Question about Panasonic Televison & Video
This 2005 PT 50DL54 after 2 hrs fan kicks on. After3-4 fan kicks in a louder turbo speed. I have seen "tiles " or a momentary freeze of picture. The fan calms down everything is fine. What is breaking down?
  • Panasonic Master
  • 19,396 Answers
This TV has two filter panels at his sides. The panels get clogged with dust, and that causes overheating.
The filter panels look like speakers and are held by screws. They are located at each side of the TV. After undoing the screws the panels must be removed and cleaned, using an apposite cloth and a small hoover. The filters are located behind filter panels.
If that does not fix the problem then either one of the internal fans is faulty, or one of the termic sensors located on board at the base of the fan is faulty.
The repair job must be done by a technician to avoid damaging the TV.
Here the fans, filters do not need replacement , and temp sensor is usually not fixed at component level.
FBA06A12HS
FBL12G12LS
Let me know if you have more questions. Please do not forget to leave feedback later.
Thanks.
G.
Posted on Sep 30, 2009
Where is the fuse for the fan located
I presume that you're talking about the engine fan, right? It is under the bonnet. You have to remove the airbox and it's right there.
This link may help you to find the one...
how to fix p0480 when fans work 03 pt cruiser gt turbo 5 speed
Jul 15, 2014 | 2002 Chrysler PT Cruiser
BMW 318 transmission
bmw have twin turbo
when move from first to second could be possible
check engine and gear box oil
Apr 23, 2014 | BMW 318 Cars & Trucks
Blown turbo 2005 Chrysler PT Cruiser
indicates a turbo failure
remove it and have it overhauled/inspected
Oct 18, 2017 | 2005 Chrysler PT Cruiser
Engine light came on and car is over heating. Took it to auto zone and was told it's the fan relay. Its a 2003 PT Cruiser, Turbo. I opened the fuse box under hood. There are 3 spots for relays in there...
Turbo Radiator Fan
The radiator cooling fan is a variable speed electric motor driven fan. The radiator fan assembly includes an electric motor, fan blade, and a support shroud that is attached to the radiator. The radiator fan is serviced as an assembly (fan motor/fan/shroud).
The variable speed radiator fan is controlled by the Powertrain Control Module (PCM) by way of a Pulse Width Modulated (PWM) signal. The duty cycle ranges from 30% for low speed operation then ramps-up to 100% for high-speed operation. This fan control system provides infinitely variable fan speeds, allowing for improved fan noise, A/C performance, better engine cooling, and additional vehicle power.
To control radiator fan operation, the PCM looks at inputs from:
Engine coolant temperature
A/C pressure transducer
Ambient temperature
Vehicle speed
Transmission oil temperature (automatic transmission only
HENCE CHECK THE PCM
Jun 26, 2011 | 2003 Chrysler PT Cruiser
Problem with 2005 pt turbo
your turbo is making a banging noise its more then likely pooched
Aug 23, 2017 | 2005 Chrysler PT Cruiser
I need a schematic diagram for the radiator fan on a 2.4 liter 2006 PT Cruiser Turbo
I dont have a diagram, but these have 2 speeds and they are a common problem. the fan will need to be replaced (complete unit)
Oct 03, 2009 | 2006 Chrysler PT Cruiser
2005 PT Cruiser leak anti-freeze leak????
the overflow bottle probobly has a crack in the seam of the bottle.you can replace the bottle or remove it and use some epoxy to repair it.
Jul 29, 2009 | 2004 Chrysler PT Cruiser
Keeps switching back to outside air from recirculating on my ac
No obvious reason for this behavior, so it is likely the control head is failing. You may be able to get a used one at a salvage yard.
Oct 27, 2017 | 2005 Chevrolet Malibu
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
