Question about Sharp MX-3501N All-In-One Printer
I have error code h3 00 shar mx 3500
I have error code h3 00 but i dont know what is the reset code, i tryed whit #/p + c + 14 + print, afther #/p interrupt c interrupt 14 print, any idea?
SOURCE: Help
Sorry bubbabear 64, you are wrong you need to reset the copier with sim 14, once you have cleared the jam, there is no sensor in the fuser so often if the paper gets crumpled in there is doesnt trigger and sensors so the customer trys to copy again and again, seen it many times.
John Sharp Tech
Posted on Jul 22, 2008
  • 24 Answers
SOURCE: Sharp MX-2300N Reset
Type in "p" "*" "C" " *" (that is p button, star button, p button, star button.) the machine will go into sim mode enter 14 then press execute which appears on the lcd and the yes to confirm, then press CA and the machine should turn off then back on again
Posted on Sep 12, 2008
  • 148 Answers
SOURCE: Sharp AR C160 - Error H4-00
The thermistor inside of the fuser needs to be reset before you can clear the code. If you remove the top cover of the fuser the thermistor is located on top of the upper fusser roller. It should be reset able by pushing in. Then you put in the reset code. you may want a tech to look into what caused this.
Hope that helps...
Lbcoaster
Posted on Sep 16, 2008
Cogz
  • 1326 Answers
SOURCE: Even when I try: P Interrupt C Interrupt 14 Start Execute The m
Are you getting a H2 error code? If the code dose not clear you may have a problem with the fixing unit... You may have a blown Heater lamp or thermister thermal fuse or one or two of these items..... You will have to trouble shoot to see what is wrong and repair it before you can reset it.. Good Luck
Posted on Apr 20, 2009
hamzaskilltd
  • 316 Answers
SOURCE: sharp code h3-00
heat roller high tempareture detection
Posted on May 24, 2010
What causes error code E7-14 on a Sharp MX-M363N?
Haven't come across that one before:
Trouble content
Detail SCU
Cause SCU PWB trouble.
Check & Remedy Check the SCU PWB.
Replace the SCU PWB.
You could try resetting the machine:
START (Copy mode)
Press the Program key.
Press the asterisk (*) key.
Press the clear key.
enter 14, execute
Cheers
Andy
Jan 20, 2017 | Sharp Mx-M363n Copier, Printer & Scanner...
What is error code C1-14
C1 14 MAIN CHARGER TROUBLE (COLOR)
You might be able to clean the charge wire.
https://www.sosnfl.com/sharp-mx-c312-error-codes/
May 07, 2016 | Sharp MX-C312 Multifunction Printer
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
HOW DO I FIX ERROR MESSAGE H3-00 ON MY MX M753N
1. Entering the simulation mode
Perform the following procedure to enter the simulation mode.
"#" key "*" key "C" key "*" key
Main code 14 Start key Sub code 0 Start key
OR
"#" key "INTERRUPT" key "C" key "INTERRUPT"
2. Canceling the simulation mode
When the clear all key is pressed, the simulation mode is cancelled.
When the interruption key is pressed, the process is interrupted and the
screen returns to the sub code entering display.
* After canceling the simulation mode, be sure to turn OFF/ON the
power and check the operation.
Note: If the machine is terminated by a jam error or paper empty during copying in the adjustment by the simulation, recopying is required.
DO NOT CONTINUE RESET AS THIS CAN CAUSE A FIRE AND RUIN A PERFECTLY GOOD DAY. REPLACE THE FUSER UNIT
Feb 25, 2015 | Sharp Mx-M753n mx-M753n
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
I have a color copier sharp MX-450 with error code H4-30. kindly solve it as soon as possible.
YOU HAD 3 JAMS IN A ROW IN THE FUSERS, TRY RESETING IT . PRESS # * C * 14 "EXECUTE OR PRINT. WILL RESET FOR SURE BUT IF IT COMES BACK YOUR HEATERS MESSED UP
Dec 01, 2013 | Office Equipment & Supplies
Sharp mx 4100n error code L4-45
P, * , CA , P then enter sim # 14 to reset code.
Jan 08, 2013 | Sharp Office Equipment & Supplies
SHARP MX-3100N CODE E7-06
MFP -Image data decoder error
Try to clear code. enter sim with program key- asterisk*-clear key- asterisk*(P-*-C-*) enter sim 14 print key execute yes clear all machine will reset. if code comes back it is not just not a fluke and you may have another issue.
Aug 28, 2011 | SHARP MX-3100N
Sharp service code H5-01
To enter simulation mode to reset errors enter this sequence on keypad.
press " custom settings" button to return to previous menu and CA to exit sim mode.
Dec 10, 2008 | Office Equipment & Supplies
Sharp MX-3501N All-In-One Printer Logo
308 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
