Question about Tomtom ONE GPS Receiver
The screen shuts down after between 30 & 60 secs
Tomtom one
The screen shuts down after between 30 seconds and 1 minute. The unit continues to give voice instruction as normal. If I touch the screen it comes back on. This problem has arisen in the last 2/3 months. The unit was bought new in 2008.
  • John Gillespie
    John Gillespie Sep 30, 2009
    Thanks Hitwizard - I have tried that. I reached this through 'Preferences' and it was already set to NEVER. Anyhow, I set it again to NEVER and the same thing happened again, screen shut down until touched.
    Also, in 'Planning Preferences' it asks "Do you want the summary screen to close automatically after 10 seconds?" - this is also set to 'No', but the problem persists.
    Regards
    Scholar:
  • 67 Answers
This is an option for the TomTom. If you enter the Options, there should be something about Power Save features. In there, you will see options to shut off the screen, and you can have it do so after a certain time, once a certain speed is reached etc. Just change the time in which it turns itself off to never and you're fixed.
Posted on Sep 30, 2009
Testimonial: "Thanks but I have already tried that. I do appreciate your support."
How do I get the fault codes up on a Panasonic split air conditioning system CUE24FKR
14.2.2 To Make a Diagnosis1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
7 The breakdown diagnosis mode will be canceled unless
pressing the CHECK button continuously for 5 seconds or
operating the unit for 30 seconds.
8 The LED will be off if the unit is turned off or the RESET
button on the main unit is pressed.
Diagnosis
display Abnormality / Protection control Abnormality
Judgement Emergency operation Primary location to verify H00 No abnormality detected - Normal operation H11 Indoor / Outdoor abnormal communica
tion > 1 min after starting
operation Indoor fan operation
only • Internal / external cable connections
• Indoor / Outdoor PCB H14 Indoor intake air temperature sensor
abnormality Continue for 5 sec. - • Intake air temperature sensor (detec
tive or disconnected) H15 Outdoor compressor temperature sensor
abnormality Continue for 5 sec. - • Compressor temperature sensor
(detective or disconnected) H16 Outdoor Current Transformer open cir
cuit - - • Outdoor PCB
• IPM (Power transistor) module H19 Indoor fan motor mechanism locked 7 times occurance
continuously - • Indoor PCB
• Fan motor H23 Indoor heat exchanger temperature sen
sor abnormality Continue for 5 sec. O
(Cooling only) • Heat exchanger temperature sensor
(detective or disconnected) H24 Indoor heat exchanger temperature sen
sor 2 abnormality Continue for 5 sec. - • Heat exchanger temperature sensor
(detective or disconnected) H27 Outdoor intake air temperature sensor
abnormality Continue for 5 sec. O • Outdoor temperature sensor (detec
tive or disconnected) H28 Outdoor heat exchanger temperature
sensor abnormality Continue for 5 sec. O • Outdoor heat exchanger temperature
sensor (detective or disconnected) H30 Outdoor discharge air temperature sen
sor abnormality Continue for 5 sec. - • Outdoor temperature sensor (detec
tive or disconnected) H33 Indoor / Outdoor wrong connection - - • Indoor / Outdoor supply voltage H38 Indoor / Outdoor mismatch (brand code) H50 Ventilation motor abnormality 7 times occurance
• Ventilation motor H51 Nozzle lock abnormality 2 times occurance
continuously - • Nozzle H52 Limit switch abnormality - - • Indoor PCB H97 Outdoor fan motor mechanism locked 2 times occurance
within 30 minutes - • Indoor PCB
• Fan motor H98 Indoor high pressure protection - - • Air filter dirty
• Air circulation short circuit H99 Indoor heat exchanger anti-freezing pro
tection - - • Insufficient refrigerant
• Air filter dirty F11 Cooling / Heating cycle changeover
abnormality 4 times occurance
within 30 minutes - • 4-way valve
• V-coil F90 PFC control 4 times occurance
within 10 minutes - • Voltage at PFC F91 Refrigerantion cycle abnormality 2 times occurance
within 20 minutes - • No refrigerant
(3-way valve is closed) F93 Compressor rotation failure 4 times occurance
within 20 minutes - • Compressor F95 Cool high pressure protection 4 times occurance
within 20 minutes - • Outdoor refrigerant circuit F96 IPM (power transistor) overheating pro
within 30 minutes - • Excess refrigerant
• Improper heat radiation
• IPM (Power transistor) F97 Outdoor compressor overheating protec
within 10 minutes - • Insufficient refrigerant
• Compressor F98 Total running current protection 3 times occurance
within 20 minutes - • Excess refrigerant
• Improper heat radiation F99 Outdoor Direct Current (DC) peak detec
tion 7 times occurance
continuously - • Outdoor PCB
• Compressor
Note:
"O" - Frequency measured and fan speed fixed.
The memory data of error code is erased when the power supply is cut off, or press the Auto Switch until "beep" sound heard following by pressing the "CHECK" button at remote controller.
Although operation forced to stop when abnormality detected, emergency operation is possible for certain errors (refer to Error Codes Table) by using remote controller or Auto Switch at indoor unit. However, the remote controller signal receiving sound is changed from one "beep" to four "beep" sounds.
Oct 13, 2017 | Panasonic Heating & Cooling
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
How to adjust date setting in PHILIPS SA011102S? I don't find any setting for date. thanks
Hi begimaria,
From page 12 of the User Manual (available @ http://ow.ly/5RIdC, as well as FAQ's and software):
1. Press MENU for settings options.
2. Press + to scroll up or - to scroll down for your option. Press )K for next or J( for previous levels.
3. Press 2 to confirm your selection
4. Press MENU or J( to exit the existing settings screens.
Below is a listing of the available settings options. If you have any additional questions, a Consumer Care agent can assist by calling 1-888-744-5477.
Hope this helps! If so, let me know by rating this solution so that I may help others more effectively.
Playmodes Off / Repeat 1 / Repeat all / Shuffle / Shuffle repeat / Repeat
folder / Shuffle folder
Equalizer Rock / Funk / Jazz / Classic / Hip Hop / Dance / Custom / Off
Delete
Power Save On / Off
Scroll status Normal / Slow / Fast
Screen saver
Display Clock vertical / Clock horizontal / Animation
Time 60 sec / 30 sec / 10 sec / Off
Time out 3 minutes / 5 minutes / 10 minutes / 30 minutes / Off
Sleep timer 15 minutes / 30 minutes / 45 minutes / 60 minutes / Off
Resume On / Off
Set day and time Day and Time screens
Language English / French / German / Spanish / Italian / Dutch / Portuguese
Swedish / Polish
Information FW version / Memory available
Factory settings Restore Factory settings
Setting Options
TIP
- Options for each setting are shown on the device display.
- Available settings vary with selected mode.
Jul 31, 2011 | Philips GoGear SA178 MP3 Player
I turn on my pc and its blank screen on it but before i turned it on i removed fan to change it but all so removed the proccer to get to it and no its blank with no bios please help its all i have...
Try unplugging the cord & resetting the bios by moving jp1 for 15 secs. Them to be sure, remove the bios battery for another 10 secs. Put the battery back, plug it in & see if you get a screen. If you do, press delete to enter BIOS. Rest the time & date & anything else you messed with. If it shuts down again, you're overheating the cpu. Meaning, the fan/heatasink isn't seated all the way or you need to apply new grease/thermal paste. If the latter is required, get artic silver or better. Remove all old grease/paste with a rag. Then re assemble. It takes about 30-60 secs for the cpu to shut down with in adequate cooling.
Apr 07, 2011 | Dell Dimension C521 PC Desktop
Hi I have a tomtom one and the problem is that it switches on for a few seconds then goes off with the green light still showing. I have tries charging it for approximately 24 hours and it held its charge...
You "MAY" have to flash the drive. To do this, just hold down the start button for approximately 15 secs. You'll then see a dark screen with different command strings listed, after doing this it should restart itself, if not, then just turn the unit off again & back on to see if it has corrected itself & boots up as normal.
Jun 10, 2010 | Tomtom ONE 125 GPS Receiver
RICOH FT 7650 shuts itself off when not in use after 45 minutes
Enter in the user mode:
1.Press the Clear mode key.
2. Press the Clear/Stop key more 4 sec untill the user tool menu appears on the touch panel.
3.This copiers has more 12 user tools.You can see 5 user tools on the display at the same time.Use these keys to see the rest .
4.AUTO RESET: the copier return to the initial condition autommatically after your job is finished.(after 60 sec)
5.SCREEN SAVER :when the copier does not detect anyone operating it for selected time the display turns OFF.(60 sec).
6AUTO OFF:Whwn the machine is used after weekly timer has turned it OFF the copier will turn itself back OFF after the selected time.The auto OFF time can be set from 1 to 999 minute or the function can be turned.(I recomanded setting level OFF).
Aug 31, 2009 | Ricoh Aficio 450 Copier
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Viewsonic PJ556d shuts down after 30-60 seconds
My solution sounds dumb, I had the same issue. Took the lamp cover off the bottom. The screws were loose holding in the lamp. Maybe they heat and expand and eventually work their way out and the lamp doesn't make good contact. Just tightened mine up, the unit would power off after 45 minutes prior. Been on now for 5 hours, no trouble.
Sep 15, 2008 | ViewSonic PJ556D DLP Projector
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
Downloaded 1 CD to Bose 3 2 1. Now system is stuck in continuous rebot mode.
There seems to be some large problem with the drive, where an obstruction within the drive pops up. The solution is to return it or repair it for a new unit. I am disappointed with the Bose team on this one, let's be SURE. So your bet is to steer clear i suppose! maybe try a reciever based Sony HTIB? Thanks! Good Luck!
Jul 04, 2007 | Bose 3 2 1 GSX System
Tomtom ONE GPS Receiver Logo
181 people viewed this question
Top Tomtom GPS Experts
Martin Murray
Jon Piercy
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
