My York combo unit heater won't come on. It blows
My York combo unit heater won't come on. It blows out cold air.
  • Scott Smith Sep 30, 2009
    MODEL NUMBER D4CG048NL03068
    SERIAL NUMBER NCCM023679
    Also last year I paid the AC guy $50 bucks he had it fixed in 3 minutes....
  • 19,396 Answers
The fault depends on the unit model. To be more specific I will need to know what model you are using.
York heaters should have a 5 years warranty. Try also contacting the manufacturer.
Posted on Sep 30, 2009
  • Ginko
    Ginko Sep 30, 2009
    Please, let me track down the model.
    Thanks.
  • Ginko
    Ginko Sep 30, 2009
    I did not find your model number, However, if the tech fixed the problem quickly, he just did reset.
    Reset is done switching thermostat to “OFF” position, and disconnecting power (trip circuit breaker) for ten minutes.
    If that does not work, try giving me model name, or select model here. If unit is less than ten years it should be warranted, at least in US,
Why would my combo A/C - Heater unit not blow air while heating or cooling is selected but will blow air just fine when set to "fan only"?
Sounds like wiring issue to me. I've delt with units like this and there is a wire lead for fan only and a separate one to run the fan when the unit is cooling or heating. I'm only speculating here but I would bet money that this was improperly installed.
Dont get discouraged though because it sounds like its working (for the most part) if you feel up to the task find the manual and check your connections. Otherwise hire a professional.
Sep 20, 2014 | Heating & Cooling
Vauxhall combo heater not working
Coolant is the carrier heat.
Top off the coolant system and test heater setting.
If the coolant and thermostat is over 2 years old then you should do a coolant flush.
Jan 15, 2014 | Cars & Trucks
I have a york diamond 80 heater. The part that blows the heat out won't come on.. igniter lites and flames come on but blower doesn't..help we are freezing
Sounds like your fan switch is defectiveor posibble installed in the wrong place. This switch is heat controlled and delays the fan coming on until there is warm air to blow.
Dec 31, 2012 | Heating & Cooling
Auto theft device on and car will not start Infiniti G35
HEATER NOT BLOWING COLD,NO HOT AIR FROM HEATER,A/C BLOWS HOT AIR,A/C NOT BLOWING COLD, COLD AIR FROM HEATER,BLEND DOOR ACUTATOR CLOSED,HVAC UNIT NOT OPERATING,
http://alltypesofpartsreplacing.blogspot.com/2012/12/heater-not-blowing-coldno-hot-air-from.html
Dec 26, 2012 | Infiniti I35 Cars & Trucks
Heater not working
Dec 26, 2012 | 2001 Ford Taurus
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
I have two Amcor AmcorAire UCHW-H12AF2 Split System Air Conditioner units -- 2 years old. One works fine, but the other does not blow heated air (Heat Mode). It is cold outside, but the good unit is...
your unit may be have possible leak on piping then refrigerant exit or had leakage of refigerant try to locate leak then braze it then recharge a correct amoun of refrigeran. if you use heater try to check heating element if ok by supplying voltage or used ommeter to test continuity.
Feb 03, 2011 | AmcorAire UCHW-H12AF2 Split System Air...
When i have the heater/defroster on the heater below blows cold air while the defrost blows hot. when i switch to just defrost the bottom heater stays on and blows cold air. when i have front dash and...
It sounds like you have a blend air door stuck. This is in the housing of the heater a/c blower unit under the passenger side of the dash. There is a motor on the top of the housing that could possibly be stuck or on working.
May 10, 2009 | 2003 Dodge Durango
Furnace blowing cold air
Nordyne Furnace, pilot is lit, thermostat is reset, Heater is on but blowing cold air.
Mar 28, 2009 | York Furnace Draft Inducer Blower Fasco #...
Heater only blows cold air
Check both heater hoses under hood to see if they get hot, if they do the heater is fine. need to check to see if the selection doors inside the unit are opening and closing.
Dec 01, 2008 | 1998 Chrysler Concorde
Heating & Cooling Logo
69 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
