Question about Fisher Paykel EcoSmart GWL15
My son put too much in the washer and now the drum is tilted and won't spin correctly. Is there an easy fix for this?
Yes call out the repair man,he can check it and unscrew it and put it back into position for you.Sounds like the fan belts have slipped off.Hope this helps.
Posted on Sep 30, 2009
Kenmore elite HE 4t washer model 110.45088400. drum is not on track. How do i get it back on track? There is also now a sound like something is loose, maybe the counterweight?
i don't know what you mean by off track,but if the washer is noisy in the spin cycle you have a broken spider gear, how far did you tilt it,i never heard of that,you put some towels down,loosen the middle of the pump and when the water starts to come out you use a shop vac to catch the water,you don't want to tilt it because if something is in the pump you don't want it to slide back inside the hose you want it out,you can take the top off and there are two springs one on each side that holds up the tub and hooks onto the side of the frame or you might have damaged one of the shocks on the bottom,these are the things i would check but if it's loud in the spin the spider gear is broken from overloading and using to much soap,if you have an oder in the washer that's also from the soap,the metal on the gear is soft and the soap eats at it.if it's the gear you'd be better off getting a new washer,it's a big repair and expensive.hope this helps
Sep 29, 2017 | Kenmore Washing Machines
Drum turn left side easy by but right side hard
A Quick and Easy Fix for Whirlpool Washer Brake Lockup
www.davesrepair.com/DIYhelp/DIYddbrakelube.htm
The symptom of what I call 'spin brake lockup' is the washer's basket stopping ... of this article for help) and you'll see the chrome clutch drum, right above the transmission. ... It would be very hard to put grease on the clutch linings inside the lower clutch drum, but I mention ... Please click the "donate" button on the left side of
Washer Agitator/spinner Turns One Way, But Not The Other ...
www.diychatroom.com/.../washer-agitator-spinner-turns-one-way-but-no...
Jan 9, 2009 - 6 posts - ‎2 authors
It agitates just fine, but when the direction switches to spin the drum, it almost feels.... That will make it easier to remove the belts and turn the drive pulley. ... find that the drive pulley won't turn anymore, or will be very hard to turn. ... on the left side or the hose going to the air pressure switch on the right side.
Nov 15, 2015 | LG Washing Machines
Washer won't drain or spin.
What to do when your washer won't spin or drain water ...
? 2:23
https://www.youtube.com/watch?v=oFB1jEdXVsQ
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't spin or drain water ...Washer Repair - Not draining or spinning ...
Maytag, Whirlpool & Roper Washer Diagnostic - Water Does ...
? 6:33
www.youtube.com/watch?v=diRuMkf9_Vs
Sep 12, 2013 - Uploaded by ApplianceVideo.com
Fix your own Maytag Top Load Washer which has some of the following ... Troubleshooting Why the Washer ..
Oct 31, 2015 | Maytag MHWE450WW - Performance Series HE...
Amana nav5805aww washing machine won't spin
You will need to replace the thrust bearing kit. Here is the part to order.
It comes with the instructions and is an easy fix.
Oct 30, 2012 | Amana NAV5805A Top Load Washer
Smeg washer SLB 6 the door won,t open after program cycle
the machine has a blockage in the filter or pump try putting it on a spin again if that dont work pull the machine out tilt it back wait 5 secs and open the door if you have water in the drum you will know the filter is blocked or pump or if its waist is plumb into the sink waist take outlethose off and unblock hope thats helped you let me know
Nov 06, 2011 | Washing Machines
When the spin stops, the brake comes on so sudden the machine jumps sideways with a trearable bang
Easy fix if you have a can of WD-40 UNPLUG THE WASHER FIRST! Then just tilt the washer back against the wall or have a friend hold it back for you look under the washer look at it from the left side dead center where the transmission sits and where the shaft goes up into the washer tub there will be a shiny metal looking disk that is your clutch go just above it where it looks black you will need a flashlight. That will be your break spray a little bit of WD-40 up into that once done set machine down where it needs to be tilt the washer towards you and set back down. This will re-balance the washer once done put the washer into spin cycle and let spin up then push the knob back in it should stop slowly not **** to a stop if it still is jerking redo these steps. But this will fix your problem hope it helps and good luck!
Jan 10, 2011 | Washing Machines
Kenmore washer goes thru all the cycles at the two spin cycles it will pump the water out but it won.t go into the cycle if you grab ahold of the drum and manually give it a start ...
pull the washer out a little awy from the wall,tilt it back so the top rests on the wall,feel around behind the motor,it sounds like the tranny is going and you might find oil around near the back of the motor where the coupling is,also check the coupling,it's behind the motor,it hits the tranny to and when the motor spins it spins the tranny,i've seen the middle of the coupling wear out just catching and if you help it out it will spin but it sounds like the transmission is bad,it's not hard to change it out.send the model number,i can look up your machine,tell you how much a new tranny is and tell you how to change it out,or replace the washer if it's old and put the money into a new washer
Nov 05, 2010 | Washing Machines
Maytag neptune error code lr
i think this one is the one with the clutch. if it does it b4 it spins. put it on a spin. if it doesnt spin, u need a clutch. under the unit the belt is whapped on it
Feb 12, 2010 | Maytag Neptune MAH6500A Front Load Washer
Washer shows UE even with nothing in it and makes a metalic pinging sound bell like when trying to spin
Imbalance error (UE)
One of the following has occurred. Try correcting one or more of these issues below.
* The load is too small
* The appliance is tilted
* Laundry is gathered to one side
* Non-distributed things are put into the drum
Aug 12, 2009 | LG WM1812C Front Load Washer
ND...our samsung won't drain and spin cycle doesn't help
I had similar problem. It would wash but not spin and drain. Spin would only happen when there was no water inside (I removed it manually.) If it spins when empty of water then it could be the outlet from under the drum to the exhaust pump is clogged or the pump itself is clogged. I found $3 in change and a bunch of plastic tags etc.. Remove the bottom panel and unscrew filter (bottom right) check for obstruction. Also tilt machine to side and undo rubber hose from drum to pump to check for obstruction.
Jul 01, 2009 | Samsung WF337AA Front Load Washer
Fisher Paykel EcoSmart GWL15 Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
dweatherby
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
