Question about Dehumidifiers
Humidifier iced up.
The back side of the dehumidifier had iced up into a large chunk of ice. Is this caused by dirt on the coils or filter or do I have a leak in the system? Any other causes?
  • 41 Answers
You are operating the unit in a cold location.wait until it is warmer or move the unit to a warmer location.
Posted on Oct 06, 2009
My Kul Dehumidifier filter keeps freezing up? is there anything I can do to keep this from happening?
Turn the knob to a lower setting so that the unit cycles on & off. This will give it time to warm back up and melt the ice in between dehumidifying runs.
Aug 30, 2015 | KUL 50 Pint Dehumidifier"
Idylis 0526051 dehumidifier - ice build-up. After 7 months of use this started to make a laboured noise that was audible the floor above. I switched the unit off and noticed what appeared to be a "check...
Dust and dirt that causes loss of airflow through the coils is the most likely cause. The only other reason would be a low refrigerant charge to the compressor.
Dec 26, 2014 | Dehumidifiers
There is ice on the filter and the filter will not come out. Tried turning off so it would melt, but filter still stuck. It is summer so why is ice forming?
I have had a AD75UST0 WHIRLPOOL Dehumidifier for several years. I had mine ice up once or twice particularly on very high humidity days > 90%. Once it thawed out. I was able to remove the filter. Most likely it is due to dust getting on coils & condenser Or actually has a Freon leak. to resolve the dirty coils you can easily dissemble (that is remove front & rear cover) it to give coils and condenser a good thorough cleaning. It the coils and condenser are not at all dirty, then is not the cause of the icing. The units are typically not serviceable - i.e. a disposable small appliance.
Jun 02, 2014 | Whirlpool 75-Pint Dehumidifier
Esco Oasis 2700L dehumidifier ices up. Is there a filter to be cleaned and if so, how to I get to it?
The most common cause of frost and ice buildup on a dehumidifier is because the unit is operating in temperatures that are too cold. Many dehumidifiers are not equipped to run at temperatures below 65 degrees Fahrenheit.
To fix this problem, Position the dehumidifier in an area where there is at least one foot of clearance around the unit in order to allow for proper air circulation during its operation. Close all windows, doors and other outside openings to make sure your unit isn't attempting to remove moisture from areas outside of the immediate room. Determine the temperature of the room by checking a nearby thermostat or by using a hand-held thermometer.
Check the filter for dirt and buildup. Unplug the unit from the electrical source and check the filter by opening the filter compartment. If the filter is dirty, it will restrict airflow through the unit and lead to freezing. Soleus recommends lightly vacuuming the surface of the filter to remove dirt. The filter also can be washed in warm water if it is extremely dirty. Once clean, place the filter back in its compartment. Allow for the ice to melt and then restart your dehumidifier.
Jul 03, 2011 | Dehumidifiers
3 year-old machine. Appears that the main refridgerant supply line to the coils ices up soon after you turn it on, starting near a small canister of some kind, then the ice makes it way across the...
Often times, a clogged filter will cause them to freeze up. Because, it's not getting enough air into the system to warm the coils. If you haven't cleaned the filter recently or regularly, that is more than likely the problem. Other than that, the ambient room temperature can play a role in it. If it's cooler than 41 degrees, the humidifier struggles. Same is true if it's over 93 degrees.
Hope this helps you solve the problem.
Mar 11, 2011 | Kenmore 54701 Dehumidifier
How do I clean the dehumidifier?
A dehumidifier works just the way an air conditioner works but in a reverse manner. If you encounter a problem with your dehumidifier then it would be repaired the same way you would repair an air conditioner. As such a dehumidifier does not require much cleaning apart from changing the filter. When the filter and coils of the dehumidifier are choked with dirt, it may not pull out moisture from the air properly. The efficiency of the dehumidifier gets decreased and the only solution is, to clean it thoroughly. In order to assist you with the cleaning procedure of a dehumidifier, following are a few tips:
  1. Remove the water tank/container and clean it after draining the water. Depending on the usage the container must be cleaned regularly.
  2. Cleaning or changing the filter is also important for the main function of ensuring a healthy atmosphere is performed by the filter. Mix some bleach with warm soapy and clean the filter. It will help to get rid of the bacteria, molds and mildew.
  3. Use a vacuum cleaner to clean the evaporative coil/hot coil. Scrub off the dirt using a brush but make sure that you don’t bend the fins while cleaning.
  4. Clean the condenser or the cold coil the same way. If the humidifier is working in a room where the temperature is below 60 degrees Fahrenheit then check the coils whether it is not icing up.
  5. See to it whether the fins are bent or not, if they are bent then straighten them out using a fin comb otherwise it might obstruct the effective working of the dehumidifier.
  6. And yes do not forget to clean the fan blades and other parts of the dehumidifier.
  7. Keeping in mind the humidity level of your room, sets the humidistat of the dehumidifier as keeping it too low or too high may only make the dehumidifier to run longer than necessary.
Also before you start with the work of cleaning the dehumidifier, make sure that it has been unplugged.
Aug 17, 2010 | Fedders A7DH45B2A Dehumidifier
Humidifier is icing up during operation
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
vbn
May 20, 2010 | LG LHD45EL Dehumidifier
Ice forms on the coils of a white westinghouse dehumidifier
if the filter is clean than it most likely is low on freon with the right tools you could add freon
Jul 06, 2009 | Dehumidifiers
Will not shut off
My unit is a Fedders A7DH65B2A and your Maytag unit was made by Fedders and is just like mine w/ different label... I've purchased two of these units (one for me & one for my father-in-law) and they both quit pulling moisture from the air (but ran constantly) about 1 month past the 1yr warranty. My unit also acted really strange one day when the problem was occurring - it flashed on & off erratically and wouldn't power off unless I pulled the power cord. In short, I took it apart and found several issues and eventually figured out the chain of events that led to this: 1) The thermistor went bad and the unit could no longer sense when the evaporator coil started freezing up (normal situation that the unit should detect & then do a defrost cycle). As a result, the evaporator coil turned itself into a big chunk of ice (can see by removing the air filter and looking into that slot at the coil (looks like a radiator). 2) the big block of ice on the coil grew large enough to start making contact with part of the plastic housing above the evap coil that's used for the power control circuit board. The plastic in that area then got ice all over it and since it looks like a little tray, it will hold water (when the ice thaws) and then the power control board will be sitting in a puddle of water (or ice - either will cause malfuntions like not being able to turn the power off using the front panel switch). 3) the puddle of water in the power control board tray caused this circuit board to corrode (happens very quickly when the unit is plugged in since electricity accelerates this kind of thing...). So... a poor quality thermistor (this straps to the bottom right side of the copper pipe that loops out & back in to the evap coil and has a wire coming out of if) caused premature defrost circuit failure. This caused a big block of ice to form where it shouldn't be. The ice caused condensation/moisture/ice to form on/under the power control circuit board and corroded the circuit board and caused erratic power control issues. RepairClinic.com had a replacement sensor board (included all sensors - yes, the thermistor too...) so I purchased it (~$40) and used only the new thermistor off of it to plug into my original sensor board (and strapped it back to the evap coil w/ the chrome looking clip that was already there). Problem fixed! Well, almost... I did have to clean the corrosion off my power control board as well, but it survived luckily. After doing this to mine, my father-in-laws unit experienced similar symptoms. I did the same fix to his and presto... fixed. Cheap low quality thermistors on these units. I need to find a higher quality replacement thermistor before round 2 happens on each unit. Good luck!
Apr 29, 2007 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
163 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
