Question about Mitsubishi WD62627 62" HDTV
Green Timer lights blinks for about 10 sec. Then Lamp light, then nothing
Just got this from the soon-2-be-ex-wife. Plugged it in, heard a click noise, then the green timer light blinked for 10-20 seconds, and when it stopped the yellowish LAMP light came on. No sound. No video.
Noticed some screws missing from the back panel so I took the cover off. No signs of cut wire, or plugs being unplugged. Fan never comes on during the click-lamp-blink session.
Any ideas?
Direct: rnrampage@yahoo.com
Definitely sounds like a power supply problem. Check with your local TV repair/service center about getting it repaired or replaced.
Posted on Dec 22, 2007
My panasonic air conditioner model CF-E24GKR is does not appear to be working the green power light is flashing and it is blowing cold air
14.2.2 To Make a Diagnosis:
1 Timer LED starts to blink and the unit automatically stops the operation.
2 Press the CHECK button on the remote control continuously for 5 seconds.
3 "- -" will be displayed on the remote control display.
Note: Display only for "- -" (No signal transmission, no receiving sound and no Power LED blinking)
4 Press the TIMER ? or ? button on the remote control. The code "H00" (no abnormality) will be displayed
and signal will be transmit to the main unit.
5 Each press of the button (? or ?) will increase error code
number and transmit error code signal to the main unit.
6 When the latest abnormality code on the main unit and
code transmitted from the remote control are matched,
Power LED will light up for 30 seconds and a "beep" sound
(continuously for 4 seconds) will be heard. If no codes are
matched, Power LED will light up for 0.5 seconds and no
sound will be heard.
When you have the error code you will be able to diagnose the fault.
Jun 06, 2017 | Panasonic Heating & Cooling
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
When i plug in my tv the screen stays black and wont come on
Hi my name is Roety,
I can help you with your issue ,
Your Mittsubishi has a system the will cause the green light to blink for 70 seconds when first plugged in, if the green light never stops blinking it is either a power supply issue or a stuck keyboard button.
So do the test and reset it to see if the light stops blinking or not.
If I have helped you with your issue
If you have more questions you can still respond
I will reply asap
Thanks
Apr 15, 2010 | Televison & Video
I own a Samsung HL-R5067W 50'' DLP. Set is about 3 years old. Recently I heard a loud pop while viewing, picture distorted, but never went blank. I turned set off. When turned on again a loud whining noise...
Check your color wheel. There is a DIY guide for replacing the color wheel. Mine did the same thing yours is and my color wheel was all busted up. Unfortunately after replacing the color wheel my set continues to do the same thing, but this could mean I need to replace the ballast as well.
Sep 20, 2009 | Samsung DLP HL-P5663W 56" TV
Red blinking light
same problem, red blinking light in series of 5 flashes
May 30, 2009 | Pioneer PureVision Pro-1000HD 50 in....
Nothing happens. power on,can hear click
I had the same problem, but I saw the events leading to it. I was watching TV, went to help the wife, heard a pop, came back to find the TV off. Turned it on, heard the same click you described. I believe you need a new bulb. Mine lasted around 2 years of heavy use. Bought two on ebay. Make sure to consult your manual for the particulars on the bulb.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Toshiba 52HM95 lights blinking
Mine was having the same problem. Just heard back from the shop and they said it's the light engine. They want $750 to fix!!!
Sep 10, 2008 | Toshiba 52HM95 52" HDTV Projection...
Fujitsu Heat Pump - problems with timer? When starting the heat pump - the operation light, together with the timer light blinks twice, then the operation light blinks another five times. Then the...
I had the same problem. The heater did not work in heating mode. However it was OK in air-conditioning mode. The operation light and the timer light blink twice and then the operation light blinks for 5 times followed by few seconds non blinking, then the cycle repeats again. I have read on the internet that you better unplug the power cord and then plug it again so that the heater re-sets itself. My only problem was that my heater is directly plugged to the power with no visible plug. So I went to the main distribution board and put off the power for about 20 seconds for the whole home. HOORAY!! The heater worked after that.
Jun 24, 2008 | Fujitsu Heating & Cooling
Vs-55707
Press Input and menu together on the TV control panel and hold them for 5 seconds see if it blinks a two digit code.
Oct 31, 2007 | Mitsubishi WD-62327 62" Rear Projection...
Mitsubishi WD62627 62" HDTV Logo
190 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
