Question about Nikon D90 Digital Camera with 16-85mm lens
I want to know how to sync my D90 with an SB-600 flash for the best results.I want to know how my camera settings should be on ...rather could I get a break down of how to use the features of the custom menu settings.
randy320sgi
  • 121 Answers
SOURCE: Camera flash problem (Nikon)
ok,
try to set the menu item for Auto FP to ON (it works in P,S, A, and M modes only) that will activate the Highspeed Sync when you are using the SB-600 flash unit, set the flash mode so the indicator shows the off position (the line thru the lightning bolt symbol) on the top inidcator menu in the its next to the red eye redution icon that will keep the built-in flash off even if you need it in low light. hope that works for you.
randy320sgi
Posted on Jan 07, 2009
SOURCE: When shutter depressed "AF" and "SB" LED's flash
My camera's shutter will not depress all the way due to a red flash light coming up all the time in the Flash-Ready indicator lamp (refer to pag 28 in the Nikon manual). It can be full sun outside but it will not work due to the red flash light coming on.
A work around is to select a flash mode of 'cancel'.
There is a button toward the front of your camera called the flash mode button. Click that until you see strike mark on the flash icon of your monitor screen (see page 32 in the Nikon manual).
The camera must have a malfunction of determining the lighting so it always thinks you need to have a flash on the picture. Of course this is not 'fixing' the flash/lighting issue but you can take typical day pictures for now with this work around.
Posted on May 25, 2009
  • 102366 Answers
SOURCE: cannot stop on board flash from flashing in
In commander mode, the onboard flash must flash. How else would it communicate with your slave flash(es)? Depending on your settings, almost all of the communications can be done before the picture is taken.
Is the onboard flash negatively impacting your photos?
Posted on Jan 07, 2010
  • 39 Answers
SOURCE: I have a new D3000 and a nikon SB-600 flash. I
From the Nikon site, do you have one of these flash units.
Support for the Nikon Creative Lighting System when using SB-900, SB-600, or SB-400 Speedlights, or the SU-800 Wireless Speedlight Commander
If so You set the flash mode to "comander" the pop up flash must be UP
This Video by Nikon shows how but you will have to read the manual to get a full description go to the flash section http://www.nikondigitutor.com/eng/d300s/index.html
Then look at them all :)
Posted on Jan 21, 2010
SOURCE: DSLR D90 Built in Flash Will not Stay down..
If the problem is that the flash won't stay locked down (ie. it's not popping up because the camera thinks it needs more light) then have a look at http://dieselpic.wordpress.com/2010/07/14/d90-flash-wont-stay-down-how-to-fix/ - this is what I did to fix mine.
Posted on Jul 14, 2010
My nikon d90 doesn't works when i put the flash sb-600
Could you provide some details? How does it not work? Does the D90 not turn on? Does it take a picture but the flash doesn't go off? What exposure mode(s) are you using?
Apr 02, 2013 | Nikon Speedlight SB-600 TTL Flash
Speedlight SB-600 TTL Flash: When I set my SB600 (mounted on D70) to TTL or TTL...
the sync speed for the sb-600 is onlt 1/200 on most cameras i think so if your shutter is faster then that then all you will see is black/ the curtans behind the shutter.
basicly just try again with a slower shutter speed
May 07, 2010 | Nikon Speedlight SB-600 TTL Flash
D90-Sb600 help
The on-camera flash has to flash if you want it to be in commander mode. That's how it sends commands to slave flashes. Set to "--", that's all it does, the flash will not affect the picture.
If you want to operate remote flashes without any flash from the camera, you'll need to invest in a third-party wireless commander and triggers.
Apr 03, 2010 | Nikon Speedlight SB-600 TTL Flash
Nikon SB600 / D90 out of sync
Check that the terminals on the flash and the camera foot are clean Use a pencil eraser to clean thyem by using a gentle rubbing motion. reconnect and test.
Please rate my help++++Thanks for using FIXYA
Nov 30, 2009 | Nikon Speedlight SB-600 TTL Flash
SB flash does not synk with d90
Are you waiting for the flash to be ready before you fire the first photo?
What shutter speed are you using? Are you trying to sync at too high a shutter speed?
Jul 05, 2009 | Nikon Speedlight SB-600 TTL Flash
My sb 600 fires with the camera but it seems not illuminate
Definately a settings problem. The camera will only syncronize on one specific speed. Youe best bet is to use auto. For manual, you'll have to set the shutter speed at the sync speed.
Flash Sync Speed
  • up to 1/250 X-Sync Speed
  • up to 1/8000 FP High Speed Sync
  • Red-eye reduction
    Red-eye reduction with slow sync
    Rear-curtain sync
    Slow sync
    Front-curtain sync (normal) Flash Sync Modes
  • 1) i-TTL: TTL flash control by 1,005-pixel RGB sensor, built-in flash, SB-800, SB-600, SB-400: i-TTL balanced fill-flash and standard i-TTL flash
    2) AA (Auto Aperture-type) flash: Available with SB-800 used with CPU lens
    3) Non-TTL Auto: Available with Speedlights such as SB-800, 28, 27, and 22S
    4) Range-priority manual flash; available with SB-800 Flash Control
  • Mar 13, 2009 | Nikon Speedlight SB-600 TTL Flash
    Sb-600 and d80 sync, connecting, off camera..
    1. On the SB 600, activate the custom settings menu by pressing the ZOOM and '-' buttons simultaneously for a few seconds.
    2. In the custom settings menu, set the Wireless Remote Flash option (indicated by a curled arrowhead) to 'ON' (use + and - buttons to toggle between options)
    3. Set the flash mode to Master (do not set it as AA or A)
    4. Press Mode button and select one of the four channels available (ensure that you set the camera also on this channel)
    5. On the D80, from custom settings menu, select Built-in-flash
    6. Set the built-in-flash to '--' if you do not want the flash to show up in the scene
    7. Set the mode of the group to i-TTL (this menu can be used to control multiple flashes in different groups. since you are using only one remote flash, select the group you have set in the SB600)
    8. Set the channel to the same as in step 4
    Now you are ready to use the remote off-camera flash.
    Jan 24, 2009 | Nikon Speedlight SB-600 TTL Flash
    How do I make my Nikon SB-600 flash work remotely
    You need something to act as a commander. SB-800, SB-900, and the SU-800 all do this. Some cameras, such as the D300 and the D90 can also do this.
    Nov 02, 2008 | Nikon Cameras
    Nikon D90 Digital Camera with 16-85mm lens Logo
    53 people viewed this question
    Top Nikon Cameras Experts
    Steve
    Ric Donato
    Are you a Nikon Camera Expert? Answer questions, earn points and help others
