Question about Maytag Washing Machines
The washer seems to be out of balance. What can I do to fix this?
    Brigadier General:
  • 3,513 Answers
Hi
Please follow these easy steps for your problem...
Step 1
Find out the reason for the shaking during the spin cycle. The cause will usually be either a badly out of balance load, or a poorly leveled and set up machine.
•Balance the load of clothes by opening the lid, and looking to see if there is a lot more on one side of the agitator than the other, and if this is the problem, move them around, close the lid, restart the spin cycle, and observe the results. You may try repositioning the clothes in the tub slightly more if you original efforts helped significantly.
Step 2
Try to tip or tilt the machine. If it wobbles when you do, the adjustment screws on the machine's base may not be set correctly, or on older machines, the threads may be stripped or corroded out, causing them to fail.
Step 3
Relevel your machine and insure it is supported correctly. This is done by kneeling down in front of the machine, and rocking it to see which corner seems to be floating, or not in contact with the floor. The leveling screw should be screwed out (clockwise, if viewed from above), which lengthens it, or the adjacent side should be screwed in (shortened), so that each leveler is in contact with the floor.
Step 4
Use a pair of pliers if the thumbscrews are too tight to turn with your fingers, and spraying the screws with a lubricant may help, also.
Step 5
Restart your machine when you have made sure all the leveling screws are in contact with the floor.
Step 6
Use shims to support the machine if the screws have become unusable for some reason (broken, stripped, or otherwise damaged). Shims can be made of almost any resilent, non-degradable material which can be cut easily, like scrap vinyl composition tile, rubber matting, or even plastic margarine container lids.
Step 7
Cut a number of shims, about 3 or 4 inches in width, and stack them under each corner where they are needed, until the corners are equally supported.
Step 8
Restart the machine and observe your results.
please note...
•Worn drive assembly parts may also cause vibration in older washing machines, in which event, these steps will not correct the problem.
•Washing machines should be set up level to operate correctly, so using a small torpedo, carpenter's spirit level, or other means of accomplishing this will help.
•Unload any contents from the machine before working on it if possible, to decrease the weight of it.
•Before tilting the machine, check the water supply hoses, the discharge hose, and the power cord to make sure there is enough slack to prevent damage.
•Get someone to hold the machine up, or find something to chock it with while adjusting screws.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
Out of balance switch will not stop washer when load becomes out of balance.
Your switch is bad. You don't necessarily need the switch. Snip the wires off either side of the switch and fuse them together with a wire connector.
May 06, 2012 | Maytag Atlantis MAV6000 Top Load Washer
Drum seems broen and off balance
if it is washer, most likely need spring kit they look like shocks that the tub sets on
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
Top loader Maytag washer cannot balance load
The shock absorbers that hold the tank are broken. Then the load will move the washer all over the place.
Look online for an exploded diagram and order the new shocks for it
Nov 12, 2009 | Dryers
We can't seem to balance our washer barrel with or without a load. it spins out of balance. all springs are good.
Is the washer itself balanced? Have you tried adjusting the adjustable "leg" screws on the bottom of the washer?
Aug 16, 2009 | Washing Machines
Washer constantly goes out of balance
1 option is to wind the back feet out so the washer drum will sit more to the front so as it less likly to hit the OOB switch, other thing is that the OOB switch might have corrosion on the inside of it and in this case if it gets moisture inside it during a wash it is more likely to go OOB, so try replacing it this should fix issue, if not replace Motor Control Unit. :)
Feb 23, 2009 | Fisher and Paykel GWL11 Top Load Washer
Whirpool Washer, Loads become unbalaced in spin cycle.
it has a bad balance ring on the top of the basket no so hard but not that easy either
you have to remove the case to get to the balance ring
go to www.sears.com and go to parts and put in the full model number, under the parts tab in appliances and select view brakedown and it will explain it better with you seeing it
May 08, 2008 | Whirlpool LSR5132PQ Top Load Washer
Out of balance spinning.
there is a spring that hooks to the back the tub of the washer and conects to the frame of the washer its there as a counter balance. if that spring was not put back in place the washer will shake like crazy. if that spring is conected the basket is warped
Nov 17, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Washing Machines Logo
125 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
