Question about Cycling
My bike has 21 gears the new wheel only has 18 gears w ill the bike work
  • 1,986 Answers
Yes it will. You will have to adjust the gear shift cable so that it doesn't go past the 6th gear on the wheel (as you would've had a 7th gear) otherwise your chain will constantly slip off the wheel and jam up
Posted on Sep 30, 2009
How can we keep the rear wheel from coming off of the drive shaft?
Lil' Rider Black 80-Kb901K Fx Wheel Repair Questions ...
www.fixya.com/.../p13170224-lil_rider_black_80_kb901k_fx_wheel_b...
Recent Lil' Rider Black 80-Kb901K Fx Wheel Battery Powered Bike Color Blackquestions, ... How can we keep the rear wheel from coming off of the drive shaft?
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike ...
? 8:05
https://www.youtube.com/watch?v=fED8N8DTQfU
Oct 21, 2013 - Uploaded by TMKGL
KB901 Lil' Rider FX 3 Wheel Battery Powered Bike Instructional Video .... Why does the right wheel keep sliding off the tire gear, leaving it free-wheeling? ... WORST piece of trash I've ever triedto assemble! congrats groupon, you ... axle through, this will keep the axle and motor and drive gear fitting tight.
Jan 08, 2016 | Lil' Rider Black 80-Kb901K Fx Wheel...
I have a Schwinn women's 21 speed Frontier. Frame in purple serial #0378. I wanted to know the year and specs. On it? Thank you!
First thing, is headbadge black and red? Does it say it was made in China, either on the headbadge or somewhere else on the frame. If so, the bike has no value as an antique bicycle. If its in running condition, tires hold air, brakes work and gears shift its about a $60 to $ 75 bike
Sep 22, 2014 | Schwinn Frontier 21 Speed Mountain Bike...
How many bicycle gears types are there?
Bicycles usually have 1, 3, 18, 21, 24 or 27 gears. There used to be bikes with 10 and 15 gears but this are old and bike manufacturers do not manufacture them anymore.
Jan 14, 2013 | Cycling
I have a R4447wmlt i need a rear rim with spokes
you will find it on e-bay or from the manufacturer spares
Sep 04, 2012 | Answer Cycling
I've got a 21 speed bike and I get a skipping ,
It is the derailer (the part on the back that the chain runs through). Take it to a bike shop or bike enthusiast. The repair should only take about 5 min. Some bike shops won't even charge you.
Jul 22, 2011 | Cycling
We have an 18" boys huffy bike and the chain keeps falling off. How can I repair.
If a single speed bike loosen the rear wheel and pull it back away from the pedals to get the chain tighter
If it has multi gears the arm hanging down has a ser screw that will need to be adjusted to align the chain to stop at the last gear
May 20, 2010 | Cycling
How do you use the 21 speeds on the Schwinn ladies coaster bike?
there are 7 cogs on the rear wheel hub; three on the crank hub:
7x3=21 gear change possibilities
large gears move the wheel faster and farther around but, with more effort
small gears move the wheel less distance but, with less effort
i.e. 10 teeth divided by 30 teeth= 3:1 per 360 degree rotation of the bicycle wheel
Sep 07, 2009 | Schwinn Cycling
My new 26 18 spd Alpine Bike gears are not
Turn the bike over so its sitting on the seat & bars..
There are a few small setting srews on the derailleur..
These are for adjuting.. Adjust while turning the peddles & shifting.. You should be able to smooth it out
Jul 08, 2009 | Huffy Alpine 26 Women's All Terrain...
Clueless
The rear cassette is only a part of the solution. The front gearset also comes with a variety of ring/teeth configurations.
Plenty on new bikes come with a 'compact' gearset (2 front rings, 10 speed rear cassette). That is generally a lower gear ration to aid in hill climbing.
The rear cassettes are easily interchanged (must be same brand as what the hub uses). Of the 3 you listed; the 11-26 would be "Fastest".
If you want to go fast, and are fit enough to power it at speed for a good duration... look for a large crank ring (greatest number of teeth) and a small cassette # (like the 11-26 you listed). It's a sinple ratio calculation. What you're looking for is the most amount of rear wheel rotations per crank rotation. That is achieved by a big (lots of teeth) front ring and a small (not many teeth) rear cassette ring.
While at the bike store, put the bike in it's highest gear (biggest ring on the crankset, smallest ring on the wheel cassette). Lift the rear wheel off the ground and count the amount of rear wheel rotations for 1 crank rotaion.
A triathalon/time-trial bike will come with a ratio of about 5.5-6.5 rotatotions of the rear wheel for each rotation of the crank.
An endurance road bike (with compact gearset) might come with about 4.25 rear wheel rotations for each crank rotation.
Tri/TT bikes are made to put the rider in the most areodynamic position possible thereby reducing the wind drag and making pedaling easier (so you can manage a higher gear ratio). Endurance road bikes are designed to put the rider in a confortable position (more upright) for all day riding.
Get the bike shop to fit you properly to the bike you choose, not all shops offer this. There are professional bike fitters that can help you when you get close.
Hope that helps
Apr 30, 2009 | Sram 850 8 Speed Cassette 11-32t Mountain...
Mens Titan Pathfinder Mountain Bike
If the gears will no longer go back on the bike, I would recommend buying a new wheel (including a new rear hub). It is usually easier and more cost effective to buy a wheel than to replace the hub. To replace the hub (the part that is stripped on your bike) you would also have to remove and replace spokes, etc. Search online for the wheel size you need (probably 26" - you can check the tire size) or take to a reliable bicycle shop and they will gladly help you. Anyway, you need a new hub but probably better off getting a new wheel - much easier.
Feb 14, 2009 | TitanNet Bike USA Titan Pathfinder Ladies...
Cycling Logo
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
