Question about GoVideo Go Video DVD/VCR Combo
Will not read disk's
The laser works , sled works, machine spins up .but will NOT read disk's and says bad disk on the screen.
Thanks for the help.
ke4asc
  • ke4asc Dec 21, 2007
    The Disk's do not have a label,I will check to see if there is an issue there though. THANKS for the help.
  • stratjunior Dec 26, 2007
    I have the same problem with my DV2150. I tried the DVD laser lens cleaner, but the player won't run it--it says Bad Disk.
Does it have a adhesive label attached to it.... I peeled the label off my disk and the darn this worked fine... go figure
Posted on Dec 21, 2007
Dvd player won't read any disks and when i put the dvd cleaner in it the tv says no disk
Either its sled motor [the motor that spins the disc inside] or the laser pickup unit might be faulty. Check it.
Nov 02, 2013 | iSymphony " 19"" Class - LED - 720p - 60Hz...
No disk message
Hello
Check it with a standard company burned disc. if it does not read it, make sure that either the disc does not spins inside, or the laser pickup unit is faulty. Just open the top cover of the set, and insert the disc, see whether it spins at high speed at first and then slows down. if the disc do not spind, the sled motor is faulty. If the disc spins, and still the player do not read disc, the laser pickup unit should be repalced.
Feb 27, 2012 | Samsung DVD-E235 DVD Player
My dvd player wont read my movies
Hello
Check its Sled Motor. Sled motor is one which get spins the disc we insert into it. If it is faulty, discs won't spin, and the set won't read anu discs, and will show no-disc display. OK.
Dec 12, 2011 | Sanyo DVW-7000 DVD Player/VCR
Hi there, I purchased a Bush lcd/ dvd combi for my daughter 18 months ago.... All of a sudden it is not reading the dvds and automatically ejecting them, any ideas on what the problem is, and how possibly...
Hello
There are two possibilities for this fault. The first one is the spinning problem of disc inside it. If loaded disc does not spins, the mechanism will eject it. The reason for this is damaged sled motor. Sled motor is one which spins the disc inside at high speed. It can be replaced. The second reason is of Laser Pickup Unit itsef. If it does not emit laser beam, the main system circuit will recogonise as there is no disc in the tray, and play function is energised, and will eject the tray out. Check for the first one. This is most comon fault with DVD players. OK.
May 30, 2011 | Bush DVD142RC 14 in. TV/DVD Combo
After loading I get either No disk or Wrong disk. Very rarely display works, mostly it keeps spinning with loading on. I tried DVDs, CDs. Same. Cleaning laser did not help. Thanks for assistance....
Hello
You haven't specified nothing about the model number or brand name of you player. Yet i posts this solution, as a common fault symptom. From your description, I assumes that either Laser Picku Unit or Sled motor is faulty. Sled motor is one that spins the disc inside the player. Just open your players outer cover, insert a disc and see whether it spins as it loaded or not. If not replace the sled motor. If it spins, and the Laser Pickup Unit attempts to read the disc from its inside edge to outer, and fails to read the lead-in and lead-out data from disc, laser assembly is faulty and should be replaced with an idetical one both in type and number. In some cases, the strip wire that connects the laser unit to main board may get braked connection prints inside it, which cammot be detected easly. First of all replace this strip wire, and see the effect if disc spins as i indicated earlier. If you wants furthermore assistance, give me a mail, and indicate your need, as I may forget about the solution which I posts to you. gopakumarg43@ymail.com. OK.
Feb 03, 2011 | Televison & Video
The eject function is not working, the yellow led is blinking, as if the machin was reding a disk, but it never opens. I tried also to open it using the screen option but it does the same thing, the lead...
Take it apart and see if the laser is moving up and down (focusing). If not, then the laser focus servo is bad. After it focuses, the spindle motor should turn and the disc should spin. Remove the spindle lock from the top of the drive case and before it spins quickly place the lock on the disc before it spins to hold the disc in place. If all these processes occur and it still doesn't read, check the lens to see if it's dirty or foggy - clean the lens with "Q" tip and alcohol. if this doesn't work, remove the disk and see if a red beam shines through the lens - if no beam, the laser is bad.
Nov 01, 2010 | LG (GCR8525BK) Internal 52x CD-ROM Drive
I herd a strange clicking noise from my ps2
It sounds like the laser assembly has become faulty, the clicking you hear may be the sled mechanism trying to move and put the laser into place so that it can read the game, or could be the spindle motor trying to spin the disc for the laser to read it. My recommendation is to replace the whole laser assembly, which includes the sled mechanism as well as the spindle motor and laser. Good Luck.
Dec 05, 2009 | Sony PlayStation 2 Slimline Console
Device could not see CD. it's TDK disc with come MP3.
Hello
Look whether the CD spins inside the set, after it has been loaded well. If not replace sled motor. Sled motor is one which do spins the disc inside. If disc spins inside, and the set do not read the disc, laser pickup unit is faulty, and should be replaced with same type and number. OK.
Aug 01, 2009 | Sony CMT-NE5 CD Shelf System
PS2 Disc does not spin
just because you see read doesn't mean the laser is good.
the laser has to read the toc (table of contents) for it to read the toc it must be at the beginning, it must be at the right depth from lens to cd and the spindle must spin. now if you have to spin the spindle that means it most like is not reaching the beginning of the cd or the spindle motor is bad.
Jan 02, 2008 | Sony PlayStation 2 Slimline Console
GO VIDEO DVD/VCR Combo
I have a govideo dvd vcr combo that will not read disks.
the sled runs fine, the laser works, and it seems to try to spin up, but just WILL NOT read the disks.
Please email sugjesstions to ke4asc2@yahoo.com
Thank you.
Nov 11, 2007 | GoVideo Go Video DVD/VCR Combo
GoVideo Go Video DVD/VCR Combo Logo
Top GoVideo Televison & Video Experts
Marvin
Marvin
Demonic-2011
Demonic-2011
 Grubhead
Grubhead
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
