My dispenser was gunged up, I cleaned this, now the softner will not dispense
  • 82 Answers
Have you damaged the control that guides the water into the softener?
There is often an adjustment under the machine cover (if it's the same as a British model.
But if it was ok before you cleaned it, then you have broken it.
Posted on Sep 30, 2009
Is not taken the softner and the bleach
Clean the dispenser with boiling water and see if it is just a sticking problem, these get gummed up after a while.
Aug 19, 2016 | Bosch Nexxt 300 Series WFMC2201UC
How do you get the agitator to come out the fabric softner dispenser is filthy and all needs to be cleaned
By grasping just the fabric softner dispenser and wiggling it from side to side while pulling up the softner dispenser will come out to be cleaned.
GENE
Oct 13, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
I have a samsung washer p1253, the machine goes thru all its cycles apart from taking the softner, ive taken the draw out on washed it put it back together and it still wont take softner in, any advice...
I hope you don't mind me saying so but often the softener dispensing siphon tube gets missed when cleaning the dispenser 'cos it's difficult to see!
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this isn't the problem it could be that the water dispensing is not working correctly. It is easy to check by selecting (final?) rinse, pulling the drawer slightly out and seeing and hearing whether water is being fed into the softener tray. If is isn't then it is a call-out ;-0(
Good luck,
John C
Mar 20, 2011 | Washing Machines
The dispenser does not dispense fabric softener or bleach
clean dispenser remove it and flush the holes etc. out also clean the area were the dispenser goes the softner is sticky and needs to use a little and some times none.
Jul 04, 2010 | General Electric WSSH300G Front Load...
Maytag MAH8700AWW will not dispense fabric softener
u need to replace the water valve theres 2 the cold is what u would replace
May 21, 2009 | Maytag MAH8700AWM Neptune Front Load...
Fabric softner dispenser
take the soap dispenser drawer out and clean the drawer and the underneath the drawer, then clean the inside of the machine where the drawer fits into to. It could be caused by a build up of soap.
Oct 30, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Kenmore front load washer will not dispense fabric softner
I've had this same problem and solved it by removing the detergent/bleach/softener dispenser drawer from the machine and seriously cleaning out all of the "gunk" from the drawer and from inside the drawer area on washer. Sometimes I have had to repeat the cleaning and then the fabric softener begins dispensing again. I have model # 417.43042200 but it may work on all the Kenmore front loading washers.
Oct 28, 2008 | Washing Machines
Start by cleaning the dispener, pull the dispenser out the owner manual should show you how to do this.
Take the cover off and clean and rinse the dispenser out, reassemble.
If this doesnt help let me know, there may be other problems.
May 04, 2008 | Speed Queen ATS90AWN Front Load Washer
Water collecting in the fabric softner dispencer
you need to take out dispenser draw and clean out under tap
the softner dispenser syphons out and if channels are gluged up the dispenser will not empty
Mar 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
NEPTUNE WASHER
"downy ball" is designed to open at the end of first spin that is the way to go without stopping machine. works very well and costs just a few dollars
Feb 07, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
62 people viewed this question
Top Washing Machines Experts
