Question about Sylvania 6720FDG 20" TV/VCR/DVD
I have a Sylvanis VCR/DVDcombo and a Standard TV.
I have a Sylvania VCR/DVDcombo and a Standard TV. I got a Magnovox converter box. I got things hooked up so that I can watch tapes and DVDs, but cannot record from the TV. All I get is a fuzzy screen. I do not understand why I can watch the tapes and DVDs but not record. I have a coax cable hooked into the input. Do I need an additional converter box, and if so, how in the world do I hook it up? Any help will be deeply appreciated.
  • 4,234 Answers
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Posted on Sep 30, 2009
Testimonial: "I'll give it a shot. I do have all of the cords hooked up. Thanks for your help."
My sylvanis vcr plays for 5 sec. then shuts down
sounds like a burnt out power supply that is shorting when it gets hot. another option could be a bad censor. if you are familiar with working on electronics i would blow the system out with a can of air and see if that helps anyways. vcr's are a thing of the past now days but you can still find vcr/dvd combo's and they have gotten a lot cheaper! the question is, how much can you buy a new unit for v.s. how much time are you going to spend working on it and determine if it is worth it to you. good luck!
Mar 19, 2010 | Sylvania (SRDD495) DVD Player/VCR
Game mode not working properly on sylvania tv
did you try to switch the tv modes Ex. my tv has av 1 av 2 comp 1 comp 2 does it have those modes
Apr 21, 2009 | Sylvania Electronics - Others
I have an RCA converter box hooked up to an RCA TV and a Sanyo VCR. The TV and VCR are set on Channel 3. The converter box is set on Channel 4 and the TV is also switched to CH 4 when viewing digital...
Basically, you cannot use the coax connections for both the VCR and the RCA converter box. I would hook up the phono/cinch connectors from the VCR to the TV if you can (these are also called RCA connectors, but I'm avoiding using that name so we dont confuse the digital receiver with a cable/connector name that is the same here). There should be a yellow one for video and red/white ones for left and right stereo. I believe the RCA converter comes with a three headed cable that can do this for you. With this configuration, you can set the TV to input on these connectors and the VCR should always output there. Once that is set, you can still use the converter box to receive the signal from your antenna, then run the coax to the VCR. Now, the VCR will always have to be set on channel 4 in your setup and you will need to manually change channels on the converter box for it to record a show. Does this make sense so far?
Feb 27, 2009 | RCA Televison & Video
Do I need converter box for my 6720FDE Sylvania?
HOW DO I SWITCH FROM CABLE INPUT TO ANTENNA WITHOUT REMOTE ONLY HAVE USE OF BUTTONS
Jan 06, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
I cannot record using a DVD/VHS player.
You can record. From antenna to converter box, from converter box to vcr. From vcr to TV.
TV on Channnel 3 VCR on channel 3, and set channel on converter box. Then Record.
Time recording works the same way, but you can set for only one channel at a time. Tht is the only restriction that I have not overcome. The converter box sets the channel. Gee Whizz
Dec 14, 2008 | Philips Magnavox DVD/VCR Dual Player
Sylvanis tv vcr dvd combo
It sounds like the VCR mode switch is dirty. This is located on the PCB, underneath the right hand side of the VCR mechanism. If you do not know what you are doing, I do not recommend trying to clean it yourself. You have to remove the VCR from the board, and pop the wheel off the top of the switch. Use a cotton swab with a bit of alcohol to clean it, and then put a dab of WD-40 on it. Good luck. Also, you might want to tryt to reset the VCR mechanism to the fully ejected position if it is not there already.
Sep 05, 2008 | Sylvania 6727FDE 27 in. TV/VCR/DVD Combo
Digital converter
if you do not have cable or satilite tv, you will have to purchase converter box. If you have either on of those services you will be in good shape.
May 03, 2008 | Sylvania 6427FB 27" TV
Sylvania 6720FDG 20" TV/VCR/DVD Logo
136 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
