Question about Samsung S8300 Ultra Touch platinium-red Cell Phone
Not connecting to pc the original usb drivers does not work
  • 438 Answers
Usb driver problem i suppose... better use a memory card and a reader ....simple!!
Posted on Sep 30, 2009
  • nayapepe Apr 08, 2011
    FOLLOW THIS STEPS:1) INSTALL SAMSUNG PC STUDIO SOFTWARE.2)BEFORE CONNECTING THE PHONE TO THE PC SET ON KEYPAD *#726872# (THIS ACTION WILL SET THE PHONE IN USB MODE).3) CONNECT THE PHONE TO THE PC, AND WAIT UNTILL WINDOWS XP OR WINDOWS 7 32 BIT INSTAL THE CORRECT DRIVERS FOR THE MOBILE (SAMSUNG MOBILE MODEM).
    THEN OPEN THE SOFTWARE AND IT WOULD BE ABLE TO RECOGNIZE THE MOBILE.THIS WORKS IN MY LAPTOP UNDER W XP PRO SP3 AND W 7 ULTIMATE 32 BIT.
    GOOD LUCK!!!
Usb do not work
if you did a factory restore from original all should work if you did a recovery with new os or without the original recovery disc there should either be a driver and utilities disc also or you will need to go to pc manufacturers website to download drivers, another option go into bios and make sure usb legacy is selected
Jan 13, 2013 | Packard Bell Computers & Internet
DYMO LabelWriter 400 Turbo Installed but gives error message when sending prints
First of all, on Dymos you need to use original Dymo roll,.
Dymo rolls have a tag at the back, non original ones does not have it.
Before reinstalling driver you also need to run the dymo uninstaller utility that you find at Dymo website.
I will post the links for download.
Oct 03, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Window7 crache connecting usb fax modem
I expect it is a problem with your USB Driver, Get an updated driver for your USB slots. (either from motherboard manufacturer or USB manufacturer if it is a USB "card")
Even default or old drivers might work Try a few different USB drivers - a new one, the reccomended one, the original one...
(good idea is to use a ps/2 mouse and keyboard since your usb will be going on and off while you're working, it can be hard to click YES when you're keyboard AND mouse aren't working ;-)
if it still dont work...
Can you set any of your USB slots to work in USB 1.0 instead of 2.0, there could be an option in bios, maybe it will run the "OLD" modem in an OLD mode?
Jan 21, 2010 | Computers & Internet
USB ports conduct power but do not let attachment (eg mouse) work.
Since you know you have power and I am assuming none of the USB connectors pins are broken or shorted then what is happening is that another driver is stepping on the USB driver. Check Device Manager for erros. If none then at the run prompt type SFC/scannow. Have your original operating system disk ready because if it finds problems it will need to install the corrections. The original disk IS NOT the recovery disk (this won't work). If this does not correct the problem the operating system needs to be repaired. Email me for further info.
May 30, 2009 | Toshiba Computers & Internet
Problem connecting Garmin nuvi 205 w to pc
Check your cable.
I had to switch to device to pc cable from the garmin original cable to a pc cable that works with my motorola razor. The funny thing is I originally tried the motorola cable and it wouldn't work, brought the garmin cable and now it doesn't work but the motorola cable does.
Now my pc finds the device and I can go on to the garmin site and update.
May 14, 2009 | Garmin nuvi 205W GPS Receiver
I want to reformat myextensa 2300 laptopanits not working by the method in the booklet on the info disk can you please tell me how to clear the hard drive and restore the system to original
You will still need the original drivers and OS using this method first you need to remove your hard drive, determine wether it is an IDE or a SATA or other connections and get a USB IDE or SATA connection connect this to your hard disk open you HD to another PC like a USB flash Card back up all DAT using this technique then reformat you HD return your HD to you laptop reinstall OS and drivers then you have a fresh laptop. Buying a new Hard disk will also be easier then you can just use your old HDD as a backup. Best of luck read manuals and be careful.
May 31, 2008 | Acer Computers & Internet
I can't transfer files to upload pictures to my pc using usb cable
Go to Sony site and download the driver for your phone
http://ma3-origin.extranet.sonyericsson.com/drivers/
Step 1
Remove data cable from usb and put it into a different one
Step 2
Connect your phone to the computer with the cable and turn it on.
You might see "Found New Hardware" wizard. DON'T let Windows search for the driver; point it to the driver you just downloaded, and install the drive on your computer.
After the driver as installed you should be working 100%
Jan 12, 2008 | Sony Ericsson K800i Cellular Phone
Emachine T1840 Sound, Ethernet, & Usb Trouble
I had the same problem. The drivers on the manufacturer's site did not work. Only the original drivers on the CD that came with the motherbaord.
Dec 28, 2007 | E-Machines eMachines Desktop PC
My XP Media Center PC does not recognise the scanner
Your USB ports on your computer may be bad. Do other devices work if you plus them into the same USB port? You can try plugging the scanner into another PC with USB ports. If it works in the other PC, then that points to the original PC's USB ports. You can try buying an add-on USB port or using other USB ports on the PC. If it still does not work, then there may be a problem with the USB port on the scanner, and the scanner itself may need to be serviced.
Oct 16, 2006 | Symbol CS1504 Handheld Barcode Scanner
Samsung S8300 Ultra Touch platinium-red Cell Phone Logo
246 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
