Back to:
Tags:
Jenn-Air 34 in. Expressions CVGX2423 Gas Cooktop
JENN AIRE CVGX2423 COOK TOP
posted by nannyp on Dec 19, 2007
The fan would not turn off. Then it poppped, sparked and went off. The fan, the ignitors and the lights which are around the knobs, no longer work. Can you help? Thanks
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Dec 21, 2007
Not Rated (0)
saal
Rank:Guru Guru
Rating: 88%, 53 votes
short in the fan wirring.. it is not easiy fix . you need to replace the fan and short wieeing.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on JENN AIRE CVGX2423 COOK TOP:
I don't want to Accept this solution
Can you Help with these Kitchen Cooktops problems?
Jenn-Air 34 in. Expressions CVGX2423 Gas...
All other igniter keep making spark and noice when any...
We have an Jenn-Air gas range, it has the problem that...
Fan will not turn off. Need a new fan switch. Where do I...
There is a small gap where the filter meets metal
I have a Jenn-Air Expressions cvgx2423b model with the...
Loading problems.
Repair Service
Find Kitchen Cooktop Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
