Question about RCA D61W130 61" Rear Projection Television
My TV turns off then turns it self back on 3-5 minutes later. We are told it is the small signal board?
Any other suggestions?
  • mistin Dec 19, 2007
    Yes it has worked for 3 years now. Just all of a sudden it turnes off while being watched flashes green a couple of times on the led and then about 5 minutes later it comes back on. I was told it was the small signal board. Is that right is it something we could install our selves?
  • jazzmaster20 Jan 11, 2009
    My RCA D61W130 61 in. When depress the power button to turn on the tv, i can get sound and no picture. After a few attempt, picture will come on. And After recevieing normal reception, the tv will turn itself off and back on after 5 to 10 second.
Where can I get a small signal board from or how much are they?
Posted on Dec 19, 2007
  • 1,030 Answers
Rca? d61w130 itc222 ..does the unit flash green led.
itc222 shut down if the processor detects a problem. can be many different things. horizontal output is first thing to check. any sounds, chirps, smell... did it ever work
  • Willie Howell Dec 19, 2007
    possible small signal board. good chance of that. small signal board require special equipment to transfer old data of signal board. to new signal board
47 inch LG tv turns on, goes to screensaver and says NO SIGNAL. nothing has been changed and have two other working sets.
I have a 42" LG that did the same. Searched for a fix, and found thousands of LGs with this issue. The fix is to remove the circuit board with the inputs (HDMI, RCA), place it in the oven at 385 for 10 minutes. I thought no way! Tried the heat gun first, after removing the board, no fix. Then heated the convection oven to 385, placed the board on cardboard in the oven with it off. !0 minute later, no fix. Then, before the turkey in the oven, placed it again on the cardboard in the gas oven at 380. After 8 minutes I could smell it, was concerned and removed it from the oven. Let it cool, hooked it back up, and it WORKED! I am blown away, 1 week later still working. Even fixed the HDMI input signal that went out a year earlier. You can find the video fix on YouTube. One caution is to flip the small tab down first that holds the ribbon connecter secure. It can break easily if you don't do it correctly. As a safety issue I am not suggesting this fix to anyone but the true DIYer, and know the possible risks. But it worked, and cost nothing, as opposed to a $150+ used board.
Nov 17, 2016 | LG Televison & Video
I have a Samsung LNT4053HX. About 4 yrs old. I have a DVD player and Macbook connected via HDMI cables. I turned on the TV and started watching a movie. There was an issue with the sound. It sounds like...
U have a small power surge somewhere.Disconnect all connections to the tv and unplug the tv and replug it back like about an hour later.Reconnected all connections.Go into the the tv Sound Setting to do a resetting of the sound setting back to the factory reset.The tv sound should work find now.If still have the same problems,then the main tv Tuner signal board it is shorted and have intermitten dying parts on the tv Tuner signal board.Only choice now is tries buy a refurbish tv Tuner signal board for the replcement.Tries websites like, to buy LCD tvs refurbishes pcb boards.
May 27, 2011 | Samsung LN-T4053H 40 in. LCD Television
TV turns on, then turns it self off about 5 minutes later. Then you must wait awhile to turn it back on. Already checked and there is no sleep timer or any other setting enabled.
I had a similar problem with my Samsung LCD TV. It turned out to be the internal power supply that was the cause of this trouble. When the repairman came out I told him what had been happening and he said "yeah power supply" right away and replaced it (under extended warranty that I usually don't buy) and yay it's working again still 2 years later.
Apr 10, 2011 | Televison & Video
The HDMI inputs on my tc-p50x1 will not work at all. Both component inputs work, but all three of the HDMI seem to get no signal. Is there a fuse I can replace, or do I have to replace the entire...
No,the HDMI connections hubs are just a few small components parts that was put on by the wave soldering machine and it is on and surface mounted by soldering fussion to the tv to main tv Tuner signal board and funsction as one board,can't replaces these HDMI hubs by itself,it very hard and almost imposible to do so by hand soldering equipments and these HDMI components hubs they don't sell out as individual consumer parts any way.Tries tv unplug,replug it back like about and hour later for the tv to do a resetting itself back to the factory setting.Than go to the tv menu go to PICTURE setting go down to do a resetting to do a resetting to all the funsctions of the tv Tuner signal board.Now all ur HDMI hubs should be working again.If not,the whole Tv Tuner signal board mut be reolaced.Try website like to buy a whole refurbish main tv Tuner signal board for the replacement.
Apr 07, 2011 | Panasonic TC-P50X1 50 in. Plasma HDTV
I have a DYNEX LCD37 for 2 years, it was working great untill I plugged in a new HDMI cable to use my laptop, after a few uses I turned my tv on one day and the Contrast was lost, everything works fine...
The tv Tuner signal board have problems,might need the replacement of the Tuner signal board it self.Tries the tv unplug,replug it back in like an hour later.Let the tv resetting itself back to the factory setting.See,if that solved ur problems.Not,than the Tuner signal board have problems itself,must be replaced the Tuner signal board itself.
Oct 26, 2010 | Dynex DX-LCD37 TV
My Olevia 242TFHD will not turn on. The blue light goes off but the tv does not power on. If I unplug it and plug it back in the blue light will come back on but when I try to power it on it never turns on
The tv have a Tuner board problems,this is the board,that take in the broscasting signal cable.Tries unplug,replug about an hour later.The tv should reset it self and work.Not than tries websites like, to buy a refurbish Tuner board for the replacement.
Jul 08, 2010 | Syntax-Brillian Olevia 242TFHD 42 in. LCD...
Tv goes on and off a few times then turns off
Thats a common symptom which is usually caused by the Small signal board. You can get a replacement small signal board from
Jul 16, 2010 | RCA HD52W66 Projection Television
Philips DLP TV purchased
The small signal board is the problem with the set replace that and the set will be fine. the small signal board is the video processor..
Jan 12, 2009 | Televison & Video
Checkerboard display.
checkboard pattern is generated internally by the light or optical engine.. when the signal is blocked from the signal board. the optic engine generates these test patterns. rolling piture also indicates a signal board problems.
Dec 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
RCA D61W130 61" Rear Projection Television Logo
172 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
