Question about Kenmore Dryers
Wont dry clothes - Kenmore Dryers
  • 770 Answers
If your dryer is properly heating up, then the fan is not expelling the "humid" air from the tub. Possible problems, the fan has stopped working, more probable problem, your dryer vent or vent hose is clogged or has a low place that has collected moisture.
Posted on Sep 30, 2009
My cabrio dryer wont heat up to dry clothes it does everythging else but dry
The heating coil is most likely burned out. Since you did not post the make and model that is all I can tell you
Mar 16, 2018 | Dryers
The dryer wont heat up the clothes dont get dry everything eles works on it the drum turns ok the timer works also it just wont dry the clothes
Hello,Sam
The usual reason a dryer will heat yet not dry the clothes is going to be a air flow problem. What ya need to check is for a blocked vent and or lint build up in the blower assambly.
By far though a leading cause of that on Maytag dryers is a broken blower wheel and therefore no warm air is being drawnthrough the clothes,to check that remove the front panel and the front drum support and in the lower left corner will be the blower asm. check to see if it moves free and doesnt seem to be attached to the motor shaft.
GENE
Sep 20, 2011 | Maytag MED5770TQ Electric Commercial Dryer
Dryer pauses several times and takes 6 hours or more to dry it does not heat.
so it is drying clothes but is taking forever:
http://www.applianceaid.com/dryertip.html
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
so the dryer is not heating:
http://www.partselect.com/dryer+dryer-wont-heat+repair.htm
these should fix the problem Good Luck Tim
Feb 19, 2011 | Danby DCD5505W Electric Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
the drying twice is a venting issue:
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
Engine got wet and wont start
Find the distributor cap and pull it off. Wipe it out with a dry rag/cloth. Dry the rotor and beneath also with a cloth.
Most likely have moisture in that area killing the spark.
It may start now, if it's dried.
No biggy :-)
Dec 25, 2009 | 2006 Toyota Sienna
Maytag gas dryer wont turn off when done drying in auto dry regular fabrics. does turn off in air fluff and auto dry perm. press. model # d3382
auto dry relies on a moisture sensor to say when its done. so your clothes arent dry enough according to sensor. perm. press. doesnt dry the clothes as much
Aug 01, 2009 | Dryers
Dryer gets hot but wont dry clothes
Do you know if the dryer vent is free of obstructions?Check outside where the dryer vents outside ,and see if the air is weak or flowing freely.If it is not clogged the air should be pretty strong from the vent outside.If it has blockage it will definitly take longer to dry your clothes.
May 17, 2009 | Roper RGX4634KQ Gas Dryer
Wont dry clothes
you need to clean out wall vent and dryer vent,thats your problem-mike
Nov 30, 2008 | Whirlpool Dryers
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
