Question about Hotpoint WMM39 Front Load Washer
New machine - cannot get it to start - when i go through sequence as manual, choose programme options etc, then press start, top light in sequence goes orange instead of green and programme does not start.
    President:
  • 1,653 Answers
Have you remode the transit screw ./ bolt? Does the drum turn freely by hand - it should. Is the water supply turned on and connected to the machine? If not the machine will not work. Also make sure that the door is firmly closed. If these are OK then switch off the machine at the mains and wait for 30 mins then switch it back on and try again.
Posted on Sep 30, 2009
Testimonial: "Very glad to get crisp advice"
    Brigadier General:
  • 3,513 Answers
These are some easy steps,you should follow before starting up your new washing machine...
Be sure that the cord to the washer will reach the outlet. If it doesn't, call a licensed electrician to move the outlet or install a longer cord.
Check to make sure the drain hose will reach the drainpipe. If it's too short, buy a new one made by the manufacturer.
Turn off the breaker feeding the washer outlet.
Be sure that the floor is clean and dry.
Fasten the drain hose to the washer with a hose clamp. Be sure not to tighten it too much or you might strip the screw.
Attach the water hoses to the washer. The hot and cold on the taps and on the washer are usually clearly marked. Red indicates hot; blue indicates cold.
Plug the washing machine in, and move it into place placing the drain hose in the drainpipe when you can reach it.
Push the washer the rest of the way into the space, being careful not to crimp the hoses.
Leave about an inch and a half of space around the washer to allow room for it to vibrate.
Turn the water faucets on.
Turn the breaker back on.
Run a cycle without clothes or detergent before you use the machine to clear the water pipes and make sure the drainage is adequate.
Thanks for contacting Fixya.com
My washing machine will not turn on.
I suggest you rapid reading of alarms.
  • Press the START/PAUSE button and the nearest option button simultaneously for at least 2 seconds: the LEDs initially switch off, and then display the flashing sequence indicating the last alarm.
  • To display the previous alarms, press the button to the left of the START/PAUSE button in sequence.
  • To return to the last alarm, press the START/PAUSE button.
  • The alarm continues to be displayed for the amount of time required, and then the display returns to its normal operation.
  • While the alarm is being displayed, the appliance continues to perform the cycle or, if in the programme selection phase, it maintains the previously selected options in memory.
Dado
Dec 09, 2015 | Electrolux Washing Machines
How do i reset washing machine AEG 64840
You can choose the right programme for any type of laundry following the descriptions on the washing programme tables (see «Washing Programmes»).
Turn the programme selector dial to the required programme. The programme selector determines the type of washing cycle (e.g. water level, drum movement, number of rinses) and the washing temperature according to the type of laundry.
The pilot light of button 8 starts blinking.
The selector dial can be turned either clockwise or anticlockwise. Position "0" to Reset programme/ Switching OFF of the machine.
At the end of the programme the selector dial must be turned to position "0", to switch the machine off.
If you turn the programme selector dial to another programme when the machine is working, the yellow pilot light of button 8 will blink 3 times and the message Err is displayed on the display to indicate a wrong selection. The machine will not perform the new selected programme.
Dado
Jan 15, 2015 | AEG Washing Machines
Aeg 72630 update
Press first left up button and first left down button simultaneously
( during the execution of the washing programme ) for at least 2 seconds: the LED switch off and then display the sequence of flashes indicating the alarm.
The alarm sequence is displayed for the time in which the buttons are hold down.
When you read the alarm code,we will be able assume what may be faulty.
Dado
Aug 31, 2014 | AEG Washing Machines
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
I have an 11 year old 5.5 excellence top loader by F&P. it won;t continue on with any cycle or programme. it wants to start, but after couple seconds it stops, then it tries again, and then stops,...
Hi just read your posting.When the machine stops and beeps a series of lights will light up on the wash progress line of lights.Starting from left to right which lights are lit when the machine is beeping,is it the 2nd and 6th or the 3rd and 7th etc?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Jun 19, 2011 | Fisher and Paykel GWL11 Top Load Washer
Hello, Re: frontloading washer Model C45172 Our washer has been operating withiout hitch since purchase about five years ago, We love it. Today I tried to program it to do an extra rinse after wash...
For the Elite (HE) machines:
Press 'STOP' twice, press 'POWER', choose a wash cycle (such as 'NORMAL'), select wash options (water temp), press 'START' to finish the reset sequence.
Other Kemore electronic washers:
Unplug the machine for a minute, plug it in. Press 'PAUSE/CANCEL' twice.
Good luck from Detroit, MI.
Jun 12, 2011 | Kenmore Washing Machines
HI IVE JUST BOUGHT A HOTPOINT AQUARIUS ULTIMA WM75 12OO, WITH NO MANUAL, DOES ANYONE HAVE THE SAME WHO CAN TELL ME HOW LONG THE PROGRAMMES ARE SUPPOSED TO TAKE AS MINES TAKING OVER 3 HOURS A CYCLE IS THIS...
choose ur programme, then press time saver then press start button. otherwise it will do a full programme which takes longer. pressing timesaver, will shorten the programme. hope this helps, ive had my machine from new till now for 10 years :) and still going :)
Apr 14, 2010 | Amana Washing Machines
My washing machine Hotpoint wf860 keeps showing Test. please help
The appliance appears to be in shop test mode, to de-activate it follow these steps.
there is 3 differnt variations so here are all 3.
Press the Start/Cancel button until all the console LED's illuminate.
Press both Start/Cancel and On/Off buttons together until
d OFF appears.
The default screen returns and you can select a new programme.
Note:- The default screen information displayed on these models is that of the programme currently selected by the selector knob.
Version 2 ( during Date Code 39 March 2005- to Date Code 42 June 2005)
To Activate
1. Same method as version 1.
To Deactivate
1. Simply press the Cancel button and the appliance returns to default.
Version 3 (During Date Code 43 June 2005 - to date )
To Activate
1. Press On/Off and Start/Cancel together with the top left option button until d On appears.
To Deactivate
1. Press On/Off and Start/Cancel toghether with top left option button until d OF appears.
These variations could explain why some of us have to make several attempts to clear tESt.
Apr 06, 2010 | Hotpoint Ultima WF865 Front Load Washer
Indesit1200 front loader not filling and flashing error code deno can anyone help
hi try these
There have been 3 versions of Demo Mode used on these appliances.
Version 1(Production to- Date code 39 March 2005)
To Activate
1. From the Default screen of a programme, after switching the appliance on press both Start/Cancel and On/Off buttons together until d On appears in display.
2. Press the Start/Cancel button only and tESt appears in the screen (Temp & Spin symbols also appear)
To Deactivate
d OFF appears.
To Activate
To Deactivate
To Activate
To Deactivate
Aug 22, 2008 | Indesit Washing Machines
Cant use dryer
Hi Haziel,
Is it that you want to dry only or wash 'n' dry straight through in one go?
If it's to dry only...
1. Switch the machine on
2. Press the Auto Dry or Timed Dry button until the neon light illuminates.
3. For Auto Dry press the button for 2 seconds to achieve the neon indicator to light up. then press the button until the glow is beside the level of drying you require.
4. For Timed Dry press the button until the time you require is in the display.
5. Press the Start/Pause key to start the cycle
Please note: in the Timed dry any time above 60 minutes will be displayed as 70, 75, 80, 85 etc. but then will be shown as 1:10, 1:15, 1:20, 1:25.
For wash 'n' dry straight through...
1. Switch the machine on.
2. Select the fabric.
3. Change the temperature or spin speed if necessary.
4. Select any extra options if required.
5. Follow the above to achieve the drying accompanied by the wash.
6. Then press the Start/Pause button to get the cycle under way.
There is a downloadable PDF of the user manual for this machine on the Service Force website, if you require the programming sequence guide, which, is covered in the user manual, should this explanation prove unhelpful.
I hope this does help you
WD Pro
Feb 17, 2008 | Zanussi WJD1667W Front Load Washer / Dryer
Hotpoint WMM39 Front Load Washer Logo
62 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
