Question about Singer CE-200 Quantum Futura Computerized Sewing Machine
The bobbin thread shows
My machine is the Singer Futura CE 350, but that doesnt come up in the list - the bobbin thread shows through to the top of the fabric instead of the top thread
    Problem Solver:
  • 10 Answers
This may or may not help, but perhaps you should check that your bobbin is wound correctly, and that you have it inserted into the bobbin case properly. I find that these are usually the 2 main reasons why the bobbin thread show through.
It could be the design, does it do it on all designs?
Posted on Nov 05, 2009
    Problem Solver:
  • 5 Answers
When this happens, it could mean a small amount of lint has built up in the black bobbin casing, where the bobbin thread threads through. Take out the case, inspect and file and rough edges on the black plastic. Then take some floss and floss through the area the bobbin thread gets threaded through. This usually solves the problem. Sometimes your bobbin thread just gets unthreaded and needs to be threaded again.
Posted on Oct 20, 2009
I am having the same problem and can't seem to find the answer. Please email me if you have found a solution!
Debr535@yahoo.com
Posted on Oct 06, 2009
I have a Singer Futura XL 400 the bobbin thread is showing on the top
Tension between top and bottom is a BALANCE, and when the bobbin thread shows on top, it means that your top tension is tighter than your bobbin tension, so it is pulling the bobbin thread up above the fabric.
Loosen the top tension to balance it--it should only take a couple of "ticks"--no more than one number. Loosening the top tension, by the way, is AWAY from the "S".
Apr 04, 2014 | Singer Futura Xl-400 All-In-One Sewing And...
I have a singer Futura CE-250. I am having problems with the tension I think. While embroidering the top thread is showing completely on the underside of the material. In other words the bobbin thread...
One of the things they don't really tell you about embroidering with the singer machines is that you really do need to use the same color in both the bobbin and the top. No matter how much you adjust the tension, you will still end up with some of the thread from both showing through on the other side, unlike with most other machines.
I found this out from a Singer technician about 3 years ago when I had the same problem with my CE 150 and was going nuts! He worked with both Singers, Vikings and Huskvarna's. and saved my sanity after demonstrating a lot of technical stuff that basically showed me why Singers did this.
Save your sanity-just bite the bullet and use the same thread in the bobbin as you do in the top.
May 27, 2011 | Singer CE-100 Futura Computerized Sewing...
My Singer Futura keeps beeping and stopping every few seconds.
There are a few problems this could be. Your top thread could be broken or about to break; your bobbin thread could be broken, about to break or empty/about to become empty and is loose around the bobbin; you could have a birds' nest (a mass of thread just under the fabric/presser foot and/or within the feed dog and bobbin) forming and causing a jam; or it could be your Futura having a little bit of a hissy fit. Obviously, if you've checked for broken thread you need to move on. Check for a birds' nest by removing the fabric and clip your threads. If you find one, clear it, rethread your bobbin and begin sewing again. If there's no birds' nest, then place the fabric back in and try sewing/embroidering again. If the machine acts up again, I recommend removing the fabric/hoop, rethreading your top and bobbin threads, replacing fabric/hoop and resuming where you left off. If the machine still gives you trouble, try hitting the start button for a couple of times and seeing if the problem doesn't simply resolve itself. When you're embroidering areas that have a few small, short stitches only, the machine seems to act up a little and then behaves fine once you bypass the area. Be sure to take all of the other steps first, though, because a birds' nest will RUIN a beautiful seam or embroidery.
Feb 06, 2011 | Singer CE-100 Futura Computerized Sewing...
I have a Singer CE-100 and I would like to know why it keeps beeping and stopping?
Nov 11, 2010 | Singer CE-100 Futura Computerized Sewing...
I have a ce 100 and the bobbin thread comes up and gets into my embroidery pattern. how do i loosen the top tension to stop this from happening. my purple flower has white in it from the bobbin :(
Just an FYI-the bobbin thread needs to match your top thread. The majority of the thread that appears in the top of your embroidery actually IS the bobbin thread. The machine is working correctly. Don't use a bobbin full of white thread-instead, thread a bobbin with the color your doing the embroidery work in to match and you will have a perfectly beautiful embroidery.
I have the futura ce-100. When embroidering it
This annoys the heck out of me, cause it happens a lot more than it should. There can be some valid reasons as to why it happens, though.
Mar 22, 2010 | Singer CE-100 Futura Computerized Sewing...
Bobbin thread is coming to top when embroidering. I have changed needle and re-threaded several times
Feb 16, 2010 | Singer CE-100 Futura Computerized Sewing...
Can't thread the bobbin on a singer futura CE 150
Be sure the bobbin thread is coming off from the left. There is a picture on my Futura bed that shows the correct way to insert the bobbin. If the thread is comming off from the right you will have the problem you described.
Good luck,
Beth
Jun 29, 2009 | Singer CE-100 Futura Computerized Sewing...
Singer ce350 bobbin thread on top
Be sure when you are threading the top thread that you ALWAYS RAISE the presser foot. This releases the tension disk and allows the thread to seat properly.
Have you gone back and re-tested on your test fabric? Does it work okay on the test fabric? If so, then there's a suspicion that it has something to do with the fabric, needle & thread of your project. Is your project fabric very dense, heavy... Are you using a stabilizer? A hoop--is it taut, not stretched? Make sure the fabric is not trampolining. Could be an incompatibility. The needle & thread may be having difficulty piercing the fabric. Try a different weight needle, perhaps a microtex or embroidery needle.
Mar 23, 2017 | Singer CE-100 Futura Computerized Sewing...
While sewing on singer quantum futura ce-200 sewing machine, thread bunchedup on underside of fabric and bobbin case flew out more than once.
Mine did this and it seemed impossible to fix. My problem was a tiny bit of thread stuck in the bobbin cover (but it could be anywhere in the thread route). I ran dental floss through the path the thread follows and also in the bobbin cover and poof out came a small piece of thread that all my looking missed. Hope this helps.
Dec 27, 2008 | Singer CE-200 Quantum Futura Computerized...
Singer CE-200 Quantum Futura Computerized Sewing Machine Logo
242 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
