My York combo unit has an issue. The heater blows
My York combo unit has an issue. The heater blows out cold. Every year it does this. Last yeear I paid the repair technician $50 and he was gone in 5 minutes and it worked all season long.
  • 8,220 Answers
You might be interested in this eye opening 2 minute movie:
Furnace Lockout
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 09, 2009
  • Dan Webster
    Dan Webster Dec 18, 2009
    Happy Holidays.
My yruck only blows cold air wont blow warm
Could be the air flaps of the heater unit are set incorrectly or not working at all or possibly the heater radiator is blocked or semi-blocked or perhaps there is something wrong with the heater hoses or the heater water valve if one is fitted.
These things need checking before a cause can be established.
I am sometimes called upon to flush out a heater radiator. Sometimes it works and sometimes it doesn't and sometimes it causes a leak and the heater radiator must be replaced. Not an easy job on many vehicles made in the last couple of decades..
Feb 03, 2015 | Cars & Trucks
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
Vauxhall combo heater not working
Coolant is the carrier heat.
Top off the coolant system and test heater setting.
If the coolant and thermostat is over 2 years old then you should do a coolant flush.
Jan 15, 2014 | Cars & Trucks
Volvo s70, 1998, heater not blowing hot air
Are you getting coolant flow through the heater core? These cars have common problems with heater cores but they are easy to replace. IPD has a Video on U-Tube with step by step instructions. Also if you are in very cold weather have you checked your anti-freeze? I saw a Toyota last year freeze completely because of no anti-freeze. It took days to thaw out the heater core and they were lucky that the ice did not blow it apart. It took me hours of starting it and running up to a low temp and shutting it down to get it drivable.
Nov 18, 2012 | 1998 Volvo S70
My 1999 Chevrolet Suburban heater and a/c switch not working properly. When I have my fron a/c unit on, it does not blow as cold as the back unit. It feels like it's blowing warm air like if the...
You are going to need to use a multimeter and have a professional test the relay voltages. This should probably only take an hour, make sure they have the proper electrical schematic for your vehicle year make and model.
Jun 30, 2011 | 1999 Chevrolet Suburban
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
I have a York Unit and a Honeywell thermostat. Our unit froze up and I was told to activate the emergency heat. I did this, what does this heat do? I mean how does it work? When do I set it back to...
by going to emergency heat you have shut off your heat pump and turned on a back up source,either gas or electric, if its cold out,35or less ,just leve your emergency heat on till it warms up a bit
Jan 10, 2011 | Honeywell Programmable Thermostat Heater
Portable Air Conditioning unit no longer blows out cold air
Bit late I know, but for others having same issue, ensure that it doesn't need draining - use black tube at bottom left when viewed from behind to drain any excess water.
Jul 01, 2009 | Heating & Cooling
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heating & Cooling Logo
59 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
