Red picture with a Zenith big screen
I have a zenith big screen that has a red picture it is a PVR6069 RK took the front cover off and the tubes are working. I believe this is a module type board dont know which one to change or what to to do. Would like to fix this my self sounds like i can get rebuilt modules online any help thanks Randy I have a e-mail of randypeters@q.com
  • Randy Peters
    Randy Peters Dec 19, 2007
    looked at each crt board all resistors look good no burn marks on board so it does not look like any resistors burned but i know that does not not mean one of them is not bad but looking at each board it is clean looking and all resistors on each board look good visually turned each board over looked at soldier joints they look good and no evidence of any hot resistors any suggestions
  • 259 Answers
Here is some info I found on your TV:
That resistor is located on the CRT board of each gun. Ususally if an image is predominantly one color then that color gun has a bad 120k resistor on it's crt board.
Posted on Dec 19, 2007
  • Rafael Ortiz
    Rafael Ortiz Dec 19, 2007
    Here is some more helpful info:
    take the front off and look down into the three tubes.they should be clear not cloudy. if one is cloudy the coolant fluid needs changing. also check the fluid has not leaked down onto the board attached to the end of the tube.
    120 k resisters may need to be replaced 1 on each
    CRT socket may need to be replaced
1995 27" zenith tv picture dark with red glare won't adjust
THE TUBE IS CARBONIZED -IF YOU HAVE A TECHNICAL KNOWS
PUT 9V CA or CC IN FILAMENT AND A LAMP MAX 15WATTS IN SERIE WITH ANODE AND RED GREEN BLUE CATHODE (ONE AT TIME) -OFF FILAMENT AND YOULL SEE SPARKS INSIDE THE TUBE WHEN DESCABONIZE. REPEAT AT LEAST 3 TIMES
Sep 25, 2013 | Zenith B27A11Z 27" TV
Zenith pvr6069 rk is out of focus for letters and picture not very bright
First this set should have a production date on the rear of around 1995--fairly old.
If letters outlined in red etc--a convergence problem--either adjustment with remote (in menu) or a circuit problem in same area.
If picture dull and darker--locate the 3 large lens inside from the rear and wipe them clean--they are the light source for the sets picture and if dirty will cause a dark dull picture.
Let me know if questions.
SD TECH
Apr 22, 2012 | Televison & Video
Zenith TV has me seeing red.
The red gun in the picture tube itself is shorted on. You will have to replace the picture tube itself to fix the problem. Probably want to just buy a new set. Sorry!
Mar 16, 2010 | Zenith B25A10Z 25" TV
I have a 1994 zenith big screen the picture is showing really dar
It could be that the picture tubes have gone down on emission, there is a prcedure that can be tried to bring up the overall brightness but it is just possible that you will loose some picture quality. If it's a 1994 projo tv i am thinking of the three crt system, a gray scale alignment would probably correct the dark condition in your picture, again depending on how far gone is the emission in your picture tubes, if your projo tv is the dlp system, the bad news is that you could be needing some light engine repair. The color adjustment is possible with the availability of a service manual or in the case of the dlp system, light engine repairs or replacement are available from some on line stores.
Jan 12, 2010 | Zenith E44W46LCD 44" Rear Projection...
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
Picture on big screen
Chances are, if it's an older set, componants have changed value through use over time, which also includes the picture tubes and associated driver circuits. The way to compensate for this color drift is through adjustments. Either turn the red down a little, or turn the blue and/or green UP. Be carefull though as there are potentially dangerous voltages in and around the circuit boards and picture tubes.
Jun 29, 2008 | Zenith P42W46X 42 in. Plasma EDTV
Dark picture, mostly red colors
if you set is over 4 yrs old the tube is at fault,you may try to adjust the screen settings.
Mar 27, 2008 | Zenith B25A76R 25" TV
Tube set zenith tv
This is very typical of a Zenith set.Your picture tube will have to be replaced.One of your 3 primary colors (red,green,&blue) have turned off leaving you with the color of the dominant color.I would heave it.
Feb 10, 2008 | Televison & Video
Televison & Video Logo
43 people viewed this question
Top Televison & Video Experts
