Question about LG enV VX9900 Cellular Phone
My display settings reset
When I turn off my phone then charge it, only about 90% of the time, my display settings reset it self. The first time i was ok with putting everything back. But, now its like the 20th time its getting kinda of annoying.
2 Suggested Answers
SOURCE: Click on the LG Dare display settings button and the phone resets
all you do is go into your security and settings and reset the phone. it will turn the phone on and back off again. but this should fix the problem and restore the ability to get into your display settings, as well as view your date and time.
Posted on Aug 01, 2009
Samsung oven display not working
The self clean setting on ovens should be labelled "Self Destruct". This often overheats the timer. This company does oven control repairs. You just remove the timer and send it to them. They repair it for $106 and send it back. There is no charge if they can't repair it.
Feb 02, 2013 | Ovens
How to reset sony tv KDS.60A2000 after replacing lamp so the warning doesn't keep coming on
With the set turned off:
RESETTING THE LAMP TIME
When replacing the lamp, use the following to reset the lamp time.
1. If the Self-Diagnostic screen is already displayed, proceed to step 4.
If not, Power off (Set to Standby mode).
2. Press DISPLAY Channel 5 Sound Volume -
POWER
3. To access the Lamp reset, press 5 until the TIME category displays.
4. Press 1 until the RSET item displays.
Mar 01, 2012 | Sony KDS-60A2000 60" HDTV
8550 cold reset
Performing a cold reset 1 Print a configuration page to record the previous printer settings. 2 Turn the printer off. 3 Hold down GO while turning the printer on. Release GO after COLD RESET appears on the printer control panel display. COLD RESET (in English) appears on the display for one second to verify that the key sequence has been recognized, followed by the power-on self-test message. Once the power-on self-test is finished, the message RESTORING FACTORY SETTINGS displays in English.
Sep 22, 2011 | HP Color LaserJet 8550dn Printer
EnV Touch Keeps resetting
I have VX11KV03 and I am having exactly the same issues; phone reseting to default display, sound, etc and trouble charging. Verizon tech support suggest a *211 call to update the software. Also, with the charging, even though this is still a hassel, unplug and replug in your phone after it says charge is complete. It will actually fill the charge the second time. Hopefully this wroks!
Oct 09, 2009 | LG enV VX9900 Cellular Phone
Jul 29, 2009 | LG Dare VX9700 Cell Phone
Unknown Phone on Lincoln Navigator
It means your phone is activated somehow. Cellular Phone NOTE: The audio system does not operate when the portable cellular phone is in use because the audio-mute feature will mute the audio system when a call is placed or received. Portable Cellular Phone Features
The portable cellular phone system is available only with the P100i audio unit and has the following features:
  • hands-free operation
  • radio muting while phone is in use
  • radio displays the phone number, signal strength, and call timer
  • radio can be used to dial stored numbers and adjust hands-free operation volume
For more detailed information, refer to the User's Guide.
  • Entering ACM Self-Diagnostic Mode.
  • ACM (Audio Control Module) Self-Diagnostic Mode
    NOTE: To enter the Speaker Walk-Around Test or ACM self-diagnostic mode, the ACM must be turned on and in radio tuner mode (AM/FM).
    ACM self-diagnostic mode can only be entered while in the Speaker Walk-Around Test.
    1. To enter the Speaker Walk-Around Test, press the ACM Preset Buttons 3 and 6 simultaneously.
    1. The Speaker Walk-Around Test stops at each speaker and applies a different tone to each speaker for about 1-2 seconds. Each speaker is tested and displayed on the ACM in the following sequence: RF, LF, LR, RR, SUBWOOFER I, SUBWOOFER II.
    1. The Speaker Walk-Around Test automatically continues and tests:
    • the antenna and displays ANTENNA II, for five seconds.
    • for a speaker short. If a short is present, SPKR SHORT will be displayed.
    • for the CD/DJ. The ACM display will show NO DJ if not present. The Speaker Walk-Around Test will end and the ACM will return to its previous setting.
    1. ACM self-diagnostic mode has five tests available:
    • Preset button 1 = Audio internal/external SELF TEST. If SELF FAIL is displayed, press TUNE > to scroll view the DTCs stored. Refer to the ACM Diagnostic Trouble Codes (DTC) Index. If the system is OK, SELF PASS is displayed.
    • Preset button 2 = View/Clear continuous diagnostic trouble codes (DTCs). NO DTCS is displayed if no DTCs are retrieved. If DTCS FOUND is displayed, press TUNE > button to view the DTCs retrieved. Refer to the ACM DTC Index. To clear all DTCs, press the EJECT button. DTCS CLEAR will be displayed.
    • Preset button 3 = SIGNAL TEST. This test measures the average strength at the current tuner setting.
    • Preset button 4 = Software configuration level. This test queries each radio system controller for the software configuration level. SOFT LEVELS will be displayed upon completion of the query. Press TUNE > to scroll view the software configuration version level.
    Controller Description Radio Display Example Main Main micro software version MAIN ##.##.## CDSP CDSP micro software version CDSP ##.##.## ADSP ADSP micro software version ADSP ##.##.## Auxiliary Auxiliary software version AUX ##.##.## CD/DJ CDDJ software version DJ ##.##.## CD Changer CDR software version CD ##.##.## Tape Deck Tape Deck software version TAP ##.##.## RSC Rear Seat controller software version RCP ##.##.##
    • Preset button 5 = DISPLAY TEST. This test will light all the ACM display segments for five seconds, then turn all segments off. When the test is complete, DISPLAY TEST is displayed on the bezel.
    1. To enter these tests, press the preset button desired while in the Speaker Walk-Around Test. This will abort the Speaker Walk-Around Test and start the selected test.
    1. To exit ACM self-diagnostic mode, turn the ignition switch or ACM OFF.
    1. If the concern remains and the fault is not detected, proceed to Symptom Chart to continue diagnostics.
    the module is under the floor console. Do you have the phone user manual.
    Apr 03, 2009 | 2000 Lincoln Navigator
    Visys time/date display settings will not stay correct - help please!
    I have the same problem. I cannot believe I wasted $70 this stupid phone. No more RCA ever.
    Jul 07, 2008 | RCA 25404RE3 Corded Phone
    Sidekick ID.
    try a friends battery if that doesnt work then dont buy a battery and sometimes reseting the phone may work like turn the screen to 90 degress and put an earing or pin inside the reset whole
    Mar 26, 2008 | T-Mobile Sidekick® 3 Cellular Phone
    LG enV VX9900 Cellular Phone Logo
    Top LG Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Are you a LG Cell Phone Expert? Answer questions, earn points and help others
