Toshiba TDP-S20U Multimedia Projector
Overheating
shared by 2 users
posted by dumbjock on Dec 19, 2007
Despite replacing the lamp, changing fan setting to high, bulb to standard, and cleaning with compressed air, our projector is repeatedly shutting down from overheating. Any tips would be greatly appreciated.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by sersan on Jan 02, 2008
indicator fan red light
Solution #1
posted on Jan 22, 2008
Not Rated (0)
Wild99HD
Rank:Apprentice Apprentice
Rating: 85%, 1 votes
Set the lamp to economy mode, make sure it is being used in a cool room with easy air flow thru the projector. If the problem persists, there are two fans inside and a thermistor that takes the temp reading, there is small adjustment POT on the board to increase the operating temp if needed.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on overheating:
I don't want to Accept this solution
Can you Help with these Multimedia Projectors problems?
I bought it in fall 06. Used it for 635 hrs. Projector...
Quick Question oh mighty one, 2810 Compaq projector,...
hi, whenever i turn on my projector, it stays on for maybe...
dear sir / madam My projector Toshiba type TDPS20, have a...
Projects grey until you turn it off and on multiple times...
Loading problems.
Repair Service
Find Multimedia Pro. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
