Question about X2Gen Computers & Internet
Where do I find a power supply cord for the monitor
  • 1,498 Answers
Hi HD,
Luckily Monitors (98.9% anyway) all use the same basic power cords that computers do.
They are available at any computer store or super store electronics department for $5.00 - $10.00.
If there is a Goodwill in your area, I've found them to be a great source of power and data cables. The price tag there is more like $0.50 - $1.00
Much more reasonable.
Best regards
Mike
Posted on Sep 30, 2009
I NEED APOWER CORD FOR DAEWOO L950
I can't find information online about your monitor, so I'll give you a generic answer for all monitors.
Almost all monitors use a C13 cord - the same kind used for a desktop computer. Some use a C7 (two-wire, like that used for some name brand laptop adapters) or a C5 (three-wire, used on other laptop adapters)
C13 image:
C7 image: ac15wna-r.jpg
C5 image:
These images were lifted from the Mouser Electronics website (AC Power Cords Mouser ). They also carry C13 cords with right-angled plugs, which may be more convenient with some monitors.
There are a very few monitors that use an external power supply, which is like a laptop computer power adapter. If this is the case, the voltage and current requirements for the power supply should be on the label on the back of the monitor, and the only other thing you have match is the plug on the power adapter output cord (it needs to fit the power jack on the back of the monitor). Note: the voltage of the power supply must be the same as that shown on the label (usually 12 VDC) and the current rating must be the same or higher. If you don't see the voltage and current listed on the label, look closely at the power jack - the numbers may be molded into the plastic next to it.
It is rare to find a monitor with a permanently attached power cord. If this is the case with yours and it is damaged, do not attempt to splice it outside of the monitor. Put a replacement plug on if the good part of the cord is long enough, and use a good extension cord. Otherwise, you should open up the case and replace the entire cord. You will probably have to get a connector for the part of the power cord inside the monitor also. (If you are good with soldering, you may be able to splice to this connector, using heat-shrink tubing to insulate the connections.)
May 08, 2014 | Daewoo Computers & Internet
WHERE CAN i GET A POWER SUPPLY CORD FOR THIS PRODUCT
Are you looking for the cord that plugs into the the electrical outlet that connects to the external power supply? Or are you are looking for the external power supply as well? If you are looking for just the cord itself, they should be common item that you should be able to purchase and any appliance store.
If you are looking for the cord and the external power supply, there are many online outlets that you can look like ebay, etc. You need to search for a 15 Volt 4 amp universal power supply. I would recommend the universal power supply since it will come with multiple adapters plugs so you should be able to find the right one to fit your monitor. Also note the polarity of the the plug otherwise it might damage your monitor.
Jun 30, 2010 | Advueu Technology ADV1901B (Black) 19 in....
Hook up to the CPU
Two cables are needed, Power and Data signal (VGA). Most monitors take the same type of power cord as computer power supplies. (Some computers will allow you to plug in a slightly modified cable that will power the monitor off the computer's power supply. This cord has similar ends on both sides (with the prongs inside a rubber housing). The only issue with this is it makes the power supply work harder and thus can fail sooner.) Most computer supply shops (online and brick-and-mortar) will have the power cables, if you don't have extra cables hanging around.
I hope this helps.
Mar 20, 2010 | Gateway 7004618 (Black) 17 in. Flat Panel...
I tried turning on my monitor and it wouldn't turn on. I checked the power cord and everything was connected correctly. Any Idea;s?
The first step is to make sure the plug you have the power cord plugged into is supplying power to the monitor. [surge protector? Check the switch or the reset button]. Check for the powered on light, usually in the power on button on many computer monitors. Yellow usually means a bad connection with the computer. So the monitor is actually on, it just appears off because you have a black screen. Check the video cable linkage to the back of the monitor and the computer's graphics card or digital video out.
If when you "power on" the monitor's on light does not light it means that power is not getting to the unit and you could have a bad power cord. If it is of the universal type that unplugs from the unit you can swap out for a new cord to test this [some monitors have external power supplies as part of the cord and this could be the problem]. If swapping it for another works than that was your problem.
Many monitors though have their power cords mounted via chassis clamps to the unit and have internal power supplies and are not end user serviceable.
If power is making it to the unit there are a handful of possibilities. Unfortunately the majority of them, at that point, involve dis-assembly of the unit's outer casing and is not advisable to an untrained end user. A service call would be required at that point.
Feb 10, 2010 | Mag Innovision InnoVision LT765 17" Flat...
I have a Gateway monitor that needs a power cord
http://cgi.ebay.com/NEW-12V-2-5A-Adapter-Power-Supply-for-LCD-monitor-Cord_W0QQitemZ220405347970QQcmdZViewItemQQptZBI_Electrical_Equipment_Tools?hash=item33512eb682
Or you can just type in 12v 2.5A LCD Adapter in an Ebay search. You can usually find a bunch of buy now power supplies that come with cords for a decent price. I've been using one of these for a year or so on my monitor.
Nov 14, 2009 | Computers & Internet
How to know if the monitor is totally dead?
Generally, if the power light (LED) doesn't come on and there is no screen display with or without input signal, it's dead. Probably a failed power supply.
Aug 29, 2009 | Samsung SyncMaster 540N 15" LCD Monitor
Power supply to Mag 780 Model
No, it has a normal, seperate power cord. But the socket in the monitor is very small, it's a small round one. When facing the monitor from the back, it's located directly to the right of the monitor-stand, at the bottom-side of the screen. Just put the monitor on it's side to see it clearly.
It's all explained with pictures in your monitor's manual which you can download from the official website here: http://www.maginnovision.com/Support/Downloads.aspx?sn=464
Aug 23, 2009 | Mag Innovision LT776s 17" LCD Monitor
Where can i purchase another power cord for my monitor
starlogi typically use a standard computer power supply cable you may find one at any computer service center commercial or mom and pop
Jul 13, 2008 | Star Logic 17" LCD Monitor
Power supply cord
Any power supply providing 19V DC at 3 Amp with a positive tip connector will do.
Hope that helps.
Jun 13, 2008 | Balance CM2017 17" Monitor
Supplying power to the monitor to get it to work
I think what you need is a "D" shell connector.. see if the one that fits your PC Power Supply will fit into the Monitor.. if so then purchase another the same. It's called a "D Shell" Power Cord.
Aug 20, 2007 | HP Pavilion F50 17" Flat Panel LCD Monitor
Computers & Internet Logo
Top X2Gen Computers & Internet Experts
Sandy Moore
Sandy Moore
William Alequin
Are you a X2Gen Computer and Internet Expert? Answer questions, earn points and help others
