Question about Canon PIXMA iP1300 Printer
Cartridge is not recognize, it states that my cartridge is not installed properly, i already tried to removed it and reinstall it but always the same result.. help pls
  • sudsud426 Oct 02, 2009
    cartridge is not recognize, it states that my cartridge is not installed properly, i already tried to removed it and reinstall it but always the same result.. help pls...for ip1300
    Guru:
  • 389 Answers
1. Switch off the printer (the button Power ).
2. Holding button Resume , include the printer (press the button Power ).
3. Holding button Power , release button Resume (indicator of the feeding/readiness must glow green)
4. Not releasing button Power , two times press button Resume and release both buttons
- under each striking the button Resume indicator of the feeding/readiness changes the colour (one striking yellow, the second striking green). Beside printer, having more one indicator indication is switched (indicator of the feeding/readiness green, indicator mistake yellow)
- after buttons will be отпущены, indicator of the feeding/readiness certain time will twinkle green (time моргания depends on models of the printer), then green fires constantly
- if after these action instead of constantly burning green printer continues to show the mistake, that or you mistakenned in points 1 4 (switch off the printer and repeat with point 1), or beside printer additional mistake, which necessary to avoid, otherwise he will not fall into service mode (that means this mistake possible hear here).
5. Four times press the button Resume (under each striking the button Resume indicator of the feeding/readiness changes the colour, but beside printer, having more one indicator indication is switched: readiness/ mistake).
6. Once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера). For switching off the printer button Power press once again.
For some printer (for instance, iP2000) for switching off it is necessary to press Power once again i.e. three times contract.
Some printers have two counters абсорбера Main and Platen (Bordless), and if after unset Main waste ink counter ( as is described in this instructions ) after leaving from service mode printer continues to show indication an overflow абсорбера repeat all points to instructions before point 5 inclusive, then instead of point 6:
# For printer iP2000 and iP6220d
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then once press the button Resume (the choice counter Platen waste ink counter) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again.
# For printer iP3300, 6210d, pro9000, pro9500
or
- once press the button Power for acknowledgement of the selected action (the unset of the counter абсорбера), then two times press the button Resume (the unset simultaneously two counters) and press the button Power for acknowledgement of the selected action; for switching off the printer button Power press once again. (For printer pro9000 and pro9500 in documentation is specified only this variant of the unset)
Posted on Sep 30, 2009
  • Sergey Artuganov
    Sergey Artuganov Oct 02, 2009
    Checking the Drum Life
    You can see the percentage of the drum’s life that remains available.
    1 Press Menu, 2, 0, 3.
    2 For five seconds, the LCD shows the available
    percentage of drum life.
    Discard the used drum unit according to local regulations. If you are not sure of
    them, call your local Sanitation Department. Be sure to seal the drum unit
    tightly so toner powder does not spill out of the unit. When discarding used
    drum units, keep them separate from domestic garbage.
    Even if the remaining drum life is 0%, you may continue to use the drum unit
    until you have a print quality problem.
    Follow these steps to replace the drum unit:
    1 Open the front cover.
    2 Remove the old drum unit. Place the drum
    unit on a drop cloth or disposable paper to
    avoid scattering toner.
    3 Hold down the lock lever on the right and
    pull the toner cartridge out of the drum unit
    assembly. (See Replacing the Toner
    Cartridge, page 21-18.)
    4 Wait to unpack the new drum unit until immediately before installing it. Place the
    old drum unit into the aluminium bag and discard it according to local regulations.
    5 Reinstall the toner cartridge into the new drum unit. (See Replacing the Toner
    6 Reinstall the new drum unit, keeping the front cover open.
    7 Press Clear.
    8 Press 1 and when the LCD shows
    ACCEPTED, and close the front cover.
REPLACE toner cartridge
See the illustrated instructions beginning on page 88 of http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/bpl10335/bpl10335.pdf for removing and reinstalling the toner cartridge.
Jul 29, 2013 | HP LaserJet 4100 Printer
I wanted to print my documents here but my printer always says that the ink cartiledge is not properly installed and i already reinstalled my canon printer pixma ip1200
Make sure the ink cartridge is properly installed. Or this is probably common problem with Cannon ink cartridge, replacing the cartridge will solve the problem, but you need check it first under maintenance on Control Panel.
Aug 06, 2011 | Canon PIXMA iP1200 Photo Printer
Oct 02, 2009 - cartridge is not recognize, it states that my cartridge is not installed properly, i already tried to removed it and reinstall it but always the same result.. help pls...for ip1300
Hi there
I have put a PDF files on my website for you to download.
Just click on the links it will download for you.
It got all you need to know in this file.
You can read it on site and print it strait off the website or save it to your PC then print it out.
Click LINK= http://www.4all2sell.com/pdf/Cano-iP1300-iP1700-Manual.pdf
You will need a adobe reader to see this file If you not got an Pdf reader you can download it off this link free.
http://www.adobe.com/products/reader/
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Oct 03, 2009 | Canon PIXMA iP1300 Printer
Cartridge is not recognized
Try it a few more times, if that doesn't work, you'll have to get a new cartridge. (I believe your cartridge comes with a new head, it's actually the printing head that you need)
Canon cartridges are infamous for failing for no apparent reason.
Aug 26, 2009 | Canon PIXMA iP1300 Printer
Ink cartridges cannot be recognized in canon printer
Hello!
Remove the cartridges and gently wipe the cartridge contacts with a dry cloth, then put them back in. Then, hold the "resume" button for 10 seconds for each cartridge, that should reset them.
If that doesn't work, one of your cartridges (sadly) needs to be replaced.
Apr 15, 2009 | Canon PIXMA iP1300 Printer
Printer cartridge
hi!!!!
may be the cardridge install not
place properly? try to remove
and placed it properly!!!
Oct 30, 2008 | HP Photosmart C6180 All-In-One InkJet...
Printing Error
plz try by reinstalling your printer drivers and resit your cartridge
Jun 30, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
INSTALLING NEW PRINTER CARTRIDGES
Cyan or blue prints in stripes. Tried allignment but still cant solve the problem.
Oct 30, 2007 | Canon Pixma MP450 All-In-One InkJet...
Canon PIXMA iP1300 Printer Logo
317 people viewed this question
old marine
old marine
