Question about Sport & Outdoor - Others
ON A MERCRUISER 120 I HAVE WATER IN THE LOWER END, HOW DO I CHANGE THE OIL?
  • 4 more comments
  • sheil561 Sep 30, 2009
    THE PROBLEM IS THERE ARE NO DRAIN HOLES, THE MOTOR IS A MERCREUISER INBOARD, THE OUT DRIVE GETS OIL FROM A TANK INSIDE THE BOAT. I'M THINKING THE LOWER END IS A SEALED UNIT, NO PLUG, BUT THE UPPER IS THE PROBLEM, HAS WATER IN THE OIL. I GOT SOME OF IT SUCKED OUT, BUT THERE IS STILL SOME IN THE GEARS. PAT
    HALBEC: I HAVE OTHER OUTBOARDS AND KNOW WHAT THE PLUGS ARE AND HAVE CHANGED OIL IN THEM REGULARLY. THERE ARE NO PLUGS IN THE HOUSING FOR THE PROPELLAR, OR ANY HIGHER. TO CHECK FOR SURE I HAVE OTHER PEOPLE CHECK FOR PLUGS, THERE ARE NONE. I HAVE HAD THE PROP HOUSING AND LOVER END OFF TO REPLACE AN IMPELLAR, AND THE OIL LEAKED OUT FROM THE UPPER PART OF THE OUTDRIVE, THAT IS FULL OF GEARS. I DID NOT SEE ANY OILING SYSTEM FOR THE PROP HOUSING, THUS THOUGHT IT WAS A SEALED UNIT. I CAN ASSURE YOU THAT IF THERE ARE DRAIN PLUGS THEY ARE NOT IN THE FAMILIAR PLACES AS ON MY OTHER MERCURY'S.
    PAT
    HALBEC: 1984 MERCRUISER 120
    HALBEC: ITS A 1984 THOMPSON 24' WEEKENDER
    HALHBEC: I THINK THERE WAS WATER IN THE BOTTLE I USED TO TOP OFF THE OIL BOTTLE IN THE BOAT. IT WAS SITTING IN THE BOAT, AND THE CAP WAS LOOSE. PAT
    THANKS MUCH...
  • 770 Answers
  1. Buy a little hand pump that fits the bottle of lube to fill the drive.
  2. Place a clean oil drain pan under the drive to catch the old lube as it drains out of the bottom of the drive.
  3. Use a large screwdriver and remove the lower drain plug.
  4. Remove the top oil vent plug.
  5. Let the unit completely drain.
  6. If your drive has an internal drive lube monitor bottle in the boat, remove the bottle from its bracket and pour out the old lube. Look in the bottom of the bottle. If you see residue in the bottom of the bottle it should be removed and rinsed out with carb cleaner or Power Tune. Make sure the bottle is clean and dry.
  7. If the old lube looks and smells bad it could be an indication of a problem.
  8. Inspect the gear lube for evidence of metal particles or water intrustion.
  9. If the lube looks bad and you suspect a problem, FIX the problem before placing the drive back into service.
  10. If the lube was simply old and smelly it is a good idea to flush the drive one time with new clean lube.
  11. To flush the drive fill the drive from the BOTTOM hole with enough lube to fill the drive and then let it drain out fully. Do NOT reuse the flushing lube.
  12. Use a sharp pointy pick and make sure to remove the old drain plug gaskets from the drain and vent holes. Never reuse an old drain plug gasket. Old gaskets get brittle and hard as rock. Look closely in the hole and use the pick to make sure all of the old gaskets have been removed. Buy new drain plug gaskets and place them over the cleaned-up plugs.
  13. Fill the drive from the bottom-up until the lube flows out of the top/side vent hole.
  14. Install the top vent plug with the new gasket and tighten.
  15. If your drive has an internal drive lube monitor bottle, continue to pump lube until there is approximately one inch of lube in the monitor bottle. If you don't, the upper unit will not be lubricated properly.
  16. Remove the lube fill pump from the bottom hole and quickly install the bottom plug with its new gasket.
  17. Wipe up any residual oil.
  18. If your drive has an internal drive lube monitor bottle, add lube to the bottle up to the "full" line. Be aware that the drive might have an air bubble and that the system might "burp" after being run. This could result in a drop of the oil level in the bottle. Just top off the bottle with clean lube and keep an eye on it
Posted on Sep 30, 2009
  • 2 more comments
  • Hal Hallman Sep 30, 2009
    Your problem stated lower end, I made an assumption that you meant lower unit and thus posted the solution for that proceedure. If it is crankcase oil that you wish to change, naturally, the proceedure is different. Most will pump the oil out of the crankcase, via the tube that your dipstick goes into. There are pumps available for this proceedure at your local marine supply/dealer. The reason for pumping rather than draining is obvious, you don't want to fill the bottom of your engine compartment with oil...duh. There is another solution that will be of help, for future changings...I highly recommend this. After you get the oil pumped, install a plug with a valve and a tube that you can route thru the drain hole in the hull, (the one U put the plug in when you launch your boat). This plug/valve will replace the one currently in your oil pan. Then when you get ready for your next change, simply route the tube thru the hole in the hull, put a catch pan under it, open the valve and your oil will drain.
    I had outlined proceedure with the bottle, before replacing the lube in the bottle the system should be drained. The lower unit should not be sealed. There should be drain plugs that simply look like flat screws. If you believe it is sealed, how do you know you have water in the gears...I assume due to the condition of the lube in the bottle? If there is indeed water in the gears, It would have had to come from the lake, indidcating a faulty seal, probably with one of the plugs. Inspect for any screws...they will be flat head, straight screwdriver, about the size of a dime.
    What is the year of your boat...the make...the engine size and make.
    Thanks for the info...I have found a free pdf manual download for a 120 sterndrive. It is older than yours but should apply. I scanned the manual and pics and found the plugs...unusual, the vent plug is in the upper unit, and if proper levels are maintained in the upper unit, it lubricates the lower gear housing because of the mannar they are interconnected. I have provided a link, below for the manual download. S/B helpful for this situation, as well as other things that may crop up. Sorry it took so long, hhope this applies and is helpful to you...GOOD LUCK!
    http://www.4shared.com/get/122707788/55b...
1995 115 hp mercury water pump installation
the water pump is at the bottom end of the leg just above the gear box
it requires the bottom of the leg to be removed to get to the pump housing and impeller
May 27, 2017 | Mercruiser Mercury Mariner Boating
How do you change lower end oil.
Please explain 'lower end oil'.
May 20, 2017 | Cars & Trucks
Why does my mercruiser engine die when put in forward?
Something is too close to the coil wire , CAbles(steering and throttle ) either up front or on the engine do flex when moved.Checkthe movement and operating clearnces at both full and idle positions. All tests can and should be done with engine off, due to Dangerous prop exposure. Good Luck and I would like it if you tell me what you ultimately find. _Ned_
Aug 03, 2014 | Mercury Marine Mercruiser 120 140 3.0 470...
Location of water pump in a 2002 5.7 mercruiser in my boat
In the lower unit there is on and on the front of the engine block is another.
Jul 20, 2013 | Mercury Impeller, Water Pump - MerCruiser...
Reverse gear
Make sure all connections on the rear shift assembly are connected.
Jul 02, 2013 | Mercury Marine Mercruiser 120 140 3.0 470...
7.4 litre mercruiser what oil is recommended?
contact a marine shop handling mercruiser engines and ask them for the recommended oil for the engine
Jun 17, 2013 | Boating
Does my Bosch SHU3032UC have a heat booster?
The dishwasher has a built in instantaneous water heater, so even if the water feeding the d/w is cold the machine will heat it the the temp required for the cycle you have choosen. Reducing the temp will not effect the wash quality at all, in fact having a lower temp or cold water filling the machine will make the drying cycle at the end of the program more effective.
Hope this helps, please leave feedback.
Jul 27, 2010 | Bosch 24 in. SHU30 Built-in Dishwasher
Do i have to drain the oil to replace water impeller in a 1976 mercruiser outdrive
Nope.They are completely separate.You can drop the g/box and the oil is going to stay in the g/box.It's still a good time to change the oil.Oil is cheaper than metal,and you see how your g/box seals are.Hope this helps
Jun 16, 2010 | Boating
All the gear lube on my bravo III leaked out. The oil came out where the prop and the lower unit meet.
we had replaced the engine in our 87 4.3 star craft and when we put the omc cobra stern drive back in we now dont have foward gear, we have nuetral and reverse. could it be the linkage or could it be the shifter cable or any other idea's that could be the problem.
Nov 09, 2009 | Garmin Boating
Sport & Outdoor - Others Logo
177 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
