Question about Panasonic Lumix DMC-FX12 Digital Camera
My camera lens shutter won't open, but everything else is working fine. It keeps on repeating 'please turn camera off and then on again' but it's still the same.Is there a way that I can fix it by myself and not need to give it in to the shops instead?
    Scholar:
  • 96 Answers
Sorry, it needs to go in for service.
Usually this type of fault happens due to sand/ grit in the mechanism or it has suffered a knock/ drop.
If it is grit/ sand then they may just clean the lens mechanism.
If it has suffered an impact, then it will probably need replacement.
Sorry for the bad news.
Cheers.
Posted on Sep 30, 2009
I have a Canon PowerShot SD1000 and it turns on, but the screen is blank. It will upload any photos taken (although you can't see what pics you take), but even then you have to click the button on the...
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
By the way, my wife happens to own a SD1000. Great little camera, but it's prone to stuck shutter every once and a while. Easily fixed each time though by simply opening the battery door while on, and gently flicking the lens barrel a few times. Again, see the link.
May 31, 2011 | Canon PowerShot SD1000 Digital Camera
Please turn camera off and then on again. it
Had the same issue with my DMC-FZ50 for a couple weeks, and tried turning it onn and off countless times. I could hear something happening inside the lens on start-up and surmised the internal shutter was trying to open but wasn't able to. I guessed that the turn off/turn on idea was to resend the command impulse to open the shutter. So.... I t urned it on while repeatedly hitting the side of the lens firmly with the palm of my hand and.....it worked!!!!
Jan 01, 2010 | Panasonic Lumix DMC-FZ50K Digital Camera
LENS PROBLEM
The slightly open shutter is the reason for this problem. Thank God you mentioned it.
Solution: Try with your fingers to shift the shutter “blades” back and forth to see if they move freely. If they do no move freely it maens the shutter “blasdes” and stuck by particles/dust/something. So you just continue to shift them like that untill they are free again. Once they are free turn your camera back on and it should perform as normal.
Sep 18, 2009 | Sony Cybershot DSCW80 7.2MP Digital Camera...
Shutter won;t open
Are you talking about the shutter, or do you really mean the automatic lens cover ? Take a look at this first to see if this is what you meant. Make sure you read the comments also for additional tips. I don't think it will be necessary to open it up to fix it. Stick with the easy tips, they should work, especially if this is happening occassionally:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Jun 05, 2009 | Canon PowerShot A570 IS Digital Camera
Sony Cybershot Lens Stuck inside!!!
I have the exact same problem with my Cyber-shot; the lens is stuck inside. After trying everything to loosen it (like wedging a razor knife between the sections, even dropping it or banging it against a book, etc) non of which I recommend, I finally got it open by PUSHING on the black telescoping section surrounding the lens itself. For some reason, this worked!
Nov 18, 2008 | Cameras
Err 99
Hi Ben ,
To isolate the cause of the issue, we suggest that you do the following:
1. Turn off the camera.
2. Remove the lens, battery, and CF card.
3. Allow the camera to sit without power for approximately 20 minutes.
4. Insert a fully charged battery, and turn on the camera.
5. Depress the shutter button as you would to take a picture.
Does the “ERR 99′ message appear? If it does, then the camera should be
serviced. If it does not, then please proceed to the next set of steps:
2. Insert the CF card.
3. Turn on the camera.
4. Format the CF card in the camera.
Does the “ERR 99′ message appear? If so, then the CF card is the most
likely source of the issue. Try using a different card.
If the message does not appear, please complete the following steps:
2. Clean the lens contacts by gently rubbing them with a pencil eraser
or soft cloth. Be careful that you do not let any debris fall into the
camera body.
3. Reattach your lens.
4. Turn on the camera.
If the “ERR 99′ message only appears when one particular lens is
attached, then that lens should be examined by a service technician.
If you see the “ERR 99′ with a different Canon lens attached, then the
camera should be serviced.
Let me know if this worked, if not then the camera is dead and it would require some service or a replacement
Thanks
Proton
Aug 07, 2008 | Cameras
Turn the power on and off again
I fixed this issue with my Sony Cybershot by gently (carefully) hitting the camera 3 times against a carpeted bench with the lens retracted and the camera turned off. It seems the lens gears were stuck. Now the camera works fine again.
Apr 23, 2008 | Sony Cyber-Shot DSC-P32 Digital Camera
Nikon d40
Take the lens off and continue pressing the shutter untill it doesn't react anymore, you should then have a normal menu without the error message.Put your lens on and you're all sorted.Cheaper and less hassle than sending it to Nikon.
olly
Apr 15, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
Shutter
You mean the lens protector doors, not the camera shutter. This seems to be a problem on this camera. Aparently you bumped it against something or dropped it. The only way I know of to fix this is to take it apart and set the arm of the spring again into the side as it should be. You cant do it with out takeing it apart.
Sep 15, 2007 | Panasonic Lumix DMC-LZ5 Digital Camera
Gently tap it on a table or flat surface a few times. Worked for me!
Jul 06, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Panasonic Lumix DMC-FX12 Digital Camera Logo
351 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
