested.
Jun 06, 2013 | Compaq Computers & Internet
Cannot Access the BIOS of my Compaq nx8220. I have pressed every button imaginable on the keyboard during boot up but nothing works. only f10 lets me get to what looks like a bios but i cannot edit...
You have already found that the 'F10' key is the correct key to enter BIOS SETUP.
> cannot edit anythig, or set boot preferences
You should be able to do the above, if you have entered the correct password.
Please explain.
Jul 06, 2011 | HP Compaq nx8220 Notebook
None of the keys work on hp logo screen F10, f11. f9. esc system won't boot from hard drive or cd
are you using a usb keyboard? A lot of systems require a ps/2 (purple round connector) keyboard to access the bios settings and anything on the startup screen unless you have set usb on boot in the bios settings. I would try connecting a ps/2 keyboard and see if it helps.
May 06, 2011 | HEWLETT-PACKARD Pavilion Desktop with AMD...
Hp 6735s was used last night and shut down properly but this morning turning it on the system continue booting without displaying anything on the screen which makes it blank / black........ Please I need...
If there is a display switch in the functions on the keyboard (most likely will look like a laptop monitor or a computer monitor on the keyboard). Press the function key and the button associated with that and wait 3 to 4 seconds (you may have to press it multiple times) If you have anything in the vga slot, then it may think a monitor is plugged in and won't display the laptop screen.
If none of the above work, then maybe your computer is having a systematic failure, or the screen connector is loose.
Jun 14, 2010 | HP Compaq 6735s Notebook
Compaq Presario Laptop 2700 bios
you've got a corrupted file most likely,
but thus your computer managed to boot up before this thing show up on screen?
If yes try to go to safe mode by pressing F8 before it boots up then go to recovery or restore setting to earlier time before this thing happen.
If it does able to boot up after pressing the power then you'll have no choice but to reformat your hard drive, you can do this if you have other computer where you can attach your hardrive, but if none, much be better to bring it to service center
Oct 31, 2009 | Compaq Presario 2700 Notebook
I need to master reset my compaq presario v2000
I have to assume you mean you Windows to become the way it was originally? If you have XP then put in the XP disk boot from it, press Enter when the system ask if you want to install Windows. Press F8 when the legal page comes up and then on the next page it should ask if you want to repair your system. Press R. If the repair option does not appear then press F3 to exit.
If you have Vista - it only has a boot repair option
If none of these apply then you'll have to do a total reinstall. You do have the Office suite on CD with your own key?
Mar 23, 2009 | HP Compaq Presario V2000 Notebook
I have a Compaq labtop and when I turn it on, it remains on the Black Microsoft corporation page and won't progress any further. It's not even a year old yet. i can't log on or do anything. Please help!
This should be under PC Laptops, not desktops.
Start the laptop up. As soon as it starts, keep hitting the F8 key until you get a list of options that includes 'boot in safe mode'.
Try to boot in safe mode and let me know what happens.
Aug 29, 2008 | Compaq Computers & Internet
Compaq Presario R3000 Notebook Logo
101 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
