Question about HP Compaq Presario F730US Notebook
Cooling fan make noise upon start-up.
When I turn on my F730US after it has been sitting overnight, the cooling fan makes a spinning noise for a few minutes until it warms up. I tried to vacuum the dust out from outside the fan vents to no avail. Does the fan have to be replaced? Is there any way to lubricate the fan spindle?
  • HP Master
  • 32,281 Answers
It is very difficult to get access to the bearing to lubricate it. The best solution is to replace the fan.
You maybe able to get parts from this site :-
http://repair4laptop.org/disassembly_compaq.html
Posted on Sep 30, 2009
Upon starting my truck I hear the sound of rushing air for about 30 seconds then ok; why?
I would say more than likely it the radiator cooling fan. For some reason some vehicles, no matter what temperature, the cooling fan clutch engages which makes the cooling fan run at full speed like there's no fan clutch.
It sort of makes it sound like the engine is revving up but it's simply the sound of the rushing air from the fan clutch making the cooling fan spin at full speed.
Hope this helps.
Feb 21, 2015 | 2001 GMC Sonoma Extended Cab
My 2003 x5 bmw 4.6is, makes a knocking noise in the Engine upon stating it up, but usually goes away after a few seconds.
Sounds like excess bearing clearance, when the engine sits overnight the oil between the bearings and the crankshaft is able to run back into the oil pan. When you first start it up it takes a few seconds for the oil pump to fill the spaces back up and you get some clatter.
Jul 26, 2014 | 2003 BMW 5 Series
My amana abl1922fes has quit cooling several times in the 5 years i've had it. We unplug it, let it set overnight and plug it back in and it cools fine for a few months when it quits cooling again. Can...
when it stops cooling, you will see some ice build up in the freezer. Letting it sit unplugged melts the ice and you will see some water under the fridge. Connect power and it works. Cause: don't overload the fridge and the freezer. Make sure the doors close snugly. Clean all lint build ups by vacuuming under and behind the fridge after switching off power.
Mar 06, 2014 | Amana Refrigerators
My computer fan making loud noise ,why?
fans tend to make loud noise right before they stop working!!! check to make sure that there is no clump of dust inside affecting the spin of the blades
Dec 16, 2010 | HP (219426-001) Cooling Fan
There is a whining sound upon powering up my HL-P6163W which softens after about 5 minutes, but doesn't disappear completely. I think the source is either the color wheel or the cooling fan. How can I...
It the Colors wheel,cooling fan will shut down,if it start making noise to the fan,because the whole projection egine and the bulb link to it.The fan have to run a certain RPM to keep the tv running without problems.These colors wheels run 1000 RPM to start to give the tv colors and it make out Flexy glass and plastics.What ur opinion,who will give u the problems,first as parts wise.Ok any noises like whinning in the tv alway the colors wheel starting to buckle and warp.Getting worse make motor noises and briddles enough will brake and shatter it into ten of hundred of pieces.Who know,than inside what else will cause the rythum of the RMPS running of the tv,when u replaced it.
Jul 31, 2010 | Samsung HL-P6163W 61" TV
Cooling Fan Spinning Fast On A Cold Start
most fans are clutch fans and they work or are engaged by temp.most all will spin under really cold conditions.this is normal.but to be sure, with the motor off and key in your pocket grab the fan and see if it wiggles or has any slop. if not alls good
Dec 20, 2009 | 2007 Chevrolet Colorado (Extended Cab) New...
Cooling fan not turning
You need to replace it.
Which cooling fan? There are sometimes several and the hardest one to replace is in the power supply. If you are handy with tools and don't mind the work, you can replace it yourself, otherwise you will have to get someone to do it for you.
Sep 10, 2009 | Windchaser 3-way Oscillating Fan
HP Pavilion dv6915nr problem
if it's still under warranty bring it back to where you bought it so they can replace your defective fan
Oct 21, 2008 | HP Computers & Internet
HP Compaq Presario F730US Notebook Logo
179 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
