Question about Creative Labs Playworks PS2000 Speaker
My creative ps 2000 digital speakers is not giveing proper output.output is not clear and some time they stop to give output.What i do? give solution thanks, kuldeep
4 Suggested Answers
Open SKy
  • 620 Answers
SOURCE: Digital out peters with odd blipping noises then stops outputing.
Hello there
First things first:
* this is a creative labs speakers models sub problem**
if you have warranty I suggest you use, Creative is alert on this kind of pop up sounds and others, concerning the subwofers.
time to RMS, or fix on house or other person who can change some resistors on the SUB.
other than this, ...just change for CREATIVE 7800 speakers, are good, and they correct this issue on this ones, I got it and I have 3 years with them and no problems.
good luck
Posted on Feb 08, 2008
sardanadixit
  • 813 Answers
SOURCE: No sound from rear speakers Creative t6100
Try this:
Go to Control Panel >> Sounds and Audio Devices. Click on Advanced button under Speaker Settings and for Speaker Setup select 5.1 surround sound speakers from the options. Click Apply >> Ok and then check.
Posted on Mar 30, 2009
SOURCE: less center speaker sound
i give two solutions
1. Buy Amplifier.
2. Buy stereo converter.
Posted on May 10, 2009
There is no power supply passing into the device. the green led is not at all lit. the volume controller does not show green light. i feel that the power supply is not getting into the device pls help
Get a multimeter and check its output voltage. it must give 11.5V AC as output. The current output in the multimeter must be 1.6 A .If it is not giving the output, your AC Adaptor has gone bad. there are 4 screws on the adaptor which you can open and inside you will find a single step down transformer. of rating 11.5V AC 111600mA(That is 1.6A) Aand 18.4VA rating. You can try to repair it at a transformer rewinding shop(IF HE DOES IT PROPERLY). or, try to get a new AC ADAPTOR OF THE SAME RATING.
Oct 28, 2013 | Creative Labs SBS 370 Computer Speakers
My creative 2b2 2.1 370 power does not work, is there a way to check what the problem is < I have check it with a different adapter! is there way to open the subbox to check the power supply board?
You can check whether the AC power adaptor is giving output first. If it is not giving an output , then only do you have to open the subbox to check deeper into the subwoofer circuitry.
Mar 25, 2012 | Creative Labs SBS 370 Computer Speakers
I jus plugged up the computer speakers and they wont even turn on .. it makes my sound stop like the speakers are plugged in but it doesnt play from the speakers
u need to be more specific, if you computer is not coming on then your speakers will in any case not give out sound....but if the PC is working and your speakers are not connected properly to the correct speaker out put jack behind the PC then also the sould will not be heard.
Change to a different output slot, check if the speaker has power, the volume is up, the volume ctrol on the task bar od Windows is not in mute,
Go to Control Panel and check for Sound and Audio Devices and check if the options are not greyed out. You should be able make changes in the Volume/Sound/Audio Tabs, else you audio card is not being detected by OS.
Further solution from me will depend on your reply.
Dec 07, 2009 | Kinyo PS-205 Computer Speakers
I bought a creative T 5300 5.1 Speaker system and tried to connect to my onida DVR. But only 2 speakers are working . Is there any other equipment required to be connected between the sub woofer and the...
Is this just a speaker system or does it have a separate control unit?
My Creative system has a unit to select analogue, digital or optical inputs. Only the digital and optical will give 5.1 - but then only if the source material is Dolby Digital or Pro Logic.
Oct 29, 2009 | Creative Labs Inspire 5200 Computer...
At a time only two speaker works out of 4
1. Open Control Panel > Sounds and Audio Devices. 2. Click 'Advanced' Button near the bottom. 9d7466a.jpg
3. Select proper sound system (Quadrophonic or surround sound) according to your speaker system.fc6ac4d.jpg 4. Click 'OK'. 5. Also check volume. 6. Double-click Volume icon in taskbar. 7. Click Options > Properties (From menu) and select 'Playback'. 8. Select all Audio components. 9. Click 'OK' 10. Increase all the volumes.
Now try playing a sound. Good Luck!
Jul 30, 2009 | Computers & Internet
Standard speakers to the computer , low volume
You are getting low volume because there is no amplifier in those speakers. Computer speaker sets are powered -- there is an amp in one of them them which drives both speakers -- a computer audio output without an amplifier will only satisfactorily drive headphones.
May 11, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Labtec speakers want play
check whether the output plug is connected properly or not.... if it is then check out whether the adapter is giving the power output.... if it is then the speakers are spoilt otherwise u can just replace the adapter...
Feb 07, 2009 | Labtec Spin 70 Computer Speakers
Less center speaker sound
1. Buy Amplifier.
Jan 15, 2009 | Creative Labs Inspire T6100 Computer...
Hello there
First things first:
good luck
Feb 08, 2008 | Creative Labs MegaWorks THX 250D Computer...
70 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
