Question about Cozy (W352E) Heater
Cozy dual sided wall heater
I have a Cozy dual sided wall heater with a thermostat on the wall. The heater will come on intermittently. I changed out the thermostat, that was not the problem. The pilot stays lit. HELP????
  • seandouglas1 Dec 01, 2008
    need wiring diagram for old gas wall heater to thermostat
  • Anonymous Dec 15, 2008
    the piolt is in the wrong spot it wont work need picutre i;m a woman??????
    New Friend:
  • 49 Answers
Have to have over 500 millivolts to operate the system. Check your vent pipe need 3 feet out of roof to prevent cold air from getting to unit and cooling down the pilot generator.
Posted on Mar 09, 2015
    Sergeant:
  • 288 Answers
There isn't much to these things, its either the pilot generator or the gas valve. Or maybe both, try the first, then the second.
Posted on Dec 23, 2007
Cozy wall heater. pilot stays on heater will go on once in a while by moving thermostat up. will run for about a minute then won't react to thermostat when i try to get it going again.
Shut the power off. Pull the thermostat off the wall and jumper the two wires, meaning put them together. Turn the power back on and if the heater works fine its in the thermostat
Dec 06, 2017 | Cozy Heating & Cooling
I have a cozy gas heater model # vcr701a-r can i change the thermostat to digital?
i read its a on off switch connected to it
thats what all wall mounted temp controller do they close a circuit thats phantom power supplied in your closet
buy any thermostat you want an it should work with this unit easily. all are battery power now days.
Jan 05, 2015 | Cozy Heating & Cooling
Cozy gas wall heater won't ignite, pilot light is on
There are two types of igniters, spark-type or glow heater. The glow heaters wear out and crack or break and the spark-type spark gap gets fouled or dirty. Both could have electronics problems that drive the glow heater or spark systems. The Filtrete thermostat is not the issue. While rapping the unit makes the glow igniter come back together to glow again.
Jan 14, 2014 | Cozy Heating & Cooling
Heater turns on and off randomly. Mostly the heater stays on for only 5 to 10 minutes. Had the thermostat changed 5 times by reputable heater man who also installed the wall cozy unit 4 years ago. One...
hi there
could have a faulty gas valve which may let in to much gas.extra load from the stove may be correcting this.
to much gas /too rich a mixture can affect internal temperatures causing thermostats to fail.
does the stove burn a nice strong bright blue flame?.
hope this helps the mystery
Dec 19, 2010 | Cozy (W352E) Heater
I have a Cozy gas heater is there any way of changing the mechanical nob thermostat to a regular wall mount one
need to change the gas valve and add a pilot generator and stat wire and a wall stat. If your unit is natural gas part numbers are gas valve 84085// pilot gen. 70098.
Nov 07, 2010 | Cozy (W352E) Heater
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
I have a cozy gas furnace that only comes on when you bump it.
Hi loose connection in the heater or sticking fan or gas valve
Jan 09, 2010 | Cozy (W352E) Heater
Thermostat fails every year
The term "you get what you pay for" applies here. Get a thermostat that at least has a mercury bulb style. the cheap contacts or points style may just need to be cleaned each year. The digital seem to be the best, but there is no need to go over board either. Keep it simple.
Jan 01, 2008 | Cozy (W352E) Heater
Cozy (W352E) Heater Logo
1,187 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
