Question about Twinhead SlimNote N12PI Notebook PC
How to remove hard drive laptop TWINHEAD f12dt because problem window can not boot we want to move out for back up data
    President:
  • 2,600 Answers
Here is the service manual, should have the info needed.
http://www.gammatechusa.com/CSD/support/manual/N12PI/N12PI_ALL_US.pdf
Posted on Sep 30, 2009
  • Fernando Couto
    Fernando Couto Dec 22, 2013
    This is not the service manual, just the user's. No good for serious issues. Anyone can provide a link to the service manual, please?
Can not boot up computer
possible your hard drive
A hard disk failure can be catastrophic if it jeopardizes the data stored on your computer.
In addition to rendering a laptop inoperable, a failed hard disk can damage other files stored on the drive as well.
It is critical to determine whether an actual drive failure has taken place, and there are several steps to troubleshoot a drive before hard disk failure can be declared.
Unplug any devices such as printers, speakers, cameras and other external peripherals. Boot the laptop by pressing the power key.
If this does not result in a successful boot, try booting Windows in "Safe Mode."
Reboot the computer, and hold down the F8 key this will vary depending on your computer and operating system
From the menu choices, choose "Boot Windows in Safe Mode".
If the boot up progresses, then the computer is likely experiencing a software issue, not a hard drive failure.
Reset the hard drive.
This will involve turning off laptop (removing the battery is a good move, too) opening the laptop unit, and unplugging all connections and cables from the hard drive.
If possible, replace the hard drive with another drive.
This will help determine if the hard drive is causing the problem.
Plug all connections back in to the hard drive, and reboot the computer.
Repeat Step 2 if necessary.
If the computer does not reboot, the laptop is more than likely experiencing a hard drive failure and will probably have to be repaired by vendor.
hope this helps
Oct 09, 2012 | mpc X3000 Laptop Transport 14.1" Barebone
Media test failure message. Reboot and Select proper boot device
hope this helps
Need drivers for Twinhead DURABOOK S14Y
The drivers for your product can be found at: http://www.gammatechusa.com/CSD/download.php?model_id=d14ry
Jun 17, 2011 | Twinhead DURABOOK D14RY
Will not boot (twinhead)
Have you tried booting in safe mode pressing F8 when starting up just after you power up, then a menu appears & you can try sytem restore from there or safe mode if you know what to get rid of on the system.
If not boot with a copy of windows in the drive & start again from fresh!
Hope this help's !
Sep 23, 2009 | Twinhead SlimNote N12PI Notebook PC
Iwould like to update this twinhead laptop P90 to a windows 2000 or newer and i would also like to know if i can hook up a portable DVD rom to it as well.
You can put XP on it if you want and yes you can connect a external DVD ROM to the USB port.Its hard to say if the DVD ROM will play well or not though.If the TWINHEAD as a onboard cd drive be sure to set it as your first boot device then the HDD.If it does'nt have a onboard cd drive set it to boot from your USB first then the HDD.Good luck.
Aug 11, 2009 | Computers & Internet
Startup Problem with Lenovo 3000 N200 with Vista
You would need to reinstall Vista together with the device drivers and programs to get a laptop functioning again.
You need to backup your data before you reinstall Vista but since you cannot boot up and get into Windows, you need to remove the hard drive and connect it to an USB hard drive adapter and then plug it into a working computer's USB port. This computer should see this hard drive as an external hard drive (provided the hard drive is OK). You can now see the various folders and files, copy your data files to a USB memory stick or burn them to a CD.
Insert the hard drive back into your laptop and then install Vista.
Jun 15, 2009 | Lenovo 3000 N200 PC Notebook
I have a philips freevent laptop f-12dt
F12DT Drivers list for Windows XP
VGA : Mobil Intel(R) 915GM/GMS,910GML Express Chipset
Version : 6.14.10.4020
Date: 1/23/2005
Audio : Realtek AC'97 Audio
Version : 5.10.0.5830
Date: 4/19/2005
Modem : Motorola SM56 Data Fax Modem
Version : 6.9.7.0
Date: 12/22/2004
CardReader : O2Micro OZ711MP1/MS1 MemoryCardBus Controller
Version : 5.1.2600.0
Date: 12/14/2004
TouchPad : Elantech TouchPad
Version : 5.0.2.1
Date: 4/10/2005
LAN : Realtek RTL8139/810x Famiy Fast Ethernet NIC
Version : 5.621.304.2005
Date : 8/18/2005
INTEL Wireless : Intel(R) PRO/Wireless 2200BG Network Connection
Version : 8.1.0.28
Date: 8/24/2004
go to http://www.twinhead.com.tw/tsd/Ftp/F12DT/F12DTdriver.htm
and download WLAN.EXE for the the driver you want.
Nov 18, 2008 | Computers & Internet
"Non-system disk or disk error replace and strike any key when ready".
If this error occurs you open the cabinet disconnected the harddisk data cable for few seconds and reconnected the harddisk data cable and bot it will work.
Apr 10, 2008 | Compaq Evo N610C Notebook
Will not boot ??
sounds like a problem i had with a philips laptop (which appears to be a twinhead repackaged as a philips)
This might sound weird but it works........
Take the battery out and disconnect from the ac
Press and hold the power button for about 40secs
connect the ac but don't replace the battery and press the power button
then replace the battery and turn it on. it should work
Apr 09, 2008 | Twinhead SlimNote N12PI Notebook PC
Open Questions:
Twinhead SlimNote N12PI Notebook PC Logo
1,349 people viewed this question
Top Twinhead Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Alun Cox
Lee Durbin
Lee Durbin
Are you a Twinhead Computer and Internet Expert? Answer questions, earn points and help others
