Question about HP PSC 2175 All-In-One InkJet Printer
Printer does not power up, have checked the small power pack on the back 31 volts comming out of it regards Pete
  • petedrodgers Oct 01, 2009
    Hi thanks, the printer is connected directly to a socket outlet. The printer has been working perfectly for a couple of years, I switched it off at the socket when we went on holiday and it would not power back up when we returned. there is the correct voltage coming out of the power pack at the back of the printer, but i am not sure if there are any internal fuses.
  • 58 Answers
Make sure you are not using any power strips or surge protectors. connect the printer directly to the power outlet
Posted on Sep 30, 2009
  • Arun Kumar Oct 01, 2009
    The fuse in printer is not user replaceable. However try with the reset
    Reset the All-in-One to the factory default settings by using these instructions:
    1. Unplug the power cable from printer when the printer is powered on.
    2. Press and hold Cancel and the Right Arrow while plugging in the power cord.
    Continue holding until it displays S Full Reset message in the front panel of the All-in-One.
I need to find a chuck, part #JT3,I think.
sounds like you need a morse 3 taper chuck or you can buy sleeves if its a morse 2 taper anyway not enough information ? is yours a morse taper or is it a screw in chuck? engineering supplies usually stock chucks or machinery shops, as an example try looking at this web site http://www.machines4u.com.au/search/?action=browse_search&industry_id=2&category_id=31 this company is called (machines4u.com.au) they have branches in all states
regards pete Sell or Buy Drilling Machines Second Hand Drilling Machines for sale...
Mar 21, 2015 | Drills
1996 jeep cherokeecranks no spark on coil or distributer
Test procedure:
1. Test powers and grounds at the Powertrain Control Module (PCM) on the C1 connector. Pins 2 and 22 are power, then check pins 31 and 32 for ground.
2. Next, test the 5 volt power supplies at pin 17 of the C1 connector and pin 31 of the C2 or middle connector for shorts to ground. Sensors on the circuit are the Camshaft Position (CMP) sensor, Crankshaft Position (CKP) sensor, Throttle Position Sensor (TPS), Manifold Absolute Pressure (MAP) sensor and Vehicle Speed Sensor (VSS).
3. Unplug the sensors on the 5 volt power supply, one at a time, while monitoring the 5 volt supply.
4. When the shorted sensor is unplugged, the PCM will wake up and scan tool communication will return.
5. The wiring harness could also be shorted to ground on one of the 5 volt power supply wires. Cut the wires at the PCM on pins C1-17 and just unplug the center connector. Then check for the 5 volts on the PCM of the connector or checking for any continuity to ground with the sensors unplugged at the PCM connector on C1-17 and C2-31 to check the wiring harness
Nov 16, 2013 | Cars & Trucks
I have ac Acer S202HL LCd monitor. When I booted up one day it didnt come on.
first check with your both power supply out put is coming 19 Volts dc.
if its not coming check with multi meter primary and secondary of your adopter continuity.if no continuity replace with proper working adopter.
Nov 07, 2013 | Acer S202HL LCD Monitor
The LG lap tap while working suddenly gone off and not switchingon again. This happended three months ago and started after some time. this time after lapse of 10 hours also not started . What could be the...
The weakest part on the laptop is the power jack and the external power supply pack.
Pay close attention to the POWER ON indicator.
A loose jack will has a intermingling power indicator when you move the jack or the cable.
When the power go off at the laptop screen,check the temperature of the power pack.
It should be warm to the touch.
If you has access to a digital volt meter then check the reading and compare to the voltage specification label.
It should read 1 to 2 volt above the spec on open circuit.
A failing power pack will generate an small buzzing noise.
Sep 06, 2011 | LG Computers & Internet
What type of ink cartriges are used in the lexmark 5400 model
hello there
here is the lexmark ink cartridges #31 for color and #32 for black 18c0031us_sm.jpg #31 Photo Color Print Cartridge (18C0031) $ 34.99 QTY 18c0032us_sm.jpg #32 Black Print Cartridge (18C0032) $ 24.99 QTY 18c0533_sm.jpg Twin Pack #32 Black Print Cartridge (18C0533) $ 47.99 QTY 18c0033us_sm.jpg #33 Color Print Cartridge (18C0033) $ 26.99 QTY 18c0534_sm.jpg Twin Pack #33 Color Print Cartridge (18C0534)
Sep 29, 2009 | Lexmark X5470 All-In-One InkJet Printer
My HP photosmart 2710 will not turn on. There is 31 volts going into it??
Option 1
If you have a blinking light try changing cart.
Option 2
If the unit is blackout change the power supply. Here are the specs
Power specifications
* Power consumption: 75 W maximum
* Input voltage: AC 100 to 240 volts - 2 A 50-60Hz, grounded
* Output voltage: DC 31 volts === 2420 mA
Sep 16, 2009 | Computers & Internet
Paper light blinking, paper tray full, won't print
hi,
i recently bought a second hand hl-5140 and when switched on had the fault you have described - on checking machine over i found a small piece of torn paper stuck in the paperpath. after clearing, the printer worked fine.check over for paper again as mine was only a very small peice.
hope this has been of help.
pete
Sep 04, 2009 | Brother HL 5140 Laser Printer
Sony dctrv250 error code C:31:23
I will forward a link to page where you can get more information regarding the issue.
http://www.kb.sony.com/selfservice/documentLink.do?externalId=C79466
Please try Power Resetting the Camcorder.
First, please turn OFF the Camcorder.
Then, remove the battery pack from the Camcorder.
Then, press and hold the POWER button on the Camcorder for 30 seconds.
Then, reinsert the battery pack and check whether the issue is resolved.
Jul 10, 2009 | Sony Handycam DCR-TRV740 Digital Camcorder
Lost power cord
Specifications:
  • Manufacturer: HP
  • Input: 100-240V, 50/60Hz
  • Output: 32V, 16V
  • You can get more information here:
    http://www.unitedsale.com/product_info.php?products_id=18583
    Please vote me if you like my post.
    May 25, 2009 | HP Photosmart 2610 All-In-One InkJet...
    Hp pavilion dv4000 screen is dark and unreadable
    hi this is a website where you can dawnload service repair manual
    http://www.laptop-repair.info/hp_laptop_repair_manual.html
    check with it
    regards
    Sep 18, 2008 | HP Pavilion dv4000 Notebook
    HP PSC 2175 All-In-One InkJet Printer Logo
    66 people viewed this question
    Seeker5211
    Seeker5211
