Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
Where does the pto cable hook on at the back. this is the spring.
  • 472 Answers
UP UNDER THE UNIT ON THE RIGHT SIDE YOU WILL SEE A SPOT IT CLIPS IN TO
Posted on Sep 30, 2009
My PTO cable with the spring on the end came off. I'm trying to reconnect the spring from the PTO cable but I have no idea where to connect it too. Please help!
Not sure what PTO cable you are talking about but if you are referring to your manual deck engagement lever with a cable and spring I may be able to help..This happened to a friend of mine..what you are going to do is lower the deck as far as possible and get the mower off the ground so you can early see the operation..then have a friend work the manual lever back and forth while you kids hold the cable towards the deck..this will,give you and idea about where it should be attached...the using a bright light look for some shiny area where the spring or cable would have been attached and wearing the paint off...Note. The spring and cable pull an idler wheel or spindle on the deck to engage the moving belt to make it mow, try locating that and move it by hand...it should have an attachment or holes, look closely possibly it did not just come off the end may be broken...good luck..
Jun 24, 2015 | Garden
How do I reattach the deck to my riding lawn mower
do you have a pto lever that tightens the belt? if so theres a bracket on top and in the back that holds the cabble but first you must attach the spring to the pulley that's on a arm that releases and tightens the belt, there is a hole on the arm closer to the pulley itself hook that up and pull with a little strength and put the end of the plastic of the cable in that bracket and with a carter key holds it in position and then try your lever then make sure nothing is rubbing or under a strain, hope this give you some idea of what to do
May 16, 2015 | Garden
Clutch cable routing for a craftsman 971289010 lawnmower
The PTO cable will come out the chassis straight down from the engagement lever on the right side of the dash panel. Will be fastened to the frame on the right side in front of the rear wheel with a zip tie. Loop over the brake rod and attach to the deck on a tab at the rear center of the deck. A hair pin will secure it there. The inner cable continues from there under the belt and the spring hooks into the engagement bracket. There may be two hole for the spring to hook into. They are marked 38 or 42.
Sep 02, 2014 | Craftsman Garden
I have a yard machine 46 inc deck i took the deck off and now i dont remember where the pto engage blades spring goes model number 13rn771h729 yr. 2007
it will be near the rear of all the pulleys probably just above top of pulleys look for a simple hole where it hooks usually a 1 inch piece of stock
May 16, 2014 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
PTO cable: Ariens 960160021
Sounds like you are missing a return spring. Your PTO if it's mechanical engage has a tension spring to bring it back when disengaged.
Apr 09, 2014 | Ariens Garden
Can't get enough tension on pto belt
make sure you have the proper belt
Sep 23, 2012 | Garden
Hi, I have a 2008 Kubota L3400 HST and recently developed a problem with the PTO not turning off when when the PTO lever is shifted to disengage. I have disconnected the two small wires to the PTO lever...
I just fixed the same problem. The cable running from the PTO shift goes into the transmission case under your seat. You can follow the cable down and where you see a rubberboot, spray DW40 on it liberally. Work the PTO shift back and forth and wait five minutes. Do again if necessary. The spring load under the seat seems to seize up and the cable doesn't slide properly. This is one of the reasons for this problem that is easily fixed. The other a broken snap ring internally that is a much bigger problem.
Good Luck
Apr 21, 2011 | Computers & Internet
Briggs 14 HP Vanguard runs well until PTO is engaged
First thing u might want to check is the governor--Make sure the spring and linkage is hooked up properly and the governor is moving freely.
Jul 19, 2009 | Briggs & Stratton Briggs Stratton Vanguard...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
149 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
