Question about Toshiba 42H81 42" Rear Projection Television
My screen have double shadow,how can i tune back?or is it any problem?
    President:
  • 267 Answers
Hi, When the colors suddenly do not line up on the screen, it means that one of your convergence output IC's has burned out and needs to be replaced. it is probably a good idea to go ahead and replace both IC's with the newer upgradedIC's. The IC's should be replaced and the convergence circuits realigned by a qualified tech familiar with Toshiba projection sets.
thank you for fixya,rate my answer
vijay
Posted on Sep 30, 2009
Dell flat screen monitor is repeating images
"Shadowing" effect fixed by separating the wires in back. Touching wires cause crosstalk of signals . Immediate fix.
Aug 01, 2014 | Dell E172FP 17" LCD Flat Panel Monitor
'Shadows' behind all texts and images on the screen
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
SPUTTERING WHEN HOLDING 50-60 MPH
Since it ran fine before you "fixed" it, go back over the things you changed. Put the old spark plugs back in it. Double check all spark plug wires and ignition connections. Put the bike in a dark area and run it at night, can you see any arcing anywhere?
Jul 01, 2009 | 2004 Honda VT 1100 C Shadow Spirit
Multi-color double images or shadows and curved screen
Alrighty, very common problem on this set. Here's a rundown of the repair if you're a DYI:
With the back cover off you'll notice a set of boards on the bottom of the TV and a pair of boards sitting up over the two bottom boards. The problem lies in the upper-right hand board which is the color convergence power supply. Either replace or repair this board. The repair involves the main power mosfet (a three legged regulator on a heat sink) and two diodes next to it.
Next, the bottom right hand board needs to be removed and a fuse replaced next to the flyback. If you are versed in electronics I can detail the repair further otherwise you're going to have to have a shop do the repair.
May 18, 2009 | RCA HD52W58 52" TV
Double Images / Shadows on the monitor screen
Hi..there,
Have you guys...try to open your OSD on your monitor and blanced the colors or adjust the WB (white blanced) settings....
Jun 30, 2008 | Gateway FPD2275W LCD Monitor
The screen is not clear
Grainy image = playing standard 480 cable or antenna on a high definition set
Double image - convergence ic's, or circuit
Green shadows - green crt coolant/tube issue
Since i haven't heard back, i'm going to clear this from my queue
May 23, 2008 | RCA Televison & Video
Panasonic PT-51HX41 rear projection tv showing shadow/double images.
Unplug the TV from the ac wall outlet for about 4 minutes then plug it back in and turn it on. If it still has a double image then tell me if it's affecting the menu screen from the TV (not the cable menu). And is the double image in red and blue?
C-Dog
Feb 18, 2008 | Sony KP-41T65 41" Rear Projection...
Double Picture
Goto menu and look for convergence control and realign colors.
Sep 22, 2007 | Hitachi 57G500 57" TV
Picture shadow on rear projection Sony big screen TV
OUR TOSHIBA HAS A DOUBLE VISION/BLURRIE PICTURE. THIS PROBLEM IS ALWAYS THERE. SOMETIMES THE PICTURE IS GREAT, BUT MOST OF THE TIME ITS BLURRIE/DOUBLE. LOOKS AS IF IT ALWAYS ON 3D!! ANY SUGGESTIONS? WE WOULD REALLY APPRECIATE ANY HELP WE CAN GET FROM ANYONE. THANK YOU!
Mar 03, 2007 | Toshiba 55H70 55" Rear Projection...
Toshiba 42H81 42" Rear Projection Television Logo
70 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
